Street fightering a GPX
hornetmike
PostPosted: 22:20 - 01 Oct 2010    Post subject: Street fightering a GPX Reply with quote
I want to streetfighter an old gpx 600r to use as winter bike, as front fairing already missing. I want to put wide handle bars on it. Where do I get, or how do I sort out the top yoke to take bars?
https://t2.gstatic.com/images?q=tbn:t2yaD0-q-gKZyM:https://i40.photobucket.com/albums/e230/iainbogie/GPZ900R/My_GPZ900R_Handlebars_ZZR600D.jpg&t=1
I know this pic is not a GPX, but its the same stlye set up.
87 Honda CG 125 - 97 ER5 - SR 50 -81 Z250- 96 CBR 600 F- 94 GPX600R 88- GPX 400R- 87 GS 125 - 2006 Honda CB600F- 2003 ER5 - Honda CBF 1000 2009 - Honda CBR 600 RR 2011
Current BMW R1200GS 2010
mad4it028
PostPosted: 22:41 - 01 Oct 2010    Post subject: Reply with quote
remove the bars that are on then buy some risers of an enduro drill yoke for risers and fit renthals or what ever bars you want
on that bike at least the standard bars look like they unbolt (4 allen key bolts) different if there part of the yoke
0ddball
PostPosted: 22:53 - 01 Oct 2010    Post subject: Reply with quote
+ you might need longer cables and brake lines so might not be worth it if it's just a winter hack.
hornetmike
PostPosted: 22:59 - 01 Oct 2010    Post subject: Reply with quote
Your probably right but I want to do it for some reason
like this ?
https://i.ebayimg.com/04/!BwCqzw!Bmk~$(KGrHqZ,!h4Ev1+0GP8+BMHLm5ccTw~~_35.JPG
mad4it028
PostPosted: 23:00 - 01 Oct 2010    Post subject: Reply with quote
yep like them
evoboy
PostPosted: 21:22 - 02 Oct 2010    Post subject: Reply with quote
https://sphotos.ak.fbcdn.net/hphotos-ak-snc3/hs067.snc3/13432_407568647249_797677249_4331062_2673192_n.jpg
https://sphotos.ak.fbcdn.net/hphotos-ak-ash2/hs331.ash2/61133_439043482249_797677249_5096111_6633787_n.jpg
Luckily all the cables will reach on my ZX6.
APT Motorcycles
hornetmike
PostPosted: 22:45 - 02 Oct 2010    Post subject: Reply with quote
thats what I am planning to do, much more comfortable.
PostPosted: 22:58 - 02 Oct 2010    Post subject: Reply with quote
Busters do a fairly inexpensive handlebar clamp that attaches round the top of the fork stanchions. You should find there is just enough sticking through if you remove the standard handlebars. Off the top of my head, you need 24mm of stanchion for them to get an adequate hold.
You have the exact same setup as my old GPZ. Here's what I did. Tension on the wiring to the switchgear was the biggest issue, I had to do some rearranging of the loom (cut back the wrapping where the wires join the main part of the loom and re-wrapped with the "split" up to the the bars further back it to create more slack).
https://i48.photobucket.com/albums/f216/stinkwheel/gpzfighter3.jpg
https://i48.photobucket.com/albums/f216/stinkwheel/gpzfighter2.jpg
hornetmike
PostPosted: 23:12 - 02 Oct 2010    Post subject: Reply with quote
that looks even easier I'll try that.
What front light is that ?
PostPosted: 23:23 - 02 Oct 2010    Post subject: Reply with quote
A realy, really shitty, bolt-on "stealth" headlight/indicator unit I got for about £20 off ebay. Really shitty but good enough for the MOT after my mate crashed it.
EDIT: I'd add, if you go for the clamps, get some big rubber grommets to blank off the hole in the middle or water will sit there and the circlip that holds the bung in the forks will weld itself in place with rust. Rolling Eyes
evoboy
I like the idea of the clamps Stinkwheel posted!
Id go with that option on that kinda top yoke. Thumbs Up
APT Motorcycles
The last post was made 16 years, 23 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.06 Sec - Server Load: 1 - MySQL Queries: 13 - Page Size: 70.42 Kb
