Failed mod 1, not fast enough
PostPosted: 21:35 - 18 Sep 2010    Post subject: Failed mod 1, not fast enough Reply with quote
I need help brothers! Embarassed
Turns out my bike is a bit of a whale for a 125 and I couldn't make it up past 49km/h no matter what I tried.
I'm seriously considering hiring a bike for the day (and having to stump up a large deposit) or selling the aforementioned whale and buying a CG125 to use for mod 1 + 2.
Are there any other options I can try to get my current bike up to speed in time?
Paxovasa
PostPosted: 21:57 - 18 Sep 2010    Post subject: Reply with quote
Were you a little cautious while taking the corner?
PostPosted: 22:07 - 18 Sep 2010    Post subject: Reply with quote
I don't think I was, at least consciously. I got the thing as far over as it's ever been and got out the bend at 22mph indicated. Pinned the throttle back as soon as I was pointing roughly in that direction.
Bike's always been heavy and slow though, and I'm now sure the 32mph it indicated in 2nd is not quite 32mph.
Either that or I'm just shit at this. Laughing
Paxovasa
PostPosted: 22:10 - 18 Sep 2010    Post subject: Reply with quote
Speedometers all read wrong, they all are over calibrated, when they say 35 you are probably doing 31/32 mph.
Jodie
PostPosted: 22:17 - 18 Sep 2010    Post subject: Reply with quote
It isn't easy on a 125, it took me a while to get the knack too.
What gear did you go through at as I did it in 2nd and just gave it all I could coming out of the bend.
PostPosted: 22:18 - 18 Sep 2010    Post subject: Reply with quote
Right... not a snowballs chance of that getting to a real 31mph in 2nd then.
Crying or Very sad
2nd through the bend, 2nd through the speed trap.
PostPosted: 22:40 - 18 Sep 2010    Post subject: Reply with quote
rob yarrr wrote:
unlucky,might aswell try again
its only £15
I've only got two holiday days left from work and Erith/Tonbridge/Gillingham don't have any weekend slots available... I'd really like to make sure I pass next time and use my last holiday morning for Module 2, and the rest of the day for hooning around town shopping for a new bike Laughing
PostPosted: 00:22 - 19 Sep 2010    Post subject: Reply with quote
Try 3rd gear, Hammer the bike in second round the bend and hit 3rd gear if second isnt fast enough.
good luck for next time
snowsurfer
PostPosted: 22:12 - 19 Sep 2010    Post subject: Re: Failed mod 1, not fast enough Reply with quote
your 125 should manage 32 in the space given, easy!! couple of questions, were you redline in 2nd? and were you sittin bolt upright or down on the tank?
if you were redlining then flick up to 3rd, no clutch required, will do it fine without, and if it wasnt redline in 2nd then get yourself tucked in on the tank and thet should get you there, remember that on the swerve test you dont touch the brakes till your by the swerve so dont worry about gettin on the brakes while tucked in, get it all done after the swerve and youll be dandy Thumbs Up
Past Bike: 07 Honda xr125l
Current Bike: 99 Yamaha Fazer 600
Glenben92
PostPosted: 00:52 - 20 Sep 2010    Post subject: Reply with quote
whack your tyre pressures up as well, don't brim the tank, make sure the brakes aren't dragging at all, maybe clean and gap the spark plug (makes a surprising difference) and try 3rd maybe through the bend? clutchless shift seems a good idea too, worth a try. I managed 53 in 2nd gear for the swerve and 52 changing to 3rd for the E-stop. i found that the best response was to take a racing line through the bend and try to get on the throttle as soon as possible.. no not then, sooner. good luck.
57 Huoniao HN125-8 - Smile, 97 Kawasaki GPZ500S - Very Happy
99 Yamaha FZS 600 - Wink
Mod 2 Passed - 01/10/2010
Bloke
PostPosted: 06:01 - 20 Sep 2010    Post subject: Reply with quote
Stay out wide through the bend, will give you a few feet more to get that throttle pinned back on the straight
2008 VFR800 VTEC
PostPosted: 13:16 - 20 Sep 2010    Post subject: Re: Failed mod 1, not fast enough Reply with quote
The bike has no rev counter, all I can tell you it was screaming it's little lungs out in 2nd, and I was tucked in.
I'm trying to nab a CG to get to know the mechanical side of bikes, so when I find a CG I may just use that instead Laughing
The last post was made 15 years, 349 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.09 Sec - Server Load: 0.52 - MySQL Queries: 13 - Page Size: 79.59 Kb
