"Doesn't restrict very well"
HD
PostPosted: 23:14 - 02 Oct 2010    Post subject: "Doesn't restrict very well" Reply with quote
I will be moving from a 50 to either a 600 or a 650 or a 250 enduro. So basically the question is when people say an inline 4 doesnt take the restriction very well does that mean that it can damage the engine or it just doesnt pull very well?
I am fully aware that the sv650 is good because it has lots of low down torque but Im not too mad on the power. An inline4 will be good as it sounds, looks nice. Yes, again it will be more expensive on insuranc, but its a price I am willing to pay. And besides, a 600 restricted to 33bhp im sure will be fine to play with for two years.
Thanks Mr. Green
yuri2085
PostPosted: 23:20 - 02 Oct 2010    Post subject: Reply with quote
You sound like you mean GSXR or R6 when you say IL4? (high powered sports bike)
It won't damage the bike but whatever you do, do not ride the bike before it is restricted or you will hate it once restricted.
In before everyone else: don't bother restricting it.
Yarri
PostPosted: 23:22 - 02 Oct 2010    Post subject: Reply with quote
I'd rather have a nice 125 then restricting a bigger engine, or you can get ninja 250rr if you can afford.
Theory Passed: 23/10/2008 Very Happy 49/74 Bike Test Passed: 05/01/2009 Very Happy 1 minor
Theory Car Passed: 22/07/2009 Very Happy 48/74 Car Test Passed: 22/10/2009 Very Happy 2 minor
Few minutes of life of the biker could be more interesting then the whole lifes of many people
HD
PostPosted: 00:04 - 03 Oct 2010    Post subject: Reply with quote
Yeah. Something like that. Was looking at the cbr600f as it would be a bit better for commuting. And dont really like the ninjas.
Thanks
Devans
PostPosted: 00:23 - 03 Oct 2010    Post subject: Reply with quote
The only bikes that don't restrict that well are ones with all there power at the top of the rev range, as the restrictor cuts the top end off big time.
My VFR 800 is restricted to 33BHP and it's fine....
Frost
PostPosted: 00:52 - 03 Oct 2010    Post subject: Reply with quote
Take a big bike and imagine the power vs rev's graph like this:
https://image.sportrider.com/f/9054496/146_z+2001_gsx_1300r_hayabusa_dyno_chart+.jpg
It's producing more than 33bhp by the time it's at 2200rpm. SO if it were restricted to 33bhp it would have very little of the rev range actually usable. Most sports bikes have a very long 1st gear as they are designed with the track in mind. On the track the slowest speed the bike is likely to do is 50mph+ so 1st gear is designed to be usable at that speed. This means that a large amount of the rev range is used in 1st gear. So only being able to rev up to a tiny fraction of it makes it very difficult to use.
Typically in line 4 cylinder bikes of a given size make more power than say a twin or triple of that size, and will therefore be greatest hit by the restriction. In line 4's also rev higher than a bike of the same size with a different configuration and therefore need to be able to use the full rev range.
hmmmnz
PostPosted: 02:09 - 03 Oct 2010    Post subject: Reply with quote
get a big single, xr600 dr600 klr etc, they are all about 33hp... at the crank, so no need to restrict, and re sale on them all is far better than most bikes,
you'll be sick of any bike after a few years, so no point buying one that you are looking at keeping untill you are over your restriction,
you'll want a new bike anyway
the humans are dead
I kick arse for the lord
Shaane
PostPosted: 10:52 - 03 Oct 2010    Post subject: Reply with quote
I'm on a 600 ninja and it took the restriction perfectly well, obviously its nothing like what it should be because theres 70bhp missing. Also like previously mentioned, do NOT ride the bike without the restriction in if you intend to leave it in because you will hate it.
Previous: 1992 DT125R
Current: ~ 2005 ZX6R C1H
HD
PostPosted: 12:24 - 03 Oct 2010    Post subject: Reply with quote
Okay, thanks guys. So basically, dont get a sportsbike Razz And so when people say it wont take it very well they mean that it doesnt perform, not that it will damage the bike in any way?
Also, to add to the list, I was thinking about the cbr, zxr and vfr 400's. Any one got any comments on these? Restricted?
Thankyou Mr. Green
Devans
PostPosted: 13:08 - 03 Oct 2010    Post subject: Reply with quote
The little sports 400s are fine restricted, they only have 40-50bhp anyway, the major factor is the size. They are tiny!
Shaane
PostPosted: 13:18 - 03 Oct 2010    Post subject: Reply with quote
Just means it won't be as fast as other 600s. Will still perform and do it at a decent rate.
rac3r
PostPosted: 13:37 - 03 Oct 2010    Post subject: Reply with quote
Whatever you get will feel fast restricted...for a while then you will get curious Laughing
Chequered Flag
PostPosted: 13:48 - 03 Oct 2010    Post subject: Reply with quote
That's taking a rather simpistic view - the reality is that by restricting inlet and other bits the engine is made to make less power throughout the revrange, so it won't be producing nearly as much to start with.
