recommend me a tool for measuring BTDC for ignition timing
cb1rocket
PostPosted: 13:18 - 27 Aug 2010    Post subject: recommend me a tool for measuring BTDC for ignition timing Reply with quote
Hi all
Can someone recommend me a tool that I can stick in the plug hole or any other piece of equipment so I can set my ignition timing?
The book says to rotate flywheel so the piston moves at least 4mm down past TDC then back it up to 1.87mm
GP100 in case anyone wants to know.
What tools can I use?
Ichy
PostPosted: 13:23 - 27 Aug 2010    Post subject: Reply with quote
https://www.tickintimeworldofwatchtools.co.uk/6-sliding-depth-gauge-1382-p.asp
or
https://www.screwfix.com/prods/38291/Hand-Tools/Measuring/Calipers-Micrometers/Forge-Steel-Vernier-Calliper?cm_mmc=GoogleBase-_-Datafeed-_-Hand%20Tools-_-Forge%20Steel%20Vernier%20Calliper
or a long DTI
https://www.discount-tools-uk.co.uk/product/900/dti-dial-gauge
Vernier caliper is of more use generally.
cb1rocket
PostPosted: 13:48 - 27 Aug 2010    Post subject: Reply with quote
Have a vernier caliper somewhere, but then how accurate can it be?
What about a screw in type?
https://cgi.ebay.co.uk/TDC-TIMING-TOOL-NORTON-TRIUMPH-BSA-/250681597893?pt=UK_Motorcycle_Parts
Also when it says rotate backwards, (ie clockwise from view) does it mean rotate the piston past TDC until about 4mm then go back at 1.87 or does it mean rotate back to 1.87 from TDC?.
I'm confused.com!
Digit
PostPosted: 16:31 - 27 Aug 2010    Post subject: Reply with quote
If you're so inclined you make your own from an old spark plug and a piece of dowel.
Roy.
Happy daze!
The last post was made 16 years, 49 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.35 Sec - Server Load: 3.56 - MySQL Queries: 13 - Page Size: 44.58 Kb
