Buying a Royal Enfield 500 & total refit, Noob help.
spetom
PostPosted: 21:24 - 27 Sep 2010    Post subject: Buying a Royal Enfield 500 & total refit, Noob help. Reply with quote
Warning Long Post ahead!
Ok I've decided to get a Royal Enfield 500 Bullet from the 90s. So no electric start or EFI. I don't mind the neutral gear feature but I wouldn't mind a 5 speed gear box if it makes any difference (don't know if these go hand in hand)? Would prefer a right hand gear box but not necessary can be left. I'm quite happy to keep the points don't need electronic ignition.
I'm looking to get a used one with the least miles on the clock possible and then totally redo it, only trouble is I'm a mechanical noob. But I would eventually like to learn this bike back to front.
I've been reading forums on what people have been writing. Here is what I'd like to do to it:
1) To put as much horsepower into the 500 as possible without spending thousands on kits etc. and without it hurting the engine.
2) Make it cruise easy at 60mph on the motorway (I understand I have to do changes such as change the amount of teeth on the sprocket as well as other things)
2) To fix up as much of the loss of build quality and weaknesses that the motorcycle comes with from India, iron out the crap and breath new quality and solidity into the bike. e.g high flow oil pumps
3) To totally repaint it so instead of the glossy black it always is either a matt black or a matt silver. So that it looks just like this:
https://www.royal-enfield.net/old_bullets/1940-1959/1951_350_Bullet.jpg
or this
https://www.musketvtwin.com/uploads/2/2/4/7/2247083/4201653.jpg
4) Importantly, I've noticed many of the rear mud guards on the new Enfields are not inline with the rear tyres (as in the do not follow the same curve) I've noticed this on many of the Indian models and to the discerning eye this is not nice! I would like the rear mudguard to be nicely in line with the rear tyre follow the curve. So the images above are exactly what I'm looking for.
5) To make the bike idle and sound like this, I understand I must change the exhaust?
https://www.youtube.com/watch?v=fJN9HI52mYU
6) Put some solid grippy tyres capable of some cornering at least.
7) Weather proof all the chrome (There will not be much left after repaint) and the whole bike.
I am not afraid of the wrench and I like to get stuck it, but it is often my lack of mechanical knowledge that holds me back and really I don't know what I'm doing I literally learn as I go along.
(I have basic maintenance knowledge, so far I have reset valves (with thou measurements!), changed clutch + brake cables, changed brake shoes, fixed a rear brake light with a stop breaklight switch, replaced a whole headlight (reconnecting all the cables etc.), repainted a rusty part of a bike (good but not a pristine paint), rebuilt forks changing seals and pouring the correct fork seal oil etc. with some other basics I forget.)
I have no idea where to start and have many questions such as:
-How is it some old engine blocks on the Enfield still shine bright and others seem to lose their luster regardless of mileage. I've seen an engine with 20,000 look pristine and one with 10,000 look battered. Are they coated in something heat resistant and protective?
This is some good information I've already picked up from the forums:
Suitor_Stu wrote:
1) Pancake airfilter/Bell mouth air filter - excellent. Makes carb adjustment/removal so much easier, removes the old shitty, prone to crack rubber from the 'tea caddy' filter/side air box arrangement with the added bonuses of increasing air flow, freeing up your RHS tool box and looking farking cool!
2) '50s 'British Made' shorty exhaust system - the more expensive one on the hitchcocks website. From a performance and feel point of view, excellent - totally transforms the bike (with the relevant carb jets I mite add). For me it just gave it that little more oomph it needed, was able to hold lines in corners with the throttle rather than just having to hope. With the baffle out it was pretty damn loud, but no one seemed to care - Even though windows would shake at full throttle, I only ever got thumbs up from people! It also allowed me to junk the PAV system, simplifying things and also more or less freeing up the LHS toolbox! From a quality point of view, I had gone for the more expensive ones because I heard the cheaper indian ones rotted within a year through a good Scottish winter. I lost the use of the garage I had last winter, and so my bike was sitting out under a cover, and it has now got spots of rust all over it - was quite disappointed with that, but hey, was only £130 for the full system!
