Tyres are turning blue, should I change them?
Wyvern971
PostPosted: 09:49 - 13 Sep 2010    Post subject: Tyres are turning blue, should I change them? Reply with quote
After a couple of days out on track at Le Mans my tyres have a distinct blue colour on the shoulders front and rear.
There is a fair amount of tread left on them, but I'm slightly concerned.
Should I be thinking about changing them?
ETA:
https://wyvern971.f2s.com/Tyre.JPG
Ed Case
PostPosted: 10:34 - 13 Sep 2010    Post subject: Reply with quote
No it just shows they're working properly.
.Bishbash.
PostPosted: 12:57 - 13 Sep 2010    Post subject: Reply with quote
Not at all, it's the oils coming out of the tyre due to the heat cycles I believe.
There is tread left and I presume you have loads of grip left in the Racetecs?
Current bike - GSX-R1000 k8
Wyvern971
PostPosted: 13:01 - 13 Sep 2010    Post subject: Reply with quote
They were gripping fine when I last used them, the discolouration just put me off a bit.
I'll take them out for the next couple of TDs and change after that Smile
Paxovasa
PostPosted: 13:40 - 13 Sep 2010    Post subject: Reply with quote
As has been said, it is due to the heat cycle while riding. Nothing to worry about. Thumbs Up
MarkJ
PostPosted: 13:48 - 13 Sep 2010    Post subject: Reply with quote
I've had Supercorsas like that and they've been fine.
supZ
PostPosted: 13:58 - 13 Sep 2010    Post subject: Reply with quote
this
mine looked worse than that after a hot mallory trackday but i've done 2 trackdays since and they're fine. they scrub up straight away np
just gotta watch the heat cycles and when you start feeling some slippage or any cracking get em changed
CBR954RR - Daily toy
CBR600RR - Trackbike
daveuprite
PostPosted: 00:48 - 14 Sep 2010    Post subject: Reply with quote
Good example of where tyre warmers are actually quite good for trackdayers. Not for that 'critical first lap grip' nonsense, but because they allow you to put your tyres through just one heat cycle per day. This helps avoid the blueing and all the 'cold shear' effect of being thrashed from cold.
Go out on your first session, warm the tyres, then fit warmers as soon as you return to the pits. Whip them off just as the next session leaves the pit lane, and repeat this routine all day, including leaving the warmers on over lunch. Thus you get the tyres up to temperature once and then keep them that way = one heat cycle.
If you're spending £220 on a pair of decent track tyres, it's worth spinning them out as long as you can. After all it's not racing, it's a trackday. It's heat cycles that destroy trackday tyres, rarely loss of tread depth.
Alternatively fit road rubber that's designed to be ridden fairly hard from cold over and over again in the first place.
TUG
PostPosted: 19:14 - 15 Sep 2010    Post subject: Reply with quote
what honda is that?
Haz ER-5, innit!
supZ
PostPosted: 23:04 - 15 Sep 2010    Post subject: Reply with quote
thought id show you what mine looked like Very Happy
done 2 trackdays on em since and they're still going strong, although i've got a set of BT003RS's sitting in the garage waiting to go on the moment they go 'off'
https://farm5.static.flickr.com/4143/4764670679_dded80ee6a_z.jpg
https://farm5.static.flickr.com/4081/4764672415_4ce1254f2a_z.jpg
Wyvern971
PostPosted: 11:18 - 16 Sep 2010    Post subject: Reply with quote
TUG wrote:
what honda is that?
It's my (Formerly Andrew on heres') track bike
Honda VTR 1000 SP1
https://wyvern971.f2s.com/SP1.jpg
Photos from Le Mans
https://ianpainephotography.smugmug.com/Le-Mans-Trackdays-11-12-August/Novice-Group
https://trackdaydigitalimages.com/120810nbs/
jay81
PostPosted: 18:19 - 16 Sep 2010    Post subject: Reply with quote
I would check you tyre pressures as the blueing can be coursed by incorrect tyre pressure.
I had the cab driver drive me here backwards, he owes me ?27.50.
KTM 625 SMC
Wyvern971
PostPosted: 18:51 - 16 Sep 2010    Post subject: Reply with quote
Usually run 32 Front 30 Rear when it's warm
jay81
PostPosted: 18:04 - 17 Sep 2010    Post subject: Reply with quote
are checking them from cold or after they are warm?
KTM 625 SMC
Wyvern971
PostPosted: 20:38 - 17 Sep 2010    Post subject: Reply with quote
Sorry checking when cold, when warm was a reference to the weather
jay81
PostPosted: 09:25 - 19 Sep 2010    Post subject: Reply with quote
Depending how hard you ride (fast/ inter) i would drop a few psi.
I have always gone by the rule of aiming to get the tyres to run at about 34 psi when hot.
But of cause this is like most thing when it comes to set up, it is all about personal preference.
And as already said the lack of tyre warmers will not be helping.
KTM 625 SMC
The last post was made 16 years, 39 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 0.45 - MySQL Queries: 13 - Page Size: 85.96 Kb
