bike not running right
Marcg868
PostPosted: 20:52 - 04 Sep 2010    Post subject: bike not running right Reply with quote
basically my bike has lost power and feels like its running on one cylinder. it was running fine and i ran over a few bumps and it lost power and can.t do more than 20 mph. tried fiddling with the ht lead and it runs normal for a few mins then back to slow.
JACK, MISS YOU LOADS YOU LEGEND.
Casper
PostPosted: 00:06 - 05 Sep 2010    Post subject: Reply with quote
rob yarrr wrote:
the HT leads all connected securely,maybe there jumping off
One of mine lost the internal clip and made it vibrate of after a few miles. Sounds like your problem is only something came loose over the speed bumps.
Marcg868
PostPosted: 01:50 - 05 Sep 2010    Post subject: Reply with quote
i think that's the problem really. because i couldn't get my hand in to proper ram the ht lead on. if a clips come lose do i need a new ht lead? will whip the fairing off and fiddle with it.
Marcg868
PostPosted: 16:00 - 08 Oct 2010    Post subject: Reply with quote
Well i'm bringing this topic up, the problem is back, HT leads are fine, spark plugs look fine, apart from the front one had a bit of carbon deposit on it.
Checked the air filter which is fine.
It starts on the button but idles very badly and will not idle without the choke on now, still seems like its running on one cylinder also.
Any ideas?
Marcg868
PostPosted: 18:49 - 08 Oct 2010    Post subject: Reply with quote
rob yarrr wrote:
is the mixture screws turned to the spec ?
maybe a compression test.
what bike is it?
Haven't got a compression tester, but was running perfectly fine previously.
Mixture screws not been touched since i bought it.
One thing i have noticed, was when running if i whip the front HT lead off it dies straight away.
Bike is Hyosung GT125R
Marcg868
PostPosted: 20:02 - 08 Oct 2010    Post subject: Reply with quote
Yeah ts a twin, shall give it a try in the morning. Its weird as its come on suddenly. Was running beautifully before this.
The last post was made 15 years, 336 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.06 Sec - Server Load: 0.48 - MySQL Queries: 13 - Page Size: 66.17 Kb
