Giving the bike A decent service.
L-Jam
PostPosted: 11:32 - 28 Sep 2010    Post subject: Giving the bike A decent service. Reply with quote
So, I've rode the CBR for about 1500/2000 miles now, and decided since I have about a spare £100, I want to clean it a bit more etc., just for the banter really.
I've already bought A K&N air and oil filter, iridium plugs and new oil, and will fit these over the weekend, but since I have some money and time, what else do you recommend doing? Nothing is really 'wrong' - the bike is flawless in terms of paintwork but I can sense the oil/plugs etc need a refresh, and I really want to clean up the swingarm/under the shock area. What shall I use?
/Stupid question.
Journalist, student, egotist.
supZ
PostPosted: 11:50 - 28 Sep 2010    Post subject: Reply with quote
apart from a good clean i think you've got it covered.
thing i use to clean the swing arm (if im giving it a good going over i'll take off the rear wheel) is muc off bike cleaner and muc off degreaser for any stubbon 'deposits'. i have a tech 7 brush set i use that helps lift any stuck on crap
works wonders.
after last winter my 600s swingarm looked like this..
https://farm3.static.flickr.com/2682/4452806392_06eba4d4a7_z.jpg
then some cleaning later
https://farm5.static.flickr.com/4042/4452033183_7eb8fe06c6_z.jpg
makes the world of difference Smile
CBR954RR - Daily toy
CBR600RR - Trackbike
L-Jam
PostPosted: 11:54 - 28 Sep 2010    Post subject: Reply with quote
Haha that is literally the exact effect I want to achieve. Cheers for the input Karma
EDIT: That wasn't the end of the thread BTW BCF. MOAR ideas!
ajbsmirnoff
PostPosted: 13:24 - 28 Sep 2010    Post subject: Reply with quote
Autosol metal polish for any metal you'd like a bit shinier. Does require elbow grease, which Halfords don't stock.
Autoglym plastic polish is pretty good at making plastics (but not painted plastics) go back to black if they've faded a bit or need a clean.
I'd not bother with a MagicTree air freshener though.
PostPosted: 14:04 - 28 Sep 2010    Post subject: Reply with quote
Pair of socks?
Embarassed
https://i104.photobucket.com/albums/m174/howlingterror_2006/DSCF0478.jpg
They serve no purpose.
Suntan Sid
If you do have any black plastics to clean, and want to get them back to black, use some of that black, plastic, bumper/trim restorer available for cars.
Works a treat!
spetom
PostPosted: 14:07 - 28 Sep 2010    Post subject: Reply with quote
works wonders.
Quite a difference. Did you have to take of the swing arm totally to do this? Or did you manage to do it as is?
Gazz
PostPosted: 14:39 - 28 Sep 2010    Post subject: Re: Giving the bike A decent service. Reply with quote
L-Jam wrote:
I have about a spare £100, .
If its going spare I'll take it. Very Happy
DrDonnyBrago
PostPosted: 14:39 - 28 Sep 2010    Post subject: Reply with quote
What is the total mileage now? Check the valve clearances if they are due, change the fork oil, grease the shock linkages and swingarm pivots, grease the headstock bearings, change the brake fluid, change the coolant, clean out your caliper seals if they could do with some work, get everything clean in and around the sprocket cover.
Then polish some stuff with autosol, clean the crap out of everything and give it a healthy dose of ACF50 or spend your £100 on a used endcan that doesn't look like a chromed kayak Thumbs Up or pay a pro to set your suspension up properly.
The list of bike things to spend £100/lots of time on are endless Mr. Green .
EDIT: Cleaning the swingarm/sprocket area etc, use a spray degreaser or something like paraffin and a spray bottle to loosen the crap and degrease then wash with soap and water Thumbs Up .
