| reggie |
 reggie Spanner Monkey
 Posted: 23:40 - 20 Sep 2010 Post subject: river crossing fail!!! gas gas 250s dont float |
| mrjonesybop |
 mrjonesybop Derestricted Danger
 Posted: 14:11 - 21 Sep 2010 Post subject: |
DAMN!!
Does she still run? Or is she ruined? |
| Paxovasa |
 Paxovasa World Chat Champion
 Posted: 14:18 - 21 Sep 2010 Post subject: |
Should have got a diesel bike  ____________________ Suzuki GSF600 K3 (in the fastest colour, black). |
| G |
 G The Voice of Reason
| reggie |
| pepperami |
 pepperami Super Spammer
| 2wheelsteve |
 2wheelsteve Spanner Monkey
 Posted: 20:56 - 21 Sep 2010 Post subject: |
You'll probably have to clean the carps haha  ____________________ Ride Safe |
| kingsknight |
 kingsknight World Chat Champion
| reggie |
| woodyeee |
 woodyeee Nova Slayer
 Posted: 21:18 - 21 Sep 2010 Post subject: |
I guess thats the water cooled model  |
| flumpy7 |
 flumpy7 Could Be A Chat Bot
| 2wheelsteve |
| Ste |
 Ste Not Work Safe
| Teflon-Mike |
| 2wheelsteve |
 Posted: 22:37 - 21 Sep 2010 Post subject: |
| G |
| Ste |
 Ste Not Work Safe
| Ariel Badger |
 Ariel Badger Super Spammer
| reggie |
| Teflon-Mike |
 Posted: 01:12 - 22 Sep 2010 Post subject: |
| reggie wrote: | only thing i did was put abit more 2 stroke in the tank because all that water must wash some of it out |
If it went on its side, it may be worth doing a full fluids change on the motor. Certainly DONT use reserve until you have drained the tank through. Water is heavier than petrol, it sinks to the bottom; its an old chestnut, bike gets wet, either through a dunking, heavy rain, or over enthusiastic washing..... bike fires up after, you dont think anything of it, then some while later, you eventually switch to res, and after a short while, if not straight away, bike starts coughing and stuttering like a bastard, and you think '"That's strange, got further on reserve than THIS last time" get to a filling station quick, top up the tank, switch to main, and its not until LONG after the initial wetting you discover that half the tanks full of water, gear-box oil turned to mayo, and in really bad cases the fork sliders!
Been a bit paranoid about damp bikes since I killed a classic Ducati Street-Scrambler, every-one said wouldn't work on the dirt....
https://www.motoannisettanta.com/images/Ducati-Scrambler-350--1973-.jpgso after a very extensive and expensive restoration, I took it mud-plugging...... curiousely it wasn't BAD on the rough stuff.... rather short of ground clearance & suspension travel, motor was a bit harsh, and the geometry rather frisky (lots of rear wheel weight bias), but ridden worse...... so took it to the petrol station on the way back to wash of the evidence...... sorry, preserve the finish!
Drowned the bludy thing... had to push it mile and a half UP FUCKING HILL! (isn't it always the way!) back home....... stuck a multi-meter on the battery... got hardly any volts..... decided I must have shorted it....... so left the seat up, hooked up the battery charger, went & made a cup of tea...... twenty five minutes later...... smoke pouring out the shed...... Uncle (who owned & restored it, and when he said I could ride it I DONT think had images of tackling green-lanes on it.... more cruising up & down the high street pretending to be the Fonze!) waving arms around screaming, gets the door open, grabs a fire extinguisher, finds no flames but battery acid bubbling out all over his Ducati paintwork and fumes coming of the wiring.....
He just looked at me, in that pitiful manner..... "You do KNOW old bikes had SIX volt electrics dont you?" he said..... walking away, counting up the hours of work and cost of parts RUINED!
Er..... anecdotes asside, dont be too cavalier over a drowned bike. Had plenty of experience of them, and Land-Rovers coming a cropper after wading. Find it rather amusing, driving V8 range-rovers people claim dont like water, wading them into puddles and rivers, without them missing a beat, where supposedly imperviouse diesels come to grief!
Its a myth that diesels 'do water', and you cant drown one. You can, and I have! Might not have an ignition system to short out, but they still have electrics. Killed the alternator on my old SIII Landy wading with a little too much vigour! But the one that gets far more people, is water getting in the fuel system, normally through the fuet cap! Seen some very well wading prepared landies, ALL the mods, snorkle, high level breather kits, wading plugs ALL teh stuff out the magazines..... let down by a 99p seal on the fual cap!
Bikes aren't much different, & though its a tad more difficult to 'hydraulic' a two-smoke, they can still suck water. On the 'old' iron I trialed with points ignition, sealing the mag cover was the critical job. Not so seriouse on modern contactorless ignition bikes, but still. Water CAN and WILL get places its unhelpful in the loom, and even if it doesn't short stuff out straight away, long term, often promotes corrosion on contacts and stuff that will chuck up random faults later.
So its ALWAYS worth doing some precautionary after a good dunking. As said, fluids can get contaminated, & are worth a look. Probably benefit from an oil change anyway. As for the rest of it, suspension bushes, head-races, wiring. Bit of time going over it, lubing stuff up, spraying stuff with WD40, even if there ISN'T any water damage or ingress, good thing to do anyway. ____________________ My Webby'Tef's-tQ, loads of stuff about my bikes, my Land-Rovers, and the stuff I do with them!
| Mr Hammers |
 Mr Hammers World Chat Champion
The last post was made 16 years, 41 days ago. Instead of replying here, would creating a new thread be more useful? |
