| flamegrape |
 flamegrape Nitrous Nuisance
 Posted: 21:59 - 29 Sep 2010 Post subject: Arghh!! Piston Lube, can you, can't you? |
A short time back I posted about one of my pistons refusing to tow the line and work with the others to push my pads!!
I followed everybody's advice and removed the calliper, cleaned everything up and (short of rebuilding the damn thing - which I'm manly enough to admit... I'm afraid of doing!!) got all my pistons dancing in time.
Now the same one is playing up again. If this little sh*t was only pushing the brake pads as much as it pushes it's luck I would not be trawling the net for a solution, only to find so many differences in opinion!
Anyway, my question is, I think I can fix my problem (without stripping the calliper) with some cleaning and lubrication. I've read WD40 is a suitable light oil to lube the pistons, others say brake fluid, others say red grease , others say to use brake grease and NEVER to use Copper Grease.
Can anybody suggest a solution/lubrication method to help? This is not a huge problem (despite my hysterical outburst!) and not causing a load of bother (but I can hear the pad brushing the disk when when riding) but I don't like riding knowing there is something which needs fixing because that means something isn't working right!
Any help and advice would be greatly appreciated!!
Thank you.  ____________________ Jonny (Riding his Kawasaki ZX6R J1)
It's one big learning curve right now  |
 ..... Quote Me Happy
| flamegrape |
| Frost |
 Frost World Chat Champion
| 0l0dom0l0 |
 0l0dom0l0 World Chat Champion
| LongJohn22 |
 LongJohn22 Trackday Trickster
| flamegrape |
| 0l0dom0l0 |
 Posted: 22:51 - 29 Sep 2010 Post subject: |
| jonny2010 wrote: | | Quote: | just pop all the pistons out, and give everything a darn good clean. where abouts are you located? if you near me, i dont mind giving a helping hand! |
Forgive my stupidity here but can the pistons be removed with out bleeding the brake fluid or does this sit "behind" the pistons? I'm near Newcastle at the minute but moving to Oxford to live a happy life on Monday. |
ah, a little far away from me then. Basically, what you want to do is remove the banjo bolt from the caliper and remove the caliper completely from the bike. take out pads etc, and get down to the raw caliper. then using a compressor, pop all the pistons out. leave them to soak it WD40 to remove brake dust. then get a very small screwdriver, and a pair of tweezers, and remove the seals. (there will be 2, one dust, and one piston). do this for each piston. then in the cavity where the seals sit, use the screw driver to remove any perished rubber residue. give everything a good clean down with water and a toothbrush. then apply reapply the seals, and replace all the pistons. attach back to the system. (do both calipers). then re bleed everything through. will take probably a long afternoon to do, but it will make a noticeable difference afterwards.
if your not sure on anything, just watch a couple of videos on youtube!!
EDIT: Make sure you coat the new seals in brake fluid, and also lube the pistons with brake fluid when putting them back in. thats all you can do!! |
| Frost |
| 0l0dom0l0 |
| flamegrape |
 Posted: 23:02 - 29 Sep 2010 Post subject: |
Superb!!
I'll get onto YouTube and see what there - different people do things different ways - being new to it I'm always unsure who to follow for advice and which is good/bad advice.
I'll get this sorted ASAP and I'll drop a reply to this post and let you know how it went!!
Cheers guys!!  ____________________ Jonny (Riding his Kawasaki ZX6R J1)
| flamegrape |
 Posted: 23:26 - 29 Sep 2010 Post subject: |
PS: Thanks 0l0dom0l0 for your kind offer!!  ____________________ Jonny (Riding his Kawasaki ZX6R J1)
| Blue_SV650S |
 Posted: 23:39 - 29 Sep 2010 Post subject: |
Red rubber grease is the lube you are after.
So clean the gunk from behind the seals and re-assemble with red rubber grease, it is not only perfectly safe on brake seals, it is actually recommended to apply
https://morrisminorspares.co.uk/shop/images/graphics/LUB108.jpg ____________________ The purpose of life is to fight maturity. |
| evoboy |
 evoboy World Chat Champion
 Posted: 00:30 - 30 Sep 2010 Post subject: |
Youll probably find youll need to remove the pistons and dust seals to stop it seizing.
I persissted with the 6pots on my j1 for nearly 2 years till i just stumped up the cash and bought a set of Nissin 4 pots off a 1200bandit.
