GS500 only one cylinder
Pete125
PostPosted: 14:58 - 04 Sep 2010    Post subject: GS500 only one cylinder Reply with quote
Hi i was wondering if anyone here could help me out with a problem with my gs500 project.
The problem im having is that its only firing on one cylinder i have swapped plugs around to see if it was the plugs at fault but no joy, the same cylinder wont fire. Im sure petrol is getting through as the plug gets wet ect.
Im guessing the next thing to try would be to try swapping the coils over to see if its the coils at fault.
Apart from that im at a loss at what it could be any help would be great thanks
almost forgot its a pain to start aswell but i have found that taking the plug out of the problem cylinder and hitting the start button seems to help getting it to fire up.
Casper
PostPosted: 15:01 - 04 Sep 2010    Post subject: Reply with quote
Does the problem side spark when plug is out and sitting on the block? Also you could have a stuck valve.
Pete125
PostPosted: 15:08 - 04 Sep 2010    Post subject: Reply with quote
Thanks for the quick reply,
Yes but its not what i would call a great spark tho, also its not very frequent like the other side.
Stuck valve hope not was really hoping to not have to take the engine out Smile
Casper
PostPosted: 15:17 - 04 Sep 2010    Post subject: Reply with quote
Shitty spark. Could be the igniter box is duff or pickup set wrong. Is this points or electronic on this bike. Just trace yoursel backwards checking all conections. If it has two coils try and swap them over to see if problem shifts, if it does you have a fooked coil. How is the HT lead, not old and split is it. Try swaping them as well. If it was running fine before it was taken apart i am sure it will be something stupid. Also look at the join where the HT goes into coil as if water had got in there then this can happen. Also HT into spark plug cap, cut a few mm here and screw back in to make sure you have a good connection.
Pete125
PostPosted: 15:30 - 04 Sep 2010    Post subject: Reply with quote
Hi yeah its electric going to try swapping the coils to see if i can get it to fire on the problem side.
Hopefully this will get it going as i seem to have lost my multimeter duh.
Casper
PostPosted: 15:33 - 04 Sep 2010    Post subject: Reply with quote
Doubt the coil swap will get it going just move the problem to other side but this way you know what to get.
Good luck
Pete125
PostPosted: 15:27 - 05 Sep 2010    Post subject: Reply with quote
Hmm swapping coils didnt seem to get that cylinder to fire up either,
But i did notice that after cleaning the plug putting on stove ect, and trying again that its not getting wet from fuel ect so i drained the carbs to see if they had fuel, they did. could the carbs be blocked somewhere stopping the fuel air getting to the combustion camber if the float is filling up fine ?
I've never stripped carbs before so not too sure any advice please
Thanks.
The last post was made 16 years, 56 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 1.53 - MySQL Queries: 13 - Page Size: 50.89 Kb
