| Robby |
 Robby Dirty Old Man
| Itchy |
 Itchy Super Spammer
 Posted: 17:15 - 31 Aug 2010 Post subject: |
Plastic welding varies, it depends on the extent of the breakage TBH and how much plastic you melt into it.
Peter welded it up on my side fairing which was a fairly long single crack it has held. (bike fell on this side when a scrote pushed it over) but he melts big plastic rods into it and made a mess requiring lots of sanding down. Though this was a simple single crack and the bike has been pushed over by chavs more than a few times and the repair has held.
Alan on the other hand welded up my indicator mount as in Spain 2008 I crashed and it punched a hole all the way round my indicator mount on the CBR. He welded it up and first time a chav pushed it over it broke taking out an even bigger piece of fairing.
Peter's was thicker, while Alan's was brittle for some reason.
I taped it up for ages, then simply sealed it up with a couple globs of liquid steel gum on both sides a hefty blob on the inside and a fair blob on the outside sanded down. I also used it to repair a lug at the bottom and he has held fine. Its £6 for a tube so not too expensive to try. ____________________ Spain 2008France 2007Big one 2009 We all die. The goal isn't to live forever, the goal is to create something that will. In the end, your life will flash before your eyes. Make sure it is worth watching. |
| yandy_yay |
 yandy_yay Brolly Dolly
 Posted: 17:24 - 31 Aug 2010 Post subject: |
super glue it in place and then...
https://cgi.ebay.co.uk/3M-Scotch-Weld-DP460-50ml-2-EPX-Quadro-Mixing-Nozzles-/260652151596?pt=UK_Body_Shop_Supplies_Paint
get some of this bad boy around it, supose araldite might work as well but this stuff is better, i have repaired plastics with this before and it's held with everything i've managed to throw at it. ____________________ past bikes: (20 years ago) cg-125 (wriiten off), C-50 (thrashed n' finnaly scrapped), CZ-125 (nicked - never recovered, insurance payout was more than i paid for it !!!)
Current bikes: GN 125(now sold), Divvy 600s. |
| rob_scott92 |
 rob_scott92 Could Be A Chat Bot
 Posted: 18:20 - 31 Aug 2010 Post subject: |
I had this 'dialemma' when i first got the honda.
Lots of plastic weld was mentioned but in the end i just used superglue which did the job for a while.
Then after this they just snapped again so i had an idea,
I used some ordinary staples to reinforce the 'fix'. (Bent them into place into the lugs from underneath) put some silicone grease on the lugs so that they wouldn't be under too much pressure when putting the side panels back on/taking off. They're still fine 3 months later
This is obviously the cheap way to do it and as my bike is pretty tatty all round anyway this didn't bother me.
Little tip though: Don't put too much silicone grease on! This will result in you losing a side panel on the motorway at 60 when you stretch your leg
 ____________________ First bike: 1982 Suzuki Gs 125 'The beast MK1' > 1988 Honda Cb 350's' FOR SPORT! (Good ol' oil burner!) > 2001 Suzuki Sv 650 's' Made it out of the 80's! > 1997 Honda Cbr 600f :p |
| Teflon-Mike |
 Posted: 18:29 - 31 Aug 2010 Post subject: |
I have just popped on to have a look whats going on, while I take a break, and have a coffee, from......
Repairing some side-panels!
Actually MADE the lugs to go on them, from scratch, with nothing more than a 30w soldering iron, and a broken staka-box!
Taken-photo's too, to make a 'how-to' on it!
Honestly, it is just BRILLIANT making stuff 'good' again, from utter scrap!
anyway, plastic welding is the way to go, and if you get enough penatration into the weld and make sure you get enough fille plastic into the wound, AND spread the wound over a wide enough area, it should be 'good'.
ONLY thing is that if its a bad one, or you are a bit cack-handed you can distort the 'face' side of what you are working on, which is no great shakes, if you are really keen, and can make for a better joint, as you can use it to make sure you have penatration right through the panel.