Not only a stiffer lever and more reliable braking power, but they havent seized up on me yet! ____________________ Suzuki GT250 x7------- Fazer 600------CB250RS------Aprilia Rally 70----- Bandit 600
APT Motorcycles |
| TUG |
 TUG World Chat Champion
| Bull |
 Bull Nitrous Nuisance
 Posted: 17:23 - 30 Sep 2010 Post subject: |
I got to do the same on my ER5 i got
As someones said go on www.wemoto.com i think its com and not co.uk)
Put in the make and model of your bike and your get a list of ALL the parts they do
My ER5 they do a Stainless Steel Piston and Seals (mine has 2 pistons one small one bigger and there both around £20/21 each I think that maybe Delivered aswell,
I still got to order mine when i get chance
O and sounds like your going to have to remove it Fully as i did the same as you tried doing it on the bike worked abit but still catching,
So that will mean Bleading the brakes ( i also hate brakes lol O and Red Grease is whot you want to put the pistion back in with and you can get a tube off Wemoto at the same time as the pistion and seals, |
| flamegrape |
 Posted: 21:45 - 30 Sep 2010 Post subject: |
If I remove a piston to clean and replace the seals - do I need to bleed the brakes and will there be a haemorrhage of brake fluid when I pop it out  ____________________ Jonny (Riding his Kawasaki ZX6R J1)
| D O G |
 D O G World Chat Champion
 Posted: 22:04 - 30 Sep 2010 Post subject: |
I'm a shit mechanic, and have rebuilt calipers before, and have three more to do soon.
Whilst in principle it isn't 'difficult', it's not, IMO, the pOp dom indicates. Getting pistons out can be a total bastard - there was a recent thread on here with a guide from some guy doing his TLR calipers. Well worth a read.
A good tip for getting annoying pistons out if you don't have a compressor, is to use a cycle pump - the big upright ones, and a high pressure valve from a road pushbike inner tube. You can cut the valve from the tube, trim the rubber so it screws tightly into the caliper thread, and pump the air in. If the 'other' piston is secured one sticky one should pop out.
If you manage to get them out easily (ho ho), then on reinstallation make sure that the seals are correctly orientated - some seals are tapered, put them in the wrong way round, and if you force the piston in - like I did, you're fucked, new seal time. They should press in with finger pressure.
Then you have to bleed the brakes. Which is not that easy, and I've heard that the 6 pots are particularly gruesome.
If I was doing this, and I had all the parts and tools available to me straight away, I reckon I could do it in a day. Maybe. Probably a whole weekend after all the messing about.
Just a word of reality from someone who has only done this once. |
| Robby |
 Robby Dirty Old Man
| LongJohn22 |
 Posted: 23:00 - 30 Sep 2010 Post subject: |
There appears to be a degree of confusion as to how a disc brake actually works. As I stated earlier the pads are in constant light contact with the disc because there is no mechanism to withdraw the piston after the brake lever has been released. The following has been lifted from an item on the web titled "How disc brakes work", it can be found at;
https://auto.howstuffworks.com/auto-parts/brakes/brake-types/disc-brake2.htm
As I also stated earlier, based on the information previously given by the OP, I am far from convinced that a problem exists, a binding brake will manifest itself in a significant loss of power and a disc literally too hot to handle.
The single-piston floating-caliper disc brake is self-centering and self-adjusting. The caliper is able to slide from side to side so it will move to the center each time the brakes are applied. Also, since there is no spring to pull the pads away from the disc, the pads always stay in light contact with the rotor (the rubber piston seal and any wobble in the rotor may actually pull the pads a small distance away from the rotor). This is important because the pistons in the brakes are much larger in diameter than the ones in the master cylinder. If the brake pistons retracted into their cylinders, it might take several applications of the brake pedal to pump enough fluid into the brake cylinder to engage the brake pads. |
| 0l0dom0l0 |
| DrDonnyBrago |
| Blue_SV650S |
 Posted: 08:18 - 01 Oct 2010 Post subject: |
| DonnyBrago wrote: | | LongJohn22 wrote: | Stuff about brakes |
They do retract back into the caliper a little, you can see it happen when you are looking at the pistons with the calipers off and pads out. Fractions of a mm but they DO retract a small amount.
Thought I might add, I do understand the concept that brake discs are by design, always slightly in contact with the pads, but if one piston is behaving differently than the rest and causing one caliper to bind then it is time to get it sorted before you have a warped disc and need new seals. |
Where the seal flexes slightly, when released, the pistons pull slightly away with the stiction of the calliper seal on the piston. i.e. the movement in the piston and the stiction to the seal has resulted in a slight bending of the seal, this then pulls it back.
Then when riding, the whole shabang moves about with vibration and with floating discs, the movement of the disc.
As stated, there is no proper recoil device, so they are expected to bind slightly, but if spinning the wheel by hand - with the wheel off the floor - the wheel stops spinning in less than 1 rev, they are over binding! ____________________ The purpose of life is to fight maturity. |
The last post was made 16 years, 8 days ago. Instead of replying here, would creating a new thread be more useful? |