3) Bar end mirrors - well for pure tart value tbh, although they also didn't stand up too well to the Scottish winter, but for just over a tenner a pop I didn't really expect them to.
4) Hagon covered rear shocks - were an ebay purchase, I found a pair which has only about 1000miles on them for less than half price and so i pounced. V. good purchase, stock suspension was way too stiff for me (only 12stone) and the hagon units have really helped iron bumps in the road out. Taking a pillion is much nicer too, feels almost like a modern bike now!
and...
stinkwheel wrote:
I stripped one of the nuts that holds the front wheel hub together with two fingers on the spanner. It turns out that this is a totally weird thread. It's an M16x1.0 Extra Fine with a non-standard hex. I could buy a "proper" new one for 95p but since they are clearly made of cheese not steel, I got new ones custom made.
Then I stripped the thread off one of the front wheel mounting studs when I went to replace the standard nuts (which point downhill slightly) with nylok ones. Had to make new studs by cutting back some longish bolts.
All in all. I have resolved to replace any nuts and bolts I remove with proper, high tensile ones.
I replaced the oil pumps with high flow ones as suggested. This seems to work pretty well because it sprung several leaks that weren't there before. Just needed the oilway bolts nipping up a bit tighter.
Having done that I decided to replace the exhaust with one that makes it sound like a motorbike rather than a lawn mower. You'll notice it's about hyalf the length of the priginal. I also fitted a conical S&B filter and upjetted the carb. I also fitted a richer throttle body.
Final addition was a set of pannier racks. Had to ditch the back rack for them to fit but they have lugs that I can bolt a box or shelf to.
All these changes do not need to happen at once but I would like to be slowly building and changing it over the course of a month or 2.
I would love to know where to start but all of this is a little over my head!
Any help from Enfielders would be appreciated!
oatesmx
PostPosted: 21:37 - 27 Sep 2010    Post subject: Re: Buying a Royal Enfield 500 & total refit, Noob help. Reply with quote
Yeah you were rite about that one
if it doesn't smoke, it's a joke... 2stroke for life bitch!!!
PostPosted: 22:03 - 27 Sep 2010    Post subject: Re: Buying a Royal Enfield 500 & total refit, Noob help. Reply with quote
I wouldn't go overboard on this point, unless you are going to go the whole hog and replace the crank etc, a very mild tune is the way to go. Most people fit a free breathing pipe, block off the PAV system, fit an aftermarket air filter (either an S&B or one of the "tea caddy" type ones) and alter the carb to suit them. This makes them more free revving and will gain you a couple of BHP without unduly stressing the internals.
The five speed box is much nicer than the 4-speed, it also costs £600. I decided I'd live with the 4-speed, I'd like 5-speeds but mot to the tune of £600. I am tempted to fit close ratio gears though to move the gear ratio in 3rd closer to fourth (there is a BIG gap between the two gears)
With the above, you ought to be able to gear it up a tooth or two.
Not absolutely sure the high flow oil pumps were totally necessary. What I would do is invest in a couple of fastner kits so you can replace any ropy nuts and bolts as you go.
This would address may of the corrosion problems people experience.
4) Importantly, I've noticed many of the rear mud guards on the new Enfields are not inline with the rear tyres (as in the do not follow the same curve) I've noticed this on many of the Indian models and to the discerning eye this is not nice! I would like the rear mudguard to be nicely in line with the rear tyre follow the curve. So the images above are perfect in this respect.
That mudguard shape is an original feature though. They're shaped like that for function not aesthetics. they keep the mud and spray off both you and the bike. It is however, up to you.
I fitted a relatively cheap shorty Indian silencer (£45 as I recall) and mine sounds just like that. Less hissing because I removed the PAV.
Even with the standard Speedmasters, there is more grip than ground clearance. Fitting a thinner piece of rubber on the mainstand bump stop makes it sit higher and radically increases ground clearance. I would do this before blowing my wad on tyres. If you find them not grippy enough, Avon roadriders fit.
