Removing Exhausts
Adrian
PostPosted: 15:17 - 26 Aug 2010    Post subject: Removing Exhausts Reply with quote
Hi everyone,
I'm thinking of removing the exhaust system on my Hornet for cleaning and was wondering is there anything I should be aware of or it's pretty straight forward?
Can you just take them off, polish them and put them back on?
Thank's a lot!
DAS 18/06/09 Off The Kerb Motorcycle Training. Proud owner of a Honda CG125 & a Honda Hornet
MarkJ
PostPosted: 15:51 - 26 Aug 2010    Post subject: Reply with quote
If you take the headers off you'll need four new gaskets that go inbetween the headers and the block.
There is a reasonable probability that the nuts are rusted onto the studs, and when you try undoing them they will just snap the stud, and you'll need to buy and fit new studs and bolts.
Someone will be on in a bit to tell you how to increase your chances of getting bolts off studs using plusgas. I've only ever replaced one set of headers off a trackbike and they all came off fine, so can't comment.
Adrian
PostPosted: 16:27 - 26 Aug 2010    Post subject: Reply with quote
Thank's for the reply Mark. Why do these need to be replaced?
The bike is quite new so I doubt there's going to be bolts that are rusted or anything like that.
Pickledswede
PostPosted: 16:31 - 26 Aug 2010    Post subject: Reply with quote
I found this out when I did mine recently, the gaskets are copper tubes, you can get fibre ones but they're slightly different. When you put the downpipes on and tighten them up these get crushed and take up all the space between the manifold and the exhaust, creating a seal, when you take the pipes off and put them back on they'll never fit exactly again so you need new ones to form a proper seal
Adrian
PostPosted: 16:34 - 26 Aug 2010    Post subject: Reply with quote
Perfect, now I'ts all clear. Another problem solved...
Thank's everyone!
Smile
MarkJ
PostPosted: 16:41 - 26 Aug 2010    Post subject: Reply with quote
Sorry didn't notice you had a new shape Hornet. As it's 2 years old max you're probably alright on the rusty studs front. When you come to putting them back on it might be a good idea to pop some gopper grease on the threads to stop them seizing in the future.
Adrian
PostPosted: 16:46 - 26 Aug 2010    Post subject: Reply with quote
I will do that. Does it have to be copper grease or?
bacon
PostPosted: 17:18 - 26 Aug 2010    Post subject: Reply with quote
copper grease is ideal as its high temp Thumbs Up im sure you can use other metal based grease if you have them laying around instead?
Adrian
PostPosted: 17:41 - 26 Aug 2010    Post subject: Reply with quote
I'll just buy some copper grease...keep it on the safe side. Smile
Skudd
PostPosted: 18:43 - 26 Aug 2010    Post subject: Reply with quote
Don't use normal grease. Embarassed
A mate of mine Wink only did that once many years ago, HIS bike smoked like a good 80 a day guy when stood at traffic lights.
Adrian
PostPosted: 19:26 - 26 Aug 2010    Post subject: Reply with quote
Lol, i'll stick with copper grease then.
The last post was made 16 years, 33 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 0.65 - MySQL Queries: 13 - Page Size: 68.4 Kb