EDITEDIT: brakes are always worth cleaning if you have the time, get the crud and crap off the pistons and grease/red rubber grease/copper grease (each grease serves a different purpose) all the pins, pistons, rubber parts etc that you find in there.
supZ
PostPosted: 15:23 - 28 Sep 2010    Post subject: Reply with quote
did it as is, only took the back wheel off so i could get to it and went to work
with a few brushes of varying sizes and some time. didnt require much effort, just took a bit of time to loosen all the grime up and wash it off Smile
i did use my jet wash to help get rid of the crap once id loosened it all up but the brushes did the real work
Robby
Dirty Old Man
PostPosted: 16:14 - 28 Sep 2010    Post subject: Reply with quote
If you're getting down to that level of swingarm cleaning, then I would take the arm out to check/grease/replace is necessary the swingarm bearings. If they are a bit knackered then this will make a huge difference to the handling. Also strip, clean and regrease the shock linkage.
The bits of servicing above basic home servicing aren't really the sort of things you spend money on, they're mostly time and feelr guages or a grease gun.
With £100 spare I would:
Change the coolant.
Replace the wheel bearings (about £15 in all)
Replace the swingarm bearings (about £30 all in)
Possibly replace headstock bearings (£30)
Change fork oil (£15).
Change brake fluid (£5).
mr.kris
PostPosted: 16:32 - 28 Sep 2010    Post subject: Reply with quote
do ur valve clearences wont cost alot just get it done buy the new shims u need if any
TS50X---CM125---MZ150---Z250---RS125---ZXR250---BANDIT600---TRX850---TL1000S---CBF600---ZX6R---BANDIT1200S---CG125---VFR800---CBR1000F---CG125---CG125---CB900F---CB900F---CG125---TUONO1000R---KLR600---GSX1300R HAYABUSA---VFR400NC30---BANDIT1200---CG125
HAYABUSA now in use!
The Tot
PostPosted: 18:28 - 28 Sep 2010    Post subject: Reply with quote
Grease up all your terminal connectors. Being a honda, the electrics WILL eat itself over the winter from the inside out. If you have a spare £100, put that aside for when your regulator rectifier goes pop.
Other than that, anything that robby said is valid. Prep her up and get it ready for winter (or storage).
I wish I had the time to do stuff like that in my own time, but bike gets used 24/7 - 20k miles last year pretty much killed it!
Never argue with autism
swiftb
PostPosted: 19:20 - 28 Sep 2010    Post subject: Reply with quote
Change the coolant.
a +1 on the above items. All money well spent, especially on an older bike.
L-Jam
PostPosted: 01:51 - 29 Sep 2010    Post subject: Reply with quote
Thanks A lot for the replies guys, karma where it's due..
Donny, the mileage is 22,000ish. Average?
I will definitely be taking the back wheel off at the very least.
Cheers Robby, I will probably end up doing most of these things. I'll speak to my Dad (ex bike mechanic) about doing the valve clearances, see if it's worth it/if he's willing to help me.
Tot, my bike gets used 24/7 and will be eating the winter too, but I have set aside about 3 days in which I can really work on it so that the winter shall be survived and I can make the most of what's left of the summer.
I haven't just got a spare £100 haha, I just did A bit of overtime in order to be able to spend some money on my bike Laughing
Cheers Karma , and I will add any progress to my HRC CBR thread in show and tell, considering I haven't done much recently.
craigs23
Mr Muscle
PostPosted: 06:53 - 29 Sep 2010    Post subject: Reply with quote
No excuse Tut Tut
The Tot
PostPosted: 21:03 - 29 Sep 2010    Post subject: Reply with quote
It was pretty much parked outside in all weathers - snow and rain. Washing the bike down every week in the freezing cold is NOT an option for me Crying or Very sad
I was going to say you can treat it to some ACF50 BUT it's way too early for that stuff.
The last post was made 16 years, 17 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.13 Sec - Server Load: 0.99 - MySQL Queries: 13 - Page Size: 100.18 Kb
