Suzuki gaze 600 srad 1998
charlie123ree...
PostPosted: 19:46 - 02 Sep 2010    Post subject: Suzuki gaze 600 srad 1998 Reply with quote
Hi everybody, I have a 1998 sad and all was fine until a ride out last night, I went to change to 6th gear and there was a clonking and grinding noise and no drive in 6th gear,from then on there was rattling in every gear like the chain was loose, I pulled over and noticed my chain was rather loose, I have since tightened the chain and the rattling is still there, sounds around front sprocket area, I have very little mechanical knowledge but any ideas or advice would be much appreciated, thanks
Blue_SV650S
PostPosted: 19:50 - 02 Sep 2010    Post subject: Reply with quote
the front sprocket is probably worn out.
Take the front cover off and have a look (if unsure, post pic).
charlie123ree...
PostPosted: 19:53 - 02 Sep 2010    Post subject: Reply with quote
If it's worn would it rattle ?
Blue_SV650S
PostPosted: 20:04 - 02 Sep 2010    Post subject: Reply with quote
Yes - the chain will be flapping about - it might even be missing enough teeth that the sprocket spins in the chain under load?!
Get in there and have a look-see is the only way to know!! Thumbs Up
Digit
PostPosted: 20:54 - 02 Sep 2010    Post subject: Reply with quote
Do you have the noise in neutral, if so it must be the box or primary drive IMO.
Roy.
Happy daze!
charlie123ree...
PostPosted: 23:50 - 02 Sep 2010    Post subject: Reply with quote
Yes I do have the noise on neutral Roy cheers
mad4it028
PostPosted: 23:53 - 02 Sep 2010    Post subject: Reply with quote
oh that dosnt sound good if its the gearbox ide be looking for a new 2nd hand engine or a rebuild or next bike
Digit
PostPosted: 00:00 - 03 Sep 2010    Post subject: Reply with quote
A sudden noise, I suggest it's probably a broken bearing.
Roy.
Happy daze!
PostPosted: 00:21 - 03 Sep 2010    Post subject: Reply with quote
If the noise is in neutral it could still be the C&S just because the bike is not in gear doesn't mean the c&S won't be turning if it is rolling along, does it make the noise when the bike is stationary or only when it is moving?
If it makes it when stationary my bet is cam chain tensioner, I believe they are a week spot on these bikes. Should be fairly cheap and easy to fix.
If it happens when moving I'd say C&S it could be bearing but then crunch rather than rattle.
Digit
PostPosted: 00:32 - 03 Sep 2010    Post subject: Reply with quote
Agreed, but when I mentioned neutral I automatically assumed that the bike would be stationary, if not, all bets are off.
A camchain tensioner problem wouldn't cause a gear loss though.
Roy.
Happy daze!
Dex
PostPosted: 00:36 - 03 Sep 2010    Post subject: Reply with quote
I'd.check the front sprockets nut hasn't come loose
WalneyFrankie
PostPosted: 07:10 - 03 Sep 2010    Post subject: Reply with quote
im with the above check the front sprocket, could be its hooked and missing teeth.. even in neutral my rear wheel moves when the engine is running (albeit slightly)...
and might be worth removing cam chain tensioner and replacing the spring, then tend to shorten over time due to pressure, and only a few quid from a dealer... i'm doing mine...
The last post was made 15 years, 306 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.08 Sec - Server Load: 1.04 - MySQL Queries: 13 - Page Size: 69.77 Kb
