| montydon |
 montydon L Plate Warrior
| pinkyfloyd |
 pinkyfloyd Super Spammer
| montydon |
| locked |
 locked Could Be A Chat Bot
 Posted: 09:04 - 15 Sep 2010 Post subject: |
Hi montydon. I also have a CBF and the stock tyres are crap. I presume yours are also TVS tyres? You just need to take it easy in the wet, Pinky pretty much explained the dos and don'ts  ____________________ on the look out for my next bike....
Motorcycles are perfectly safe as long as you remember they're dangerous. |
| pinkyfloyd |
| c_dug |
 c_dug Super Spammer
 Posted: 10:58 - 15 Sep 2010 Post subject: |
A small blip of the throttle when changing down gears will help smooth it out a little. Wouldn't try this until you are confident with slowing down normally though.
When braking make sure to squeeze the lever rather than jam it on. As you apply more pressure, the front tyre gets pushed into the ground more by the weight transfer of the bike, this gives you more grip and you can brake harder. Obviously only up to a certain point, there isn't infinite grip available
When riding in the wet the braking should be closer to 50-50 than 75-25 front - back, it is a lot easier to control a rear wheel slide, remember skidding your bicycle as a kid? It's the same thing, just bigger, and it hurts more when you get it wrong Front wheel slides on the other hand tend to bugger off to one side and are pretty impossible to save once they are going. ____________________ I am a bellend, I am a man of constant sorrow, I am a gummy bear, I am a rock. |
| montydon |
| Beelzebob |
 Beelzebob Spanner Monkey
 Posted: 15:55 - 15 Sep 2010 Post subject: |
Monty - I can sympathise, I've recently started riding myself (got a YBR 125) and locked the front up a couple of times... not fun and really shit myself up. Luckily I haven't dropped it yet but, from what people say, (including the first thing my dad said to me when I said I'd got a bike ) it's only a matter of time.
I've heard the stock rubber is bad on the YBR as well... I just ride really gingerly when it's wet (which is often in Scotland).
The main thing, I think, is to learn from your mistakes - and obviously listen to the advice from these guys (which I too am grateful for!) - you'll be a little bit more prepared the next time it happens. You just need to jump back on and make sure there is a next time
Good luck mate ____________________ '09 YBR 125 -> '92 XJ600 S Diversion -> '99 Hornet 600
"Stronger than your average female lifeguard" |
| gmanxiii |
 gmanxiii World Chat Champion
| Paxovasa |
 Paxovasa World Chat Champion
 Posted: 17:32 - 15 Sep 2010 Post subject: |
When it is or has just rained watch out for diesel and avoid manhole covers (especially mid corner ones).
If you have to cross a wet manhole cover do not change speed or direction.
When the road is wet it is better to use 50/50 front / rear braking. when dry 75/25 front / rear braking (although I dont use the rear much in the dry).
As has been said, gently apply more pressure to the front brake rather than grabbing a handful.
I would aslo be changing the stock tyres for some better ones. As to which are best for your bike (Sorry but I don't know). ____________________ Suzuki GSF600 K3 (in the fastest colour, black). |
| FLV |
 FLV Trackday Trickster
| ajbsmirnoff |
 ajbsmirnoff World Chat Champion
 Posted: 18:38 - 15 Sep 2010 Post subject: |
Keep at it, its more fun commuting on a bike - says the man who wafted through the last 15 year of commuting in a comfy car.
You'll love filtering through traffic to be first at the lights - obviously once you've got other stuff firmly in your comfort zone.
Top marks for dusting yourself off and getting back on.  |
| drzsta |
 drzsta World Chat Champion
| Alex A |
 Alex A World Chat Champion
| Bloke |
 Bloke Crazy Courier
 Posted: 19:56 - 15 Sep 2010 Post subject: |
I'd avoid using either brake in a corner in the wet. not just the front
Drag the back and it locks, you'll lowside.
Slow down before you get to the corner, apply positive (read: keep it lightly applied not twist the nuts off of it) throttle as you go through the corner it keeps the weight from shifting forward in the turn placing the front under excess load and causing it to slip away from you. ____________________ 2008 VFR800 VTEC |
| neil. |
 neil. World Chat Champion
 Posted: 20:29 - 15 Sep 2010 Post subject: |
Have a good look through: https://125ccbikeclub.awardspace.co.uk/tyres.htm
Seems the stock CBF tyres aren't well regarded. This also seems common with other 125's, especially my '05 YBR, which had leathal factory fitted tyres. I replaced them with Pirelli City Demons which I personally haven't had problems with, but for the next 'level', I would go for Michelin Pilot Sporty's as replacements, which have had many fantastic accounts and reviews on 125's.
 ____________________ CBT February 2008 | A2 June 2008 | Yamaha YBR125 (written off) | Honda CBF125 (current) |
| montydon |
The last post was made 15 years, 350 days ago. Instead of replying here, would creating a new thread be more useful? |
