NSR124R 2002 troubles - help needed.
Blunet600
PostPosted: 15:36 - 10 Sep 2010    Post subject: NSR124R 2002 troubles - help needed. Reply with quote
My sisters NSR isnt firing up. It sparks on ignition switch but wont turnover. She said she was riding it the other day when it went wrong, she said there was a lack of power and it backfired twice. When she went down a gear to get power there was none still so she went to first and it over revved then when she pulled off it stuttered again with lack of power. And when she got home it just died on her.
any ideas or suggestions?
I check 2 stroke oil and its fine, petrol fine, i gave the spark plug a clean ( which was covered in oil/petrol, was dark in colour) but still no luck. It started to idle for 5 seconds after the spark plug was cleaned but then stopped again.
any help is greatly appreciated.
cheers.
Honda - Power of Dreams - NSR 125R - Hornet 600
dardappa2004
PostPosted: 15:43 - 10 Sep 2010    Post subject: Reply with quote
Buy new sparks plugs, i has same symtoms on my old rs and changed them and ran fine afterwards Thumbs Up
Blunet600
PostPosted: 16:15 - 10 Sep 2010    Post subject: Reply with quote
It is a new spark plug, its only been in there a month or so. I will change it just to be safe and the air filter, cheers.
Any other suggestions?
Blunet600
PostPosted: 16:35 - 10 Sep 2010    Post subject: Reply with quote
Its never been rebuilt. Its done 12,000 miles and has been really well cared for. Good oils etc. Ive never cleaned the carbs so that could be one to try. How much is a rebuild? cheers. any other suggestions?
Digit
PostPosted: 17:16 - 10 Sep 2010    Post subject: Reply with quote
Check fuel tap and tank filter, you might find that the fuel is not getting through to the carb properly.
Roy.
Happy daze!
stirlinggaz
PostPosted: 18:33 - 10 Sep 2010    Post subject: Reply with quote
definately buy a NEW plug, its the 1st thing i do on my 2t's as they can go through them quickly...
i'd also be checking the compression & whip the head off, as it sounds like its needing at leat new rings.
cheers,
GAZ
alains
PostPosted: 10:11 - 11 Sep 2010    Post subject: Reply with quote
i agree about the plug but BR9ECS is bull shit , so buy BR9EIX
other thing , this bike need a maintenance schedule as :
- 7500 miles (or 12000 kms) de-coking plus rings change
- 15000 miles (or 24000 kms) de-coking plus piston-rings change
- 22000 miles (or 35000 kms) top-end change
each top-end openning needs new : base cylinder seal , cylinder head gasket , oil seal (valves shaft) , small end bearing , 2 clips ,piston pin (about £30)
piston is about £31 , rings £22 and a complete top-end £220
i recommand you schedule at least a rings change . but if you want to change the piston you need to dismount the barrel to see what letter is hammered under the exhaust port . see example : https://www.geneva-racing.ch/~alains/lettre.jpg (it's a E) . you must buy piston with the same letter or the same size . pistons size are A to E but if it's a E price is awful and you may fit a D
PS sizes are in the workshop manual
The last post was made 16 years, 10 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.09 Sec - Server Load: 1.35 - MySQL Queries: 13 - Page Size: 66.79 Kb
