Ramps
Dan79
PostPosted: 00:00 - 01 Sep 2010    Post subject: Ramps Reply with quote
I need a ramp to assist getting one of my bikes into my shed in the winter.
I know it will fit as it is the same size of shed, in a new position. I used to simply use a block of wood and force of momentum as the elevation was only about four inches.
However the new position is 7 inches above ground level (including lip of doorway, which i would consider cutting a channel through if necessary). Too much for a 5'8" shrimp like me to charge a 190kg bike in without doing serious damage to the shed, the bike, or myself, or a combination of the three.
If anyone either has a good method for getting a bike into a narrow doorway at this height, involving makeshift ramps or whatever, I'd be interested in details of such methods.
Previous bikes - 1984 Honda VF500 (FII) Interceptor and 1990 Yamaha RXS100
Current bikes - 1984 Honda VF500 (V30) Magna
CptBlack
PostPosted: 01:53 - 01 Sep 2010    Post subject: Reply with quote
You need an extravegant system of pullys and levers.
Seriously though, how much space have you got to play with in the run up?
Normally, I find a small ramp and ride it in with lots of clutch control is enough but only had about 5 inches to ride up really.
Ariel Badger
PostPosted: 08:10 - 01 Sep 2010    Post subject: Reply with quote
I often watch people push a bike into the back of a van up a scaffold plank. I use a wider piece of wood that was once a science desk top. 7" is not high, long ramps are easier than short ramps IMHO.
Kwaks
I'm not a fast rider
PostPosted: 08:52 - 01 Sep 2010    Post subject: Reply with quote
The entrance to my shed at the end I put my bike is about 2 ft off the ground.
When I open the shed door, I wave a hinged ramp inside made out of decking boards, which I drop down.
www.cliqueycuntsmcc.co.uk
truslack
PostPosted: 11:38 - 01 Sep 2010    Post subject: Reply with quote
While marshalling we push bikes into the back of the recovery vans on scaff planks, and that's about 1.5-2ft high - 7inch shouldn't be a worry.
Dan79
PostPosted: 19:41 - 02 Sep 2010    Post subject: Reply with quote
Thanks for all the replies, this gives me plenty to go away with and try out.
I have plenty of room for a run up, albeit no room to overshoot once in the shed only about 2 inches, no room to either side due to shelves, bucycles, and piles of other junk, and have to rock the bars from side to side to get handlebars and indicators through the doorway - never tried getting bike in under its own power for these reasons but may be worth a try.
truslack
PostPosted: 19:45 - 02 Sep 2010    Post subject: Reply with quote
How about walking it under power with the clutch if you struggle pushing it? Just watch out for it spitting the ramp out if it isn't attached at the top.
Dan79
PostPosted: 21:51 - 02 Sep 2010    Post subject: Reply with quote
Let me clarify - when I used to push the bike into shed I actually sat on it and use my legs to poke it along like someone on a velocipede, or a kid on a hobby horse - doorway is too narrow for one person to stand to side of bike and push it in that way - the handlebars are fairly high (it's an old Honda Magna V30).
Or is my technique completely wrong ? Bearing in mind doorway is so narrow I used to lean bike left and right to get handlebars through. Any suggestions welcome !
Dan79
PostPosted: 21:04 - 04 Sep 2010    Post subject: Reply with quote
Problem solved !
Thanks for the ideas.
truslack
PostPosted: 22:04 - 04 Sep 2010    Post subject: Reply with quote
Go on, what was the solution?
Dan79
PostPosted: 22:25 - 04 Sep 2010    Post subject: Reply with quote
Tried the method of pushing it in up the amp whilst off the bike, rather than my old mode of sitting astride it. Never realised quite how easy it was as I'd never tried it before, so I've learnt something new. Managed to rock the bars through by approaching at a slight angle!
Sorted
Casper
PostPosted: 00:11 - 05 Sep 2010    Post subject: Reply with quote
Quite sure with a 4" step you could have did the same driving it in. Tricky first few tome but you would get a nack.
The last post was made 15 years, 295 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.10 Sec - Server Load: 8.56 - MySQL Queries: 13 - Page Size: 69.95 Kb
