Lumpy Idle
bandit600
PostPosted: 14:10 - 01 Sep 2010    Post subject: Lumpy Idle Reply with quote
I have a 98' 600 Bandit which is very lumpy on idle.
It is up and down and does not sound smooth.
I have replaced the plugs, oil, oil filter and had the carbs off and cleaned them with carb cleaner. I have also been adding redex to the fuel.
The only thing i have not got round to is repalcing the air filter.
Could this be causing the issue?
cheers
PostPosted: 14:14 - 01 Sep 2010    Post subject: Reply with quote
Doubtful, sounds like it needs carb balance to me.
Digit
PostPosted: 14:28 - 01 Sep 2010    Post subject: Reply with quote
As Chris said.
Roy.
Happy daze!
el_oso
PostPosted: 15:06 - 01 Sep 2010    Post subject: Reply with quote
it is firing on all four cylinders isn't it?
easy to check by touching each of the headers in turn with a wet sponge or cloth and listening for it to sizzle.
CAUTION:header pipes get extremely hot extremely quickly.
if all four are working then balance your carbs
Duke 390
Car: Jeep Wrangler 4.0L
bandit600
PostPosted: 20:17 - 01 Sep 2010    Post subject: Reply with quote
It is firing fine on all 4 cylinders, yes the headers are all very hot.
i have enquired at my local garage and they would charge me £50 per hour plus vat and it will take them 2 hours to balance the carbs.
This sounds a lot to me, anyone any ideas on what it should be, or am i being tight?
Digit
PostPosted: 20:23 - 01 Sep 2010    Post subject: Reply with quote
Tight??? I can't move! Very Happy
Buy a set of guages and DIY.
Roy.
Happy daze!
bandit600
PostPosted: 20:37 - 01 Sep 2010    Post subject: Reply with quote
I think i might just do that.
Cheers Roy.
Digit
PostPosted: 20:58 - 01 Sep 2010    Post subject: Reply with quote
Then you can do your mates bikes at £40/hr! Laughing
Roy.
Happy daze!
Ditto
PostPosted: 17:40 - 02 Sep 2010    Post subject: Reply with quote
Don't get them balanced until you've done a full service, oil, plugs, valve clearances etc. Balancing should be the last step.
CG 125 > Bandit 600 > CBR 600 FY > Street Triple R
The last post was made 15 years, 220 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.05 Sec - Server Load: 0.28 - MySQL Queries: 13 - Page Size: 57.02 Kb