Good luck. If you find out how, let me know. It's down to how much you spend ultimately. A British made silencer will be much more corrosion resistant than and Indian one but will cost 2-3 times as much. They also make them in stainless.
Don't go tearing the whole bike apart as soon as you get it. Ride it about for a bit so you get a feel for what you like and what you don't like. They are meant to be ridden, not sit in bits in the garage. Get used to routine servicing which will give you a feel of how it all fits together.
Some people have nothing better to do than wash and polish their bikes. These ones are shiny. Others can't be arsed, these ones are not shiny.
PostPosted: 22:39 - 27 Sep 2010    Post subject: Reply with quote
Some of the non shiny ones might be Indian home market models which come painted in a nice shade of silver.
Some of the shiny ones are like that because they are polished whenever they can't be ridden and are waiting for spares to arrive.
You may be a mechanical noob at the moment but after a couple of years of Enfield ownership you'll be able to strip the engine down blindfolded, have a very good knowledge of how carburettors work and how wiring looms are put together.
I've had numerous different Enfields over the last 15yrs, but these days only have enough spare time to ride my bikes, not waste time sorting out problems arising from bad quality control.
spetom
PostPosted: 23:40 - 27 Sep 2010    Post subject: Reply with quote
Stinkwheel, you know when I mentioned repainting a bike?
Is it possible to strip the paint and then give it a solid repaint that would be weather proof? I would rather a professional does the repaint as I'm somewhat dubious in my finish.
I take it they strip the paint, prime it and then repaint? Would it be better just to buy the new parts to repaint? Or would it just cost a bomb?
Likewise is there a way of getting rid of the electric starts on the later models? I'm looking at buying a model now that has an electric start but I'd rather keep it as true as possible to the 50s original?
PostPosted: 01:52 - 28 Sep 2010    Post subject: Reply with quote
You can do pretty much anything you want. It's all a matter of time and cost.
Stripping it back to the bare frame then rebuilding it would be very time consuming, maybe a lot to take on for a novice. Having it painted (or stripped and powder coated if you wanted to go the whole hog) wouldn't be the cheapest job in the world. Then you go and scratch the new finish putting the engine back in.
I think you'd need to change out the gearbox to convert electric to kick start but I'm not certain on the ins and outs of that, there may be more to it. The EFI models are electric start only. Easier in the long run to just buy one with a kick start if a kick start is what you want.
I'll be blunt. Buy the time you've done everything you are proposing, you might as well have bought a Triumph Bonneville in the first place.
The main advantage Enfields have over everything else is that they are cheap and basic. Spare parts are equally cheap and are readily available. Revel in that and ride it, don't spend all your time and money trying to turn it into something it isn't.
If a part has rotted or worn beyond useful function, replace it then. If the whole thing eventually rots into the ground, buy another one (and I bet you'll have still spent less).
spetom
PostPosted: 14:03 - 28 Sep 2010    Post subject: Reply with quote
I've seen some pretty low mileage 500s over the last 2 months go for less than a £1000 on ebay and they were 5 gear kickstart models (so I don't have to spend a lot on new gear box). My idea is to get one that on the outside might not be in great condition (so rust here and there it's definetly getting a respray) but have lower mileage so 3000-10000 miles. Then to create an optimised plan to up the bike to all of the above. I don't need to go over board with the performance of the bike but I definetly want to breath new build and mechanical solidity into it.
Time is ok I'll have quite a bit of time to do it and there is another reason for doing all this I want it to be a decent introduction to motorcycle mechanics and after less than a year of owning it I would like to be more than the following:
I would like a steep learning curve to the next bike I'll be getting which I'm pretty much 100% sure will be a Honda VFR 400 in some months time, I intend to be doing that one up as well.
My total estimated budget is £2000-2200 but I'm counting on that including buying the bike between £700-£1000 which I've seen some of the early 90s models going for.
Is there an Enfield forum anywhere where I can get more expert and detailed advice?
