bike locks when in motion, able to change gears with clutch
abbey8k
PostPosted: 00:50 - 27 Sep 2010    Post subject: bike locks when in motion, able to change gears with clutch Reply with quote
today on my way home my xt 125-16 which is a copy of a Honda cg 125 died whilest in gear.
after pulling over I tried to kick start the bike
(because the electric start wouldn't work)
only to find that i couldnt and that it was solid and would not kick down.
i tried to get it going by bumping it down a hill but the second i put the bike into any gear (i tried them all)
the back wheel would instantly lock.
anybody got a rough idea without gong into to much detail on what the problem could be.
am i right on thinking that its a gearbox problem maybe it could be the crankshaft
thanks chris
PostPosted: 01:18 - 27 Sep 2010    Post subject: Reply with quote
Yes. sounds like a seized engine. The kickstart is attached to the engine. If the kickstart is solid in neutral, it's the engine rather than the gearbox.
Could be one of a variety or causes, all of which are going to require a fair bit of repairing (or may be beyond economic repair compared to the price of a second hand engine that runs).
First off, drain the oil through an old pair of tights. See if there was enough oil in it and if any big lumps of engine come out with the oil. Once the oil has settled, look for a sheen of metallic particles on the surface
Next I'd be taking off the engine side cover and trying to turn the crank directly with a spanner. If it turns, there may be something up with the starter mechanism
If it's still locked solid, remove the rocker cover and inspect the valvegear and rocker assembly (looking for a dropped valve or anything broken/detached such as a snapped rocker, a bent pushrod, a loose nut jammed under a rocker and so-on).
Those parts are simple and quick. If you find nothing and it's still locked solid, you'll need to take the head off and see if the piston has hit any valves (this would usually be pretty obvious due to severe mangling of said parts).
If that checks out ok, try turning the crank again anyway. If it still doesn't turn, whip off the barrel and check to see if there is any scoring on the barrel or piston indicating a heat-seizure (where the piston had expanded too far and gripped the inside of the barrel). It is possible the barrel wont come off if the piston is seized in it. A good soaking in hot oil followed by hammering a block of wood on top of it will sometimes free it off.
If the barrel looks ok and the crank still wont turn, the crank is screwed. Most likely main bearings or big-end.
Could be a combination of several of those things.
A 4-stroke engine seizure is usually catastrophic in nature and trashes several componants in a fraction of a second so don't get your hopes up and be pleasantly surprised if it's something simple like a thrown pushrod.
You tend to find something along the lines of this:
https://i48.photobucket.com/albums/f216/stinkwheel/305/Image074.jpg
https://i48.photobucket.com/albums/f216/stinkwheel/305/Image076.jpg
abbey8k
PostPosted: 11:22 - 28 Sep 2010    Post subject: Reply with quote
it does have oil in the bike. the level is full.
i've got my old boy picking the engine up today for a closer inspection as he is a mechanic, so i will keep you all posted.
thanks for the help
thanks for the info stinkwheel, lets hope its not as surveyor as that Sad
The last post was made 15 years, 352 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.09 Sec - Server Load: 1.33 - MySQL Queries: 13 - Page Size: 42.74 Kb
