delay on indicators?
skatefreak
PostPosted: 09:55 - 29 Aug 2010    Post subject: delay on indicators? Reply with quote
Hey, boring one here lol.
Ever since i got this bike there has been a delay on the indicators. The front are not stock and the back are LED with in line do hickys to keep the flash rate constant.
I got a new battery and changed the reg so the electrics are a healthy 12.5+ at all times and the indicators still have a delay from flicking the stick to them coming on...
Its getting anoying as i want to get round to doing my full test but dont think i'll have the confidence when there is a delay of up to 5-6 seconds some times which means some times i end up indicating to early or to late Neutral
One thing i noticed is occasionally if i go directly from indicating from one direction to the other they will switch without any delay but if i stop and then indicate in the other direction there will be a delay Neutral
Cant say i'm to hot on electrics so have no idea where to start looking.
Only other thought is there seems to be a randomly long cable going to the back indicators where i think who ever put the LED indicators on just stuck the cables for it onto the existing cables lengthining it quiet a bit.
Any thoughts would be much appreciated.
Best regards
-Jvr
defblade
PostPosted: 10:02 - 29 Aug 2010    Post subject: Reply with quote
I'd try changing the indicator relay. There has to be movement inside it to switch the current and maybe it's getting worn out - takes a while to start moving from cold (happens to the best of us!).
Or put stock indicators back on, at least for the test.
iooi
PostPosted: 10:05 - 29 Aug 2010    Post subject: Reply with quote
Either get std ones all round or led all round. At least that way you can swop out the relay and rule out that problem.
Might be also worth while giving the switch a good clean out.
skatefreak
PostPosted: 12:00 - 29 Aug 2010    Post subject: Reply with quote
Awesome,
Will get onto it.
I dont have the origional but i do have some g-d awful stalky round ones that i can try out for now, although the cable is cut right by the indicator... fun fun fun...
Will give the switch a look at to and get back to you.
-Jvr
The last post was made 16 years, 16 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.05 Sec - Server Load: 0.81 - MySQL Queries: 13 - Page Size: 40.79 Kb
