| XJ600N |
 XJ600N L Plate Warrior
 Posted: 17:42 - 25 Sep 2010 Post subject: Engine noise!! |
Hi I bought a XJ600N last week but found that there is a noise coming from the engine. I am not sure if this is Piston slap or valve noise. I am very interested in my bikes engine and would like to sort the problem myself but I don't have a lot of knowledge about this motor since this is my first big bike.
The bike runs fine without any issues and the gears is smooth with no slips and no smoke coming from the motor either. The noise is loud when the bike idels but once the engine gets running the noise disappears. I did find that the oil level were very low when I collected the bike. I have since toped it up with oil but the noise is still there. Will this harm the bike if I keep using it like this or would it be ok until I can manage to get it sorted?  |
| Frost |
 Frost World Chat Champion
| Casper |
 Casper World Chat Champion
| Frost |
| Vincent |
 Vincent Banned
| Robby |
 Robby Dirty Old Man
| Walloper |
 Walloper Super Spammer
 Posted: 06:07 - 27 Sep 2010 Post subject: |
I'll defy anyone to identify what is the cause of noise using screwdrevers or stethescopes or divining rods et al.
Unless you have prior knowledge of what you should be hearing from an engine under normal conditions and or an engine sufferering the ravages of time/abusive operation it may only lead to confusion.
It may give an indication of where but even then the noise of one part can be amplified in a completely different area.
On larger machines this will work on small motorbike engines it's normally worthless.
As suggested above, elimiate the cause/s of noise if possible. Pulling in the clutch.
In gear slowly let the clutch out to biting point.
In gear running on centre/paddock stand.
Think of ways to test before wheeling it into theatre.
Open up the oil filter for a shoofti. Look for evidence of failure.
If it's critical then there will be debris from active problems.
If it just wear then there will not be much to see.
It may mean opening up the engine to measure and evaluate.
If something is broken you will find it then.
Unless you know someone who has 'intimate knowledge of the beast of course.
I would expect piston slap noise to be accompanied by lack of power, poor cold starting and really bad oil consumption.
I wouldn't worry too.... much about the low oil. Unless you had to top up by about 50%. A lot of folk never bother to check oil regulary and so may need a top up of 20% when they do.
I have a pre-Crimean War Massy Ferguson in my bike which uses more oil than a chipvan but I know this and check it regulary anyway. ____________________ W-ireless A-rtificial L-ifeform L-imited to O-bservation P-eacekeeping and E-fficient R-epair |
| 0l0dom0l0 |
 0l0dom0l0 World Chat Champion
| Vincent |
 Vincent Banned
The last post was made 16 years, 36 days ago. Instead of replying here, would creating a new thread be more useful? |
