NSR 125 Problems
MartinMyhre
PostPosted: 10:51 - 27 Sep 2010    Post subject: NSR 125 Problems Reply with quote
Hi,
I have a 1992 Honda NSR 125, alcast frame, serial number starting with "HI-JC20".
I checked the exhaust for restrictions, but didn't find any, also checked the intake plate, nothing there either.
The bike only seems to hit 75 mph, with a pretty slow 0-60.
Any ideas on what's wrong with this bike?
andy_g2k7
PostPosted: 11:48 - 27 Sep 2010    Post subject: Reply with quote
have you tried cleaning the carb or de-coaking the exhaust things like that. i no there small things but they can make a difference as i found out on my ns125r
nsr's rule
The Artist
PostPosted: 11:49 - 27 Sep 2010    Post subject: Reply with quote
It's a 125...
andy_g2k7
PostPosted: 11:58 - 27 Sep 2010    Post subject: Reply with quote
nsr's rule
Hobes
PostPosted: 12:04 - 27 Sep 2010    Post subject: Reply with quote
The Artist wrote:
It's a 125...
+1
From what you've written in your post this sounds entirely normal to me.
Current: Suzuki DRZ400sm (07) https://fbc.spruz.com
XBL: Matt Hoban
PSN: MattHoban
mysterious_rider
PostPosted: 12:25 - 27 Sep 2010    Post subject: Reply with quote
The Artist wrote:
It's a 125...
Wrong.
My ns125r is the older version of this bike, basically the engine is about 10hp LESS than his nsr model, yet mine will get to 85mph. Wink
Start with the exhaust, decoke it.
Check the air intake, make sure there's no blockages. It's even possible the rings are worn? Not entirely sure to be honest.
alains
PostPosted: 20:02 - 27 Sep 2010    Post subject: Reply with quote
check :
1) the compression (less than 125 PSI is bad and in this case a top end repair is necessary)
2) check your valves sequence of working (download my file https://www.geneva-racing.ch/~alains/NSRtips.doc
if your servo-motor doesnt move write me , i will guide you to investigate the bug
MartinMyhre
PostPosted: 20:19 - 01 Oct 2010    Post subject: Reply with quote
alains wrote:
check :
Haven't checked the compression yet, but i doubt there's anything wrong with it because it had a top end repair 4 years ago, and it has only gone about 500 km since that.
Checked the valves, they close at 2000 rpm, and opens at about 7000 rpm.
Also, the exhaust is completely clean.
alains
PostPosted: 21:09 - 01 Oct 2010    Post subject: Reply with quote
MESURE COMPRESSION !!!!!
MartinMyhre
PostPosted: 22:12 - 01 Oct 2010    Post subject: Reply with quote
Alright, will do it on monday Smile
MartinMyhre
PostPosted: 19:47 - 05 Oct 2010    Post subject: Reply with quote
the compression was at 120 psi, is that too low?
alains
PostPosted: 19:55 - 05 Oct 2010    Post subject: Reply with quote
book says : under 125 PSI is not good but not so worse
probably rings , which mileage and how long since last top-end maintenance (if you know)
MartinMyhre
PostPosted: 20:10 - 05 Oct 2010    Post subject: Reply with quote
The mileage is about 45 000 km, and the bike had a top end rebuild 4 years ago, but it's barely been ridden since, somewhere between 500 and 1000km.
alains
PostPosted: 20:39 - 05 Oct 2010    Post subject: Reply with quote
if you want to keep it more than one year , you should re-buid top-end which is around £220 . if not do nothing because the investment dont worth the benefit
MartinMyhre
PostPosted: 20:51 - 05 Oct 2010    Post subject: Reply with quote
Would i get any significant performance gains if i get i rebuilt?
The way it runs now is like its restricted, even though its not.
My cdi is a CI 589 C, and the rc controller is tv-78.
alains
PostPosted: 21:08 - 05 Oct 2010    Post subject: Reply with quote
i see !!!! your CDI is a french bull shit
find a CI572 but still , for my point of view, needs something to do in the top-end
just had a look on ebay and no luck , but in uk i know some breakers work together , find the site and ask (no more than £35)
MartinMyhre
PostPosted: 21:18 - 05 Oct 2010    Post subject: Reply with quote
Is it possible to cut a "bridge" on the ci589, like on the ci639?
Also the bike revs fine all the way up to 12000 rpm, so what would the ci572 do different?
alains
PostPosted: 08:33 - 06 Oct 2010    Post subject: Reply with quote
cuting the shunt on any CDI doesnt make any difference
MartinMyhre
PostPosted: 10:21 - 06 Oct 2010    Post subject: Reply with quote
So i should change the cdi for a ci572, and change piston rings? or a top end rebuild?
alains
PostPosted: 19:42 - 06 Oct 2010    Post subject: Reply with quote
it's only a question of purse
The last post was made 15 years, 353 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.08 Sec - Server Load: 0.76 - MySQL Queries: 13 - Page Size: 100.47 Kb
