| Louise |
 Louise World Chat Champion
 Posted: 19:20 - 07 Sep 2010 Post subject: Dry batteries help...... |
Just a quickie
Mrs got a 2009 SV650 Gladius 3 weeks ago... 1,100 miles on the clock.
We both did a road trip around Cornwall for the week..
We get to a village, hour later bike is dead. Nothing.
Bumped it. few days later, I noticed her parking light on - turned bike over - nothing. Bumped again.
We take no, and make sure her P/lights arnt on.
Going home, make it to plymouth ferry... ignition on all for 5 mins. Try to leave ferry - bike dead. By this point im pretty peeved having to bump this in leathers.
Phone her dad to locate nearest Susuki garage for new batt.
3 miles down road.
get there, the guy tests bike, really nice -explains the batt is basically buggered, something isnt charging the bike back up to what its ment to be. the 'reg' could of gone ect ect.
Buy new batt and head home.
Next day take it to local dealer, explain whats happen..
He did tests and told us the bike is fine.......
Because its a dry' battery we must not use hazards, parking light as this will drain the 'memory' of the dry battery.
I thought this was a load of tosh - but he explained, that say mem off batt is 100%, use parking light, it will drain 30% (for eg) when we start the bike, it will remain at 30% lower then normal and wouldnt re-fully charge... same as usein hazzard, untill you have the optimax to fully re-charge the batt.
Hence the use of the optimax (which she has)
Now is this true??? If i needed an optimax each time i parked my bike, id be buggered as I live 6 floors up.
Just somehow cant get my head around this  |
| Clanger |
 Clanger Stirrer
 Posted: 19:30 - 07 Sep 2010 Post subject: |
I had to replace my battery twice in 9 years, it was a major pain. The batteries drain ridiculously quickly, especially if you have an alarm on the bike. I kept mine on constant trickle charge when parked up.
Also - when you buy them new, you have to let them sit and charge up overnight before fitting and using them!!! Not the best Suzuki choice...
Edit: Mine was an acid battery...? You would think that the Gladius would be the same battery as an sv. ____________________ Be who you are and say what you feel, because those who mind don't matter, and those who matter won't mind - Dr. Seuss
| Louise |
| Codemonkey |
 Codemonkey Crazy Courier
 Posted: 12:35 - 08 Sep 2010 Post subject: |
I think your local dealer is talking crap . Dry cells are a bit less rugged than wet ones in that they require a better regulated charger and don't recover well if discharged below about 1.75volts per cell (6 cells in your battery so about 10.5volts).
If the battery doesn't get discharged below the 1.75volts per cell lower limit, it should fully recover when it gets a charge.
If the battery does get deep discharged, then it may never recover.
To check if your battery is charging correctly, measure the voltage across it with the engine running, it should be somewhere around 13.5volts. If its much higher than this then it will damage the battery, much lower and it will never get fully charged. |
| chris-red |
| Louise |
The last post was made 15 years, 360 days ago. Instead of replying here, would creating a new thread be more useful? |
