Front brake problem??
fazza59
PostPosted: 17:33 - 26 Aug 2010    Post subject: Front brake problem?? Reply with quote
Can someone advise me...
My R1 has developed a slight problem. Under slow speed braking (using front brake) the forks dip as thought the brake pads are binding. At high speeds this is not noticable.... I dont get any pulsing throught the lever! I know most will say the disks are warped but I dont think they are... Could it be sticking pistons? Or could it be something else???
Any suggestions would be great.
Current - Yamaha R1 - Yamaha XJ600N - Kawasaki GPZ 500S (project? Maybe )
Pics of my bikes
MarkJ
PostPosted: 18:27 - 26 Aug 2010    Post subject: Reply with quote
Sounds like sticking pistons to me, you might be lucky and the discs haven't warped yet.
Go for a quick ride round the block, avoiding heavy braking, and see how hot the discs are when you get back.
fazza59
PostPosted: 18:33 - 26 Aug 2010    Post subject: Reply with quote
I have felt the disks after a long ride and they dont get hot! Thefront wheel spins freely so I dont suspect warped disks...
Pics of my bikes
mad4it028
PostPosted: 18:36 - 26 Aug 2010    Post subject: Re: Front brake problem?? Reply with quote
My R1 has developed a slight problem. Under slow speed braking (using front brake) the forks dip .
the forks are ment to dip under braking
fazza59
PostPosted: 19:18 - 26 Aug 2010    Post subject: Re: Front brake problem?? Reply with quote
Ok let me rephrase......they dip then come back up ...then dip then come back up.... so its not normal...If it was normal I wouldnt post it as a problem..
Pics of my bikes
MarkJ
PostPosted: 19:24 - 26 Aug 2010    Post subject: Reply with quote
No oil in the forks? Have you blown a seal?
fazza59
PostPosted: 20:57 - 26 Aug 2010    Post subject: Reply with quote
Forks are fine... seals are fine...its the brakes or head bearings! Well thats my theory....
Pics of my bikes
Digit
PostPosted: 21:15 - 26 Aug 2010    Post subject: Reply with quote
I'm not familiar with your model but two things seem possible to me. Brake problem is one, but does the bike have anti dive? if so a a fault there could be a second possibility.
Roy.
Happy daze!
mad4it028
PostPosted: 21:21 - 26 Aug 2010    Post subject: Reply with quote
out of shape front tyre?
MarkJ
PostPosted: 21:40 - 26 Aug 2010    Post subject: Reply with quote
Does it feel like a knocking? I know what gone head bearings feel like but I wouldn't describe it as though the forks dip then come back up
fazza59
PostPosted: 22:25 - 26 Aug 2010    Post subject: Reply with quote
No anti dive....tyre is fine....
Hard to explain.....but here goes....5mph ot less....slight front brake not much pressure...forks dive as you would expect as the front brake is applied...the the brakes feel as thought they release and the forks rise....then dip again as they bite..
but I have to say this is only at low speed.....at high speed all is fine??? thats what I cant understand
Pics of my bikes
Ariel Badger
PostPosted: 22:58 - 26 Aug 2010    Post subject: Reply with quote
Any uneven wear on the pads or air in the system?
loply
PostPosted: 23:10 - 26 Aug 2010    Post subject: Reply with quote
Okay, so you have the text book perfect symptom of warped discs.
You say you don't think they are.
Any reason?
Because if you haven't taken them off and lay them on a sheet of glass then the logical answer is that you have warped discs.
Yamaha SZR660 Caution to the wind, the throttle pinned!
MarkJ
PostPosted: 23:15 - 26 Aug 2010    Post subject: Reply with quote
That certainly sounds to me like a warped disc or discs with seized pistons. I had it a few months ago - pistons were seized so you didn't get any pulsing on the lever as they wouldn't go back into the caliper to move the fluid against the master cylinder, but moved enough to brake. So when the wheel spun you got a braking force where the disc was warped out of shape and pushed against the pads then no force where it was normal.
You can do what loply says, or just take the calipers off the front wheel and spin the wheel. Look from the front as the wheel spins and you'll notice any warped discs because they won't stay true and will appear to weave.
fazza59
PostPosted: 19:21 - 27 Aug 2010    Post subject: Reply with quote
Ok so looks like it might be my worst fears ..... Was only hoping it was not a warped disk but looks like I might be wrong!!! Can anyone tell me if buying a set of wavy disks from china is a bad idea??! Looks like I'm gonna have to service the calipers as well. Had them off and one is sticking Sad
Bugger
Pics of my bikes
Digit
PostPosted: 19:26 - 27 Aug 2010    Post subject: Reply with quote
There's only one problem with buying from China that I've experienced and that's boredom whilst awaiting delivery.
Roy.
Happy daze!
Noxious89123
PostPosted: 21:10 - 27 Aug 2010    Post subject: Reply with quote
Roy.
There's more than one problem! The main one being that they are likely to be useless shit that warps in a few thousand miles.
Keep away from Kagizume discs; lots of stories of them warping. Personally I'd go OEM every time.
The last post was made 16 years, 54 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.08 Sec - Server Load: 0.91 - MySQL Queries: 13 - Page Size: 95.61 Kb
