| Hunter |
 Hunter Nitrous Nuisance
| Guest |
 Guest
| Kickstart |
 Kickstart The Oracle
| G |
 G The Voice of Reason
| Hunter |
| G |
| Hunter |
| G |
| Hunter |
| NovaMuncher |
 NovaMuncher Two Stroke Sniffer
| G |
| Hunter |
| G |
 Posted: 11:37 - 16 Mar 2002 Post subject: |
Not sure how much you know, so here's the basics of what you need to do:
First you need to get the bike so the reservoir is as level as possible.
Take the cover off the reservoir, making sure you keep all the stuff away from dust etc.
Cover the bodywork around the reservoir with an old rag to prevent any fluid getting on it.
Attach your tube to the bleed nipple and put the other end in the jar, secure tightly around the nipple.
Undo the nut underneath the nipple, the brake fluid should start to seep out, make sure none is leaking from the seeal between the tube and nipple.
*Gently* press/pull on the brake leaver, fluid should start to come out through the tube, note the colour.
When the fluid reaches the 'lower' mark on the reservoir, top it up with fresh fluid.
Repeat until the colour of the fluid coming out though the tube has lightened and is therefore fresh fluid.
Top up so that it's at the maximum line, close the nut underneath the bleed nipple then replcae the covers & remove the tube.
Remeber: brake fluid eats bodywork, so be *very* carefull. |
| Hunter |
| G |
 Posted: 18:40 - 16 Mar 2002 Post subject: |
Yeh, it's the same for both.
Varous people on here helped me when I first got my NSR, so I'm quite happy to reciprocate.... And I'm still trying to find an excuse to not do tidying . |
The last post was made 24 years, 193 days ago. Instead of replying here, would creating a new thread be more useful? |
