| Tsopo |
 Tsopo Two Stroke Sniffer
 Posted: 15:14 - 26 Aug 2010 Post subject: Front brake noise (all the damn time) |
A few days ago it started suddenly and I've no idea why. There's a noise coming from the front disc/pad. When in motion (not braking) there's a loud, scraping sound. However, there's also a knocking sound that increases in frequency the faster the wheel turns, and which is more audible when cornering.
When I apply the front brake both noises stop. Unfortunately, at low speed they are replaced with a generally shitty sound, which is more noticeable when I brake firmly. I know that's a vague explanation, but it's the only way I can describe it; it's as if there's a whole load of rubbish on the pad or something. At very low speed I can feel excess vibration when I brake.
Does anyone know why this may have started? And more importantly, what to do about it? Nothing has happened to the bike (03 Varadero), certainly not since I've had it. And as I said, it started very suddenly a few days ago.
If I need new pads, it's something I'd like to do myself as I want to learn as much as I can about the bike (and bikes in general). I wouldn't want to take it to a garage unless it was a severe problem.
Any advice would be most appreciated  |
| bacon |
 bacon World Chat Champion
 Posted: 15:24 - 26 Aug 2010 Post subject: Re: Front brake noise (all the damn time) |
if your worried about the pads, why not remove them and have a look at them?
There will be a pad cover or something similar which you will have to remove, either small screws or allen key headed bolts to take it off.
Then the pads are usually held in place with a pad pin that will have a small circlip or something stopping it from coming out of the caliper, pull the clip out, slide out the pad pin. then pull the pads out, if they are knackard or worn below spec then get some new ones.
its a simple 5 minute job so dont worry if you havent done it before.
Worst case is they are very dirty and the pads are a bit stuck in, in which case you may need to unbolt the caliper from the fork leg to get the pads out.
When putting the pads back in, give the back of them a good clean, then apply some copper grease to the back, will stop noise coming from vibrations against the piston etc, and will also prevent siezing
edit: Just a thought, while you have your pads out take a look at the pistons, if any of the pistons in your calipers have siezed up that could be contributing to the excess noise, in which case you would need to rebuild your calipers (piston removal), potentially new seals etc, but thats a fun job hehe.
What can happen is that months of salt from the roads etc can get behind the dust seal and into the groove, causing corrosion etc, this pushes the dust seals into the pistons which can lead to the seals being dragged out with the piston and causing it to become very stiff and seize up.
But yeh see what the pads and pistons look like first, may give you some insight to whats wrong, good luck |
| MarkJ |
 MarkJ World Chat Champion
| ZRX61 |
 ZRX61 Victor Meldrew
| Lycan |
 Lycan Derestricted Danger
| Tsopo |
 Posted: 20:04 - 26 Aug 2010 Post subject: |
Cheers for the replies. I'll follow the advice and have a look, although I'm a little worried that it may be a bigger issue than my newb mind understands
If it is a warped disc, how would that have happened so suddenly, without anything 'bad' having been done to the bike (i.e. dropped, crashed)? |
| Digit |
 Digit Scooby Slapper
| Lycan |
| Tsopo |
| Lycan |
| Paxovasa |
 Paxovasa World Chat Champion
 Posted: 20:30 - 26 Aug 2010 Post subject: |
Could also be like mine and that is the floating part of the disc has movement from the bobbins.
That will explain the knocking noise and also why you feel a pulse through the brake lever when pulling gently on the front brake, it will also explain why when you brake more forcefully that it stops  ____________________ Suzuki GSF600 K3 (in the fastest colour, black). |
| Tsopo |
| Tsopo |
The last post was made 15 years, 350 days ago. Instead of replying here, would creating a new thread be more useful? |
