| chris1x |
 chris1x L Plate Warrior
| stevo as b4 |
 Posted: 22:33 - 13 Sep 2010 Post subject: |
They did have a reputation for wearing the bottom ends more quickly than the KMX125 having exactly the same bottom end. The main bearings were the common thing that used to wear out within 15-20'000m. The big end could also be worn, but the std 200 is quite low revving compared to a hot 125cc stroker, even so it's all based on 125cc sized bottom end components.
Your bike sounds like it has worn main or big end bearings, seeing as it still starts and as you say has some power. If it's a rumbley vibration through the footpegs and that it never goes away when revved, then id say it's a main bearing issue. If it knocks and sounds a bit clattery then it's most probably the big end bearing.
Either way it's a full engine strip down job to replace, and while your at it all the crank case seals and gaskets should be changed for new, and a new piston and rings fitted, as it's not worth running a worn piston and rings in a Nikasil bore due to the cost of repair if it lets go.
My 200 packed up when a peice of piston crown broke off and snapped the rings which then fell down into the crankcases. The bits of mashed piston went down the exhaust and i found them when i removed the expansion chamber and shook it upside down.
I can't be too specific about what parts are not available for the KMX200 engine now, but Kawasaki bikes from the late 80's-early 90's are notoriously harder to get new spares for than the other jap bikes, due to Kawasaki not supplying new spares for very long 15yrs? The last i heard was that new gearbox components and particualary the 2nd gear set was NLA new.
Pistons, rings, gaskets and bearings will always be available however, and decent pattern parts are just as good in most cases as Kwak Genuine parts. |
| Ariel Badger |
 Ariel Badger Super Spammer
 Posted: 22:42 - 13 Sep 2010 Post subject: |
Big End  ____________________ Bikers make great organ donors, get 115 on your licence today. |
| chris1x |
| chris1x |
| Frost |
 Frost World Chat Champion
| chris1x |
| stevo as b4 |
 Posted: 21:24 - 17 Sep 2010 Post subject: |
Sorry to hear that! I know you said that it's your main transport but KMX's are fun bikes especially in 200cc form!
I know that 200cc top ends fit onto a 125cc bottom end, and i see no reason why you can't do the reverse although i've never hear of anyone doing it? TBH i know it's and expense, but i think a decent full crank re-build and new main bearings and crank bearing seals would have sorted you out for another 20k! If you change pistons and rings together for new items every 10k, the cylinder bore can last over 40k easy if the engine is running correctly.
You might be able to find a secondhand 125 or 200 engine, but 200's are comparitively rare, and there are some internal engine/gearbox parts that a NLA new, so for finding an engine that has a fair chance of being a decent running unit, a 125 is possibly better. I've never brought a secondhand 2stroke engine and just thrown it into a bike, unless i knew where it had come from and it's mileage and history etc. On a 4stroke i've chanced my luck on a used motor without too much of a problem though.
It would be nice if you can keep your KMX and get it sorted and back on the road again, as they are getting a bit rare now and are cool bikes! As you say a decent condition running bike with an mot will fetch £600-850 these days, but they will probably go up a bit more over the next few years.
Im not really looking for another KMX at the moment, although when mine is done, i'll have enough bits except for a frame and forks to build a full rolling chassis and i've got lots of old bodywork, a tank, seat, wheels and a spare carb etc. If you really do want to get rid of it then let me know where your located and how much you want for it ok mate. |
| andy_g2k7 |
 andy_g2k7 Derestricted Danger
The last post was made 15 years, 174 days ago. Instead of replying here, would creating a new thread be more useful? |