The only way I know (Without actual decent chroming, which if I'm right is copper, nickel then chrome plating I believe? (is this expensive??)) is to put ACF 50 on all the chrome bits.
I used to do this on my Japanese and Chinese 125s to stop them rusting over the winter, the stuff really works. Only trouble is whenever you touch the bike when it's covered in ACF 50 you get the oily ACF 50 all over you and as the stuff is so viscous and permeable it somehow always manages to get onto your mirrors and handles!!
PostPosted: 15:52 - 28 Sep 2010    Post subject: Reply with quote
There is a bulletin board on the Hitchcocks website if you had any specific questions.
https://www.hitchcocksmotorcycles.com/
PostPosted: 15:57 - 28 Sep 2010    Post subject: Reply with quote
There are quite a few dedicated Enfield forums around. Here are some of the more popular ones.
https://www.hitchcocksmotorcycles.com/index.php
https://tinytim.forumcircle.com/index.php
https://www.midlandbullets.co.uk/smf/index.php
https://autos.groups.yahoo.com/group/royalenfield/
https://www.enfieldmotorcycles.com/forum/
There's a fair bit of technical know how buried within these sites, you can browse all of them but [like here] some will require membership if you wish to post a new query. Each have their share of resident 'experts'. Two have ride-out sections as well, if you fancy the chance of breaking down with like minded individuals Wink
The Bulleteers (tinytim) are predominantly based around the Severn bridge area (but ride a lot further afield occasionally) Midland Bulls are in the Midlands.
This place stocks Indian Enfield parts along with some after market stuff, with prices cheaper than most other UK based outlets.
https://www.pricepartmotorcycles.co.uk/
You will always, always need to phone. The owner (Henry) who runs it has been known to travel abroad to repair bullet engines that the owners and local mechanics can't sort out, and he always seems to be busy, so one of his other less knowledgeable staff might answer. For that same reason its not worth just turning up on his door step either. But if you want to save a fair bit of money it's certainly worth persevering.
Robby
Dirty Old Man
PostPosted: 16:08 - 28 Sep 2010    Post subject: Reply with quote
You'll find that an awful lot of bullet owners do similar modifications to their ones - it's a bit like the Harley owner idea of buying the bike then fitting the entire screaming eagle catalogue, but for a fraction of the price.
So you'll be able to buy one with a better oil pump, air filter and exhaust so a lot less than buying a standard one and buying all of those parts.
Don't be too hung up on mileage, it's the build quality and lack of care that kills them rather than miles. An enthusiast owned example with an uprated oil pump and 20k on the clock is likely to be better than a standard one with a non-mechanical owner and 5k on the clock.
Corrosion can be prevented using ACF-50 and occasional cleaning. ACF-50 needs to be renewed from time to time. Steel parts such as the frame or swinging arm benefit from being powder coated, and reassembled with decent bearings, seals and bushes. Once you have measured the existing bearing, seals and bushes then you can find decent, cheap replacements at www.simplybearings.com.
I stripped a 1980 CB250RS down to the frame, stripped the paint off with nitromors, rubbed back any rust patches with emery paper, gave it a coat of rust converter and then two coats of hammerite paint. Took bloody ages. The paint has scratched, chipped and flaked in no time at all, I'll be stripping it again over the winter and getting them blasted, welded and powder coated. This will cost about £200, which is a drop in the ocean against the rest of the spend you're looking at.
You'll spend a lot more than the value of the bike, make sure you keep all the receipts. When you're thinking of selling it, look at how much you've spent on it and the massive loss it represents. You'll never sell it.
Don't try a home sprayjob, it'll look crap. Knackered original paint looks a whole lot better than a crap home sprayjob, a classic looking bike should have some character.
If you are going to tune it internally, do it right. Find a local old-school engineer, tell them what you want to do, and give them a lot of money. They'll smile, love the project, and do a really good job. Make sure you have a spare, working standard engine sat in your garage inhibited so you can keep it on the road when you blow the tuned one.
