quick tyre Q 190/50/17 instead ofa 180/55/17
Welshd1k
PostPosted: 18:18 - 04 Sep 2010    Post subject: quick tyre Q 190/50/17 instead ofa 180/55/17 Reply with quote
what would the effetc eb of puttign a 190/50 intsead of a 180/55 on a cb600 ?
Moo.
PostPosted: 19:23 - 04 Sep 2010    Post subject: Reply with quote
Not alot i should think, it'll still fit. All the numbers mean are the various widths of the rubber..
the first number is the width across, so it'll be 10mm smaller then the other, and the 2nd number is the sidewall width
https://www.tyres-online.co.uk/techinfo/sidewall.asp
A2 Passed 18/6/10
SamJL
PostPosted: 19:27 - 04 Sep 2010    Post subject: Reply with quote
It won't turn in as quickly, go for a190/55 instead!
2009 CBR1000RR
2004 KTM 200SX
2004 KTM 65SX Very Happy
Welshd1k
PostPosted: 19:33 - 04 Sep 2010    Post subject: Reply with quote
just a 2ct pilot road has poped up cheap. and i need a back tyre it runs a 180/55/17 stock
would a 190/50/17 kill it?
Crazy Assed Goose
PostPosted: 19:45 - 04 Sep 2010    Post subject: Reply with quote
Unless you're having issues with traction from accelerating all a bigger tyre will do is slow down the turn in. Wider ones look cooler though.
h00dwink
PostPosted: 21:12 - 04 Sep 2010    Post subject: Reply with quote
i'm running a 190 50 on the rear atm instead of 180 55. picked up a pair 2nd hand super cheap and had been used for very little mileage before getting changed.
through the experience with these, the turn in and acceleration does feel slower. i also cant get over to the very limit of the tyre, pretty much just to where a 180 would be.
Sahf East Winnah 4LYF
https://bikepics.com/members/h00dwink/00sv650s/
www.youtube.com/h00dwink updated regularly
binge
Emo Kiddy
PostPosted: 21:37 - 04 Sep 2010    Post subject: Reply with quote
That's probably because it's only a 5.5j wheel, a 190 tyre is meant for a 6j wheel.
So the edges of the tyre will be distorted where it's been pulled in further than it's meant to, making the edges almost impossible to reach.
Stick with the 180/55 if you can. I changed my TLR1000 from a 190/50 to a 180/55 for handling.
Ben
bacon
PostPosted: 01:29 - 05 Sep 2010    Post subject: Reply with quote
Ben
Would putting a 180/55 tyre on a 6 inch rim not have the opposite effect you were hoping for? i.e the smaller tyre is being stretched over a wider tyre so making its profile flatter? so it would not steer any quicker at all, plus you now have less rubber in contact with the road surface than before?
I might b wrong, but its what put me off of taking advice of fitting a 180/55 to my 7r, so i stuck with the 190/50, though im going to make some spacers for the rear hugger and fit a 190/55 when these tyres die
binge
Emo Kiddy
PostPosted: 18:43 - 05 Sep 2010    Post subject: Reply with quote
In some ways, yes.
But a 180/55 still has a slightly taller profile to a 190/50, So you're still gaining that bit of height at the rear.
190/55 is the BSB size, best size to go for on a big sports bike if clearance will allow.
Ben
The last post was made 16 years, 17 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.10 Sec - Server Load: 0.5 - MySQL Queries: 13 - Page Size: 60.79 Kb
