honda mtx kick start spring fault
zene
PostPosted: 19:54 - 18 Sep 2010    Post subject: honda mtx kick start spring fault Reply with quote
hello to every one, I'm new here
mi name is Juan i come from the canary islands
i just swapped mi Yamaha sr 125 for a Honda mtx 125 83
The kick start is not returning when i kick it i have taken the clutch side cover out to get it fixed but the spring is in the gearbox
does any one know the way to get to it do i need to split the engine apart, it seems like big job just to get to the spring is it there another way to get it done???
thank you for any help!!
regards
PostPosted: 20:17 - 18 Sep 2010    Post subject: Re: honda mtx kick start spring fault Reply with quote
regards
Hi Zene, welcome to the forum.
Now, I don't know about the MTX 125, but on my MZ ETZ301 you just needed to take the side cover off of the engine. The hard part was re-tensioning the spring again. The trick was to clamp the kick start shaft in a vice, fit the engine case over the spline and locate the spring in the hole in the cover, then rotate the cover around 1 and a third turns, and fit the kickstart lever.
I realise that might not apply to the MTX, but if the MTX *is* like that then it'll help you out a lot, cos I tore my hair out for ages trying to fit it back together.
zene
PostPosted: 19:53 - 19 Sep 2010    Post subject: honda mtx kick start spring fault Reply with quote
hello, Marjay
Thank you for the quick reply , it really seems like i will have to split the engine, i was looking in to it and i really don't see another way....
the engine came out easy enough but i don't know what way is best to get to the kick start mechanism with out too much work and what special tools i would need???
regards
The last post was made 15 years, 175 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.06 Sec - Server Load: 0.57 - MySQL Queries: 13 - Page Size: 37.26 Kb
