Replacing Handlebars
Adam.I
PostPosted: 20:12 - 01 Oct 2010    Post subject: Replacing Handlebars Reply with quote
Hello all, bought a Bandit and it's got the standard handlebars on it. Got some different ones, not as 'bent', more suited to me. Just a bit cautious changing them over.
I know to undo the four bolts near the yoke, and taking the mirrors off is straight forward. But unsure about the actual controls. Anyone know how?
Veni Vidi Vici
Itchy
PostPosted: 20:25 - 01 Oct 2010    Post subject: Reply with quote
You need to drill some holes!
There will be small dowels in the controls (horn/lights indies)which you need to drill holes for. Else they won't fit!
Just undo everything and put it back on after you';ve drilled the holes took me 20 minutes to do it on my NTV, if you are careful you can slide things off your old bars and slide them back onto your new bars saving much time.
Adam.I
PostPosted: 20:31 - 01 Oct 2010    Post subject: Reply with quote
Ah, so that's what the hole is for! It's already got 'em so that's one less job. Everything is loose now, bit the grip seems stuck on?
Veni Vidi Vici
Itchy
PostPosted: 20:39 - 01 Oct 2010    Post subject: Reply with quote
WD40 and screw driver down the inside, then bog roll on the inside to absorb said WD40 and some glue, I used no more nails on the NTV grips and on the CBR used nothing as the grips were a very tight fit anyway.
The last post was made 16 years, 6 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.05 Sec - Server Load: 1.12 - MySQL Queries: 13 - Page Size: 42.04 Kb
