| monkeyman |
 monkeyman Scooby Slapper
| alains |
 alains World Chat Champion
| mr jamez |
 mr jamez World Chat Champion
| monkeyman |
| monkeyman |
| mr jamez |
 Posted: 11:10 - 30 Jul 2004 Post subject: |
Do a compression test first, it should be around 142PSI. I just did a rebuild, including a new barrel, you need to strip it down first to see what is damaged. The barrel will probably be OK, but you may want to replace it anyway. It is cheaper to buy a new barrel than it is to get it replated.
I dropped the engine out of the bike to do the rebuild, makes it so much easier. Barrel and piston is £85, piston rings are £22 and cylinder heads are about £20 (if you need one) then of course the base gasket, head gasket, small end bearing, gudgeon pin, circlips, RC valve dust seal, exhaust gasket. I also bought new cyclinder head/exhaust port studs and nuts to save the bother of getting the old ones out. The rebuild cost me over £150, but I had extra parts on top so it wont be as much for you, I bought all the parts from david silver spares.
It took me 2 hours to fit the new parts, the only tricky part was fitting the rings on the piston. As for a service manual, they pop up on ebay every now and again as having it in front of you helps, I think Ste is hosting the manual but I don't know if he wants that to be common knowledge  |
| monkeyman |
| mr jamez |
The last post was made 22 years, 72 days ago. Instead of replying here, would creating a new thread be more useful? |
