 Posted: 22:51 - 21 Sep 2010 Post subject: VFR750 dash rewire and LED conversion |
The flexi PCB that provides all the wiring to the dash on my VFR was suffering badly from corroded tracks causing all manner of weird lighting faults.
I finally decided I'd had enough and set about rewiring it. I opted for traditional wires and terminals and to replace the terminal blocks on the loom with more conventional ones.
I also decided to replace all the bulbs with LEDs. I got a bag of 20x10mm LEDs with the correct resistor fitted for running on 12V, complete with flying wires and bezels for them to go in for a tenner on ebay.
So I wired it all up, pretty much copying what was on the PCB by doing one track at a time (two blocks of 10 connections which I labelled 1 to 10 and A to J to make attaching them to the loom easier).
The only thing I really needed to referr to the wiring diagram for was the polarity of the bulbs because the LEDs only work one way round.
Landed up with something of a birds nest and I think if I was doing it again I'd start at one side and work to the other, lacing the wires into a bundle as I went so i landed up with a single "loom" running across the back of the clocks with the terninals on the end.
All that said, it all worked first time with only one bad soldered joint. The LEDs turned out to be a bit too bright so I painted over the top half of them with silver enamel paint.
The bezels were simple to fit, just had to open out the original bulb holes a touch with a step drill, clicked them in then secured them with a dab of hot glue. The LEDs then push fit into the bezels
The wires from the LEDs are quite delicate so I wrapped any coming out to a terminal block in bundles then bonded the wrapping to the terminal blocks to prevent straining them.
To finish off, I cut out a rigid plastic sheet to cover over the more delicate parts of the birds-nest so all you can see from the back is the wrapped terminal bundles sticking out of a plastic sheet.
I'm quite pleased with how it went really. I reckon the whole job cost about £30.
https://i48.photobucket.com/albums/f216/stinkwheel/clockwire.png
https://i48.photobucket.com/albums/f216/stinkwheel/DSCN0987.png ____________________ “Rule one: Always stick around for one more drink. That's when things happen. That's when you find out everything you want to know.”
| colin1 |
 colin1 Captain Safety
| chillyman0 |
 chillyman0 Nearly there...
 Posted: 15:38 - 22 Sep 2010 Post subject: |
| chillyman0 wrote: | Nice idea! I've just had a few bulbs go in my dash go, no idea why (clock and left hand side of the speedo) without having to look through the clymer manual, how hard is it to get to the back of the dash?
cheers |
It's a complete and utter pain in the arse to get at.
Most likely explanation is that you have some blown bulbs but it could be a corroded PCB track too.
Take off the fairing side panels, front panel and mirrors. Disconnect the front flashers and headlight, undo the top fairing "mickey mouse ears", screen and remove the top fairing.
The dash is then held on by three nuts onto the subframe. It has two connectors.
You can also get LED wedge bulbs that fit into the original bulb holders which might be easier in your circumstances. I just did this because the PCB is totally screwed.
NB. If you do take the dash off, check the speedo and tacho needles are on the correct side of their stop-pins before you reassemble everything. Don't ask me how I know!
@ Colin. I did consider this, but then thought that corroding PCB tracks caused the original problem. Wires should be somewhat more resistant to this. It would still need 20 wires coming out of it in any case. ____________________ “Rule one: Always stick around for one more drink. That's when things happen. That's when you find out everything you want to know.”
 Posted: 19:00 - 22 Sep 2010 Post subject: |
The last post was made 16 years, 25 days ago. Instead of replying here, would creating a new thread be more useful? |
