KTM 520 EXC run in
MaybeGuy
PostPosted: 22:25 - 22 Sep 2010    Post subject: KTM 520 EXC run in Reply with quote
since mine ate its carb slide earlier this year, i figured i'd give it an overhaul as required.
no damage was caused by the shard sucked in, so cleaned it out, and replaced the rings as the old ones were approaching out of specness.
question being: what's the run in on something like this? most rebuilds i've done have been rebores with completely new components rather than a partial like this one.
i'm thinking a few miles of taking it easy then treat as normal? or am i missing something
Welshd1k
PostPosted: 22:35 - 22 Sep 2010    Post subject: Reply with quote
i always start as i intend to go on . obviously alittle calm for the first few heat cycles . then rag teh arse off it
MaybeGuy
PostPosted: 22:37 - 22 Sep 2010    Post subject: Reply with quote
what do heat cycles have to do with rings?
Welshd1k
PostPosted: 22:40 - 22 Sep 2010    Post subject: Reply with quote
they expand and shrink give them a chance to bed in properly.
how i did my 3 of my rd350's my ns125 not sure if its the same for a 4 smoker. but i always just run it a few times let it heat up and cool so the rings are settled then ragg the arse out of it
MaybeGuy
PostPosted: 22:47 - 22 Sep 2010    Post subject: Reply with quote
hmm. whatever works for you i guess. i personally think thats a crap way to run something in, but then again theres no proven method.
ill take it safe and take it easy for a tank full first as if it was a whole new piston/bore.
Welshd1k
PostPosted: 22:51 - 22 Sep 2010    Post subject: Reply with quote
ann thought was just the ring you changed.
id say take ti easy for a few hundred then screw it Razz .
saying that when i rode my ns slowly the ring died so the garrage gave me a new ring piston and barrel and i just shagged the arse off it from the day i picked it up and she did 16k on that ring and piston Very Happy
MaybeGuy
PostPosted: 22:58 - 22 Sep 2010    Post subject: Reply with quote
read again
Welshd1k
PostPosted: 23:03 - 22 Sep 2010    Post subject: Reply with quote
yeah with rings its just let them settle in and then go on as normal wouldnt say it takes that long but the ktm's are quite tunned?
SamJL
PostPosted: 23:16 - 22 Sep 2010    Post subject: Reply with quote
Different people will say different way's to run a bike in.
I went off this guide here, which basically says ride it like you stole it.
I know it's not a full build, but this guide does talk about getting rings to seat properly in some detail.
https://www.mototuneusa.com/break_in_secrets.htm
2009 CBR1000RR
2004 KTM 200SX
2004 KTM 65SX Very Happy
evoboy
PostPosted: 23:23 - 22 Sep 2010    Post subject: Reply with quote
Id just get the motor upto temp riding around then use all the rev range without bouncing it off the limiter, just dont put massive load on the engine. ( i.e high gear, low revs, then giving it the beans)
APT Motorcycles
The last post was made 16 years, 23 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 1.04 - MySQL Queries: 13 - Page Size: 64.59 Kb