If the overall aim is a cheap, simple, reliable commuter, then anything Japanese will do the job easier and cheaper - CB250 of any description comes to mind. No soul in a 250 twin though.
spetom
PostPosted: 16:25 - 28 Sep 2010    Post subject: Reply with quote
Robby wrote:
I stripped a 1980 CB250RS down to the frame, stripped the paint off with nitromors, rubbed back any rust patches with emery paper, gave it a coat of rust converter and then two coats of hammerite paint. Took bloody ages. The paint has scratched, chipped and flaked in no time at all...Don't try a home sprayjob, it'll look crap. Knackered original paint looks a whole lot better than a crap home sprayjob, a classic looking bike should have some character.
I did exactly the above (minus the nitromors part) and hammerited parts of an old Honda CG! Also resprayed a Honda Escort front bumper when I was younger. I know now definetly I will not do a home paint job ever again!
Correct!
Would love to do this but I'd actually like to learn and do it myself, perhaps I could get an old-school engineer and do it with him??
I don't need to commute that often, overall aim is to learn motorcycle mechanics and have a multi purpose long range pocket battleship that I can also enjoy as a classic looking bike! Otherwise I would just wait a couple of months and then fork out £6000+ on an original 1940s Triumph, but I fear I would have mechanical issues and would not dare to ruin such a bike with my lack of mechanical savvy by commuting or long distance bombing runs!
Thanks for the pointers everyone.
PostPosted: 16:28 - 28 Sep 2010    Post subject: Reply with quote
Indeed from someone who I believe was recently asking about the best MPG, spending a load of money that could probably easily double the per-mile cost on top of fuel for a decent few years seems a bit odd.
spetom
PostPosted: 16:52 - 28 Sep 2010    Post subject: Reply with quote
I know an Enfield probably won't burn more than 60 mpg even if I really upgraded the engine.
I just got afraid about the VFR 400 and CBRs as I'd heard a rumour that they were burning up 30mpg standard! Meaning London Manchester is 3 stops at a petrol station! Another good reason to have one as a 2nd bike.
PostPosted: 17:00 - 28 Sep 2010    Post subject: Reply with quote
The point was that if you look at how much you're likely to pay out in total for all your 'modifications' minus any likely sale price (which won't go up nearly as much) then divide that by the miles you do, you'll find you're probably spending quite a lot per mile.
I'm always amused by people buying new cars with really low mpg, yet swapping it out every couple of years, so they're actually paying a lot more in depreciation per mile than they are for their fuel.
I'd be willing to bet a VFR400 (or better, a GPZ500) ridden at the speeds you can ride the Enfield would result in pretty damn good mpg.
Of course you have the option to go massively faster and get less mpg, but it's your choice not a limitation.
Me, I have bikes for practicality and fun. I'd get a diesel citreon AX and try and get some paying passengers along if I wanted good fuel economy Smile.
spetom
PostPosted: 18:30 - 28 Sep 2010    Post subject: Reply with quote
I was afraid the VFR 400 would be like a Range Rover where you have to stop to fuel every 60 miles! (I'm exaggerating)
You are right of course, but I have no intention of selling this one or the VFR 400. I'm sure that I could buy a kickstart Enfield 500 for around £800 with 5 gears, low mileage (I know I know!), then put in £1200 (and remember the only part I will outsource is the respray! So labour = me is free!)
Well as I have also set my heart on a VFR 400 and would like to try out racing on a track, I will definetly be able to tell you in several months time!
I intend the enfield to be the first learning curve and then I'll buy a VFR 400 which will be an even steeper learning curve mechanically. I would like one of the better low mileage VFR 400 so around £1500+ then another £1000 would be kept in reserve to do anything up on it. I've decided I'd like to have the VFR 400 more as a collectors piece, so I won't be doing any long miles on it just the race track and back and once acquired I don't think I'll ever be selling it either!
The last post was made 15 years, 344 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.53 Sec - Server Load: 0.25 - MySQL Queries: 13 - Page Size: 114.07 Kb
