'99 KTM exc 300- mental fuel consumption!
multijoy
PostPosted: 18:42 - 26 Sep 2010    Post subject: '99 KTM exc 300- mental fuel consumption! Reply with quote
I've posted about this bike before (bit of a hard starting issue), which may or may not be linked.
Anyway, today we did the bocketts run as far as we could before the 300 ran out of fuel. Fine, no problem. Off to petrol station, fuel can, back, time to head home.
Until it ran out of fuel again. Back of the fag packet sums suggest that it's doing somewhere in the region of 20mpg, which really doesn't seem right!
Temperamental start aside, the bike seems to be running fine. It's on premix, 50:1, give or take a whisker. Could probably do with a new spark plug, air filter cleaned and oiled yesterday.
Is 20mpg about right for a 300 2t, or is this a symptom of something else? It does also have a tendency to piss fuel out of the carbs when leant to a side (not enough to account for the current consumption!) which does suggest that there is something not quite right there (although I have been led to believe that this is an 'endearing' feature of these machines).
Any thoughts?
Cheers,
Rich
PostPosted: 18:45 - 26 Sep 2010    Post subject: Reply with quote
Stop pinning it everywhere?
Adamantis
PostPosted: 19:03 - 26 Sep 2010    Post subject: Reply with quote
It doesn't get pinned everywhere - far from it! Pootled the nationals at about 45 in top gear, flipping the revs around so it doesn't sit in one place for too long.
Just before it runs out of fuel it makes a distinctive noise - I can only describe it as the bottom note vanishes, and it just makes the high "scream" noise?
Laura
Rides: '91 CG125 (Sold), '00 CB500S (Sold), '97 Thundercat (Sold), '99 KTM EXC 300 (SOLD), '99 RSV Mille (stolen. Thieving SCUM!!!), '94 DR350 (sold), '10 Vstrom 650 (hated it so much I gave up riding), now on the OH's CBF1000 until I can afford another Mille...
Frost
PostPosted: 19:35 - 26 Sep 2010    Post subject: Reply with quote
Bigger cylinders tend to give worst economy, so i wouldn't expect greatness form a 300 2t! On the other hand though 20mpg is very shit. Apparently the bike has a 2.25 gallon tank, so you're getting 45 miles per tank? Gearing is an issue too with off road bikes as the gears tend to be very short and closely spaced. The hard starting could be related to it running rich and consuming more fuel as a result. An easy way to test this is to try starting it when hot, and first thing on a cold morning. If it starts as well or better in the cold it's running rich.
Quote Me Happy
PostPosted: 20:10 - 26 Sep 2010    Post subject: Reply with quote
45 miles from a tank isn't too bad. I think I get about 55 from my Gasser and I think the tanks are the same size.
No fuel coming from the carb overflow?
multijoy
PostPosted: 22:27 - 26 Sep 2010    Post subject: Reply with quote
Only when it's tipped to the left!
I wonder if the idle is upped a whisker it'll avoid having to keep the revs on when it isn't needed, which could make a bit of difference.
Good to know it's in the right ball park, though. It's only the 15 miles to/from the lanes you really notice it the low mileage. Might be worth a bigger, or at least transparent, tank!
boundy
PostPosted: 22:41 - 26 Sep 2010    Post subject: Reply with quote
I was only getting about 25 on my GasGas ec300, having the carb correctly jetted, fresh spark plug and air filter should make a notciable differance
stevo as b4
PostPosted: 23:10 - 26 Sep 2010    Post subject: Reply with quote
I wouldn't expect much mpg from a big 300cc+ 2stroke engine IMO. My old KMX200 was used mainly on the road, and it would never do more than 40mpg at the most. I would think a 300 or bigger would be down to 25mpg easily really.
PostPosted: 01:19 - 27 Sep 2010    Post subject: Re: '99 KTM exc 300- mental fuel consumption! Reply with quote
Definityely worth doing general maitenance and cleaning out the carb too, while you're at it (should be very easy to do). My 200 went from being a bit bitchy starting to very easy/regular!
There's plenty of options for a bit bigger tanks. The 4 strokes do do better on fuel, but then do worse on maitenance and make a horrible mess when it all goes wrong!
PostPosted: 01:31 - 27 Sep 2010    Post subject: Reply with quote
My dads KH350 does about 25mpg. My old 350 powervalve could easily drop below 20mpg if ridden enthusiastically.
So, 25mpg from a performance 300cc 2-stroke engine isn't outwith the realms of possability.
multijoy
PostPosted: 09:17 - 27 Sep 2010    Post subject: Reply with quote
Might be time to work out if a small van will be cheaper than the run from home to the lanes!
That or a tow rope...
garyd
PostPosted: 16:33 - 27 Sep 2010    Post subject: Reply with quote
a small van would be even cheaper on the lanes Laughing
CRF230 all you need
Blue_SV650S
PostPosted: 22:36 - 28 Sep 2010    Post subject: Reply with quote
My 250 does ~25mpg so, no, not surprised you are getting ~20mpg!
It is ridiculous and means you need to plan regular fill-ups/a route with petrol stations that are no more than 40(ish)miles apart!! Shocked
The last post was made 15 years, 344 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 0.56 - MySQL Queries: 13 - Page Size: 76.18 Kb