Just means you have to add more build on the face side, build it up, smooth it off, file, sand and paint, which is you want a quick fix without having to paint or replace graphics can be a pain.
In which case dont go deep, spread the wound WELL over the area and add lots of build to get the joint long and strong, if not dep and strong. ____________________ My Webby'Tef's-tQ, loads of stuff about my bikes, my Land-Rovers, and the stuff I do with them!
| Frost |
 Frost World Chat Champion
| Ed Case |
 Ed Case World Chat Champion
| stirlinggaz |
| ms51ves3 |
 ms51ves3 Super Spammer
| MarJay |
 MarJay But it's British!
| TUG |
 TUG World Chat Champion
| Robby |
 Robby Dirty Old Man
| Teflon-Mike |
 Posted: 00:24 - 03 Sep 2010 Post subject: |
Redundant, I know, BUT, just finished compiling the pics and txt for the 'how to' & Snow-tigeress has just used it in her 'Pup' restoration thread over on show & Tell; so in HER words:-
| Quote: | Tef has been doing a bit of wizardry with old staka-box plastic and a soldering iron, re-making the lugs to hold on the side panels and tail cowling, but the first thing was to 'panel-beat' the side panels into shape, as they were a bit warped for some reason.
https://i178.photobucket.com/albums/w269/teflons-torque/Little%20Dreams/imag1353.jpg
Tef did this with a couple of hammers and an electric blow-lamp! Clever, hugh!
https://i178.photobucket.com/albums/w269/teflons-torque/Little%20Dreams/imag1560.jpg
Tef, getting cleverer with the soldering iron and bits of old scrap plastic snapped out of yet another broken stak-a-box!
https://i178.photobucket.com/albums/w269/teflons-torque/Little%20Dreams/imag1561.jpg
First he welded two strips together to make a T section
https://i178.photobucket.com/albums/w269/teflons-torque/Little%20Dreams/imag1565.jpg
Then added another to make an X section
https://i178.photobucket.com/albums/w269/teflons-torque/Little%20Dreams/imag1566.jpg
Then he melted down the edges, using the molten plastic to fill the corners of the X and make the whole section the same width.
https://i178.photobucket.com/albums/w269/teflons-torque/Little%20Dreams/imag1567.jpg
THEN he melted down all the 'spare' platic off the end, filling in the corners of the X for about 1/2" to make the 'head' (Phnar-Pnar! You'll see what I mean in a tic! I think its unfortunate that the stak-a-box he nicked the plastic from was red.... just sort of emphasises the phallic similarity!)
https://i178.photobucket.com/albums/w269/teflons-torque/Little%20Dreams/imag1568.jpg
About 1" from the end, he melted a notch in the X section, and welded in another strip of plastic, to make the base of the lug where it would push through the rubber..(Oh gawd! The innuendo!)
https://i178.photobucket.com/albums/w269/teflons-torque/Little%20Dreams/imag1569.jpg
He did that on all four sides, melting the spare plastic into the section to form a solid base, and then using more plastic melted into the bit above, shaped the 'head' (NOW do you see what I was laughing at!) And welded, using the spare plastic at the bottom to get (Tef's words not mine !) 'good penetration' (sheesh! I feel like I'm writing the captions for a porno mag, not a motorbike restoration! Must be my dirty mind!) {Err. Tef just said, DEFINITELY my dirty mind! LoL}
https://i178.photobucket.com/albums/w269/teflons-torque/Little%20Dreams/imag1542.jpg
These are almost ready to be sanded properly, primed and painted.... only thanks to Halfords 2-Can stock holding, we don't have any paint at the moment! |
THAT is how you make a phallic statuette.... sorry, side-Panel lug, from scratch, with scrap plastioc and a soldering iron! ____________________ My Webby'Tef's-tQ, loads of stuff about my bikes, my Land-Rovers, and the stuff I do with them!
| Robby |
 Robby Dirty Old Man
| Gone |
 Gone Nearly there...
The last post was made 15 years, 304 days ago. Instead of replying here, would creating a new thread be more useful? |