Gearing certainly is an issue - with a modern litre bike geared for over 100mph often, if you restricted one, just using first would be like having to use top gear for everything for a bike designed for that amount of power.
(However, that is actually a bit of an over simplification too, as in some cases the rev range is restricted too - so effectively making it a bit shorter geared relatively.)
So from my experience I'd say most bikes can be restricted ok (though I would avoid a litre sportas bike regardless), but that you do want to consider some decent geaering changes if it's high geared as sports 600 and faster are.
Personally, I'd just go for a cheap SV and consider upgrading the suspension if it became an issue.
Otherwise, if you're interested in getting muddy, go for a DRZ400 perhaps.
HD
PostPosted: 15:15 - 03 Oct 2010    Post subject: Reply with quote
Okay. Thanks for the comments guys. Quite interested in the vfr 400. One bloke has one literally at the top of my road and I love the sound of it. It also is quite nice looking with West racing decals.
They go for about £1500ish on eBay so that is quite reasonable so what is insurance like for a 17 year old with 1 years ncb (fingers crossed). Also, would you guys advise taking lessons for my test or not? Maybe just a couple?
Thankyou Smile
0l0dom0l0
PostPosted: 15:22 - 03 Oct 2010    Post subject: Reply with quote
Thankyou Smile
VFR400's do restrict well, but they arent to great on insurance. they are imports, and the companies dont like that.
get lessons, i thought i was good enough to take my test without lessons, but had i not taken the lessons i would have failed big time! it gets you out of the bad habbits and into what the examiner wants.
also IL4'S can restrict well. it just depends on their 'full power' output as with any other bike. naturally a bike with 50nhp standard is going to restrict better than something with 120bhp as standard.
to put it into perspective, my fazer is 95 bhp. it restricts ok, but it wont rev past about 8k in neutral. the power curve goes all over the place after 6k (i had it dynoed). but for the first 6k in the rev range its ridable. it just depends on what you want to go for. dont bother with ninjas or r6's because they dont restrict well, and cost a fuck load on insurance. get something like a hornet/fazer/bandit that are lower classed bikes and take the restriction okay. of course though, the sv650 will always be slightly quicker than them because its a twin.
Shaane
PostPosted: 15:36 - 03 Oct 2010    Post subject: Reply with quote
If your after a vfr400 i'd have a sit on 1 first because there tiny and may cause a problem if your quite tall?
Tom_B1H
PostPosted: 15:57 - 03 Oct 2010    Post subject: Reply with quote
My old zx6r was restricted via the throttle, would be perfectly acceptable coming from a learner legal. Bike still read 125mph and held my own on a couple of trackdays, obviously it was a totally different bike with the restrictor removed.
I would not go down the expensive route of 4 stroke 125's or 250's
Previous: '08 Suzuki DRZ400SM > '04 Kawasaki ZX-6R B1H
Current: '07 Kawasaki ZX-6R P7F
HD
PostPosted: 16:00 - 03 Oct 2010    Post subject: Reply with quote
Well yeah, im 6 foot ish. Maybe more. Also Im a big build :/
Not too keen on those 3. Would rather go for an sv. How about a cbr600f? Do quite like them and they are more sat up.
Thanks Thumbs Up
HD
PostPosted: 16:19 - 03 Oct 2010    Post subject: Reply with quote
Was maybe thinking a 4stroke 250 enduro...
How was your drz?
And yeah, still an option but I dont like the zx6's. Maybe an r6 or gsxr. Again, not too keen on the cbr's.
Redoko
PostPosted: 18:26 - 03 Oct 2010    Post subject: Re: "Doesn't restrict very well" Reply with quote
Thanks Mr. Green
Thats what I thought when I came passed my test, got a GSX-R600.
Insurance was killer, but yeah I thought, it's so worth it.
It's not, I'm at Uni and have to ride back every weekend for work, the insurance is almost as much as I earn a month, (8K Claim on me) and the fact it's a sport.
When I move to a Hornet, it's less than a 1/3 of the price of a GSX-R insurance wise.
Don't get me wrong, I fcuking love my Gixxer, but I have little time to pleasure ride it now, so mainly just commuting, so I need something cheaper, and more reliable.
Choose wisely, nakeds are usually half the price insurance wise to super sports. Thumbs Up
Cheeseybeaner
PostPosted: 18:41 - 03 Oct 2010    Post subject: Reply with quote
I don't really know why you'd want to get a restricted machine anyway, personally.
You'd be better off with a 250 designed to make the most of its 30 odd hp without completely capping the engine's output and characteristics.
I can't imagine why you'd want to restrict a 180kg bike down to 33hp when you could have something smaller, sharper and more exhilarating to ride with its throttle pinned open most of the time and responding as it should be.
As said something like the 250 Ninja which used to be known as a GPX250 would be ideal if its a so-called 'sports' machine you're after.
The insurance will undoubtably be cheaper and you'll have a bike you can use to its full potential that hasn't been muzzled.
I couldn't see the attraction in riding around on a 600 sports bike that goes less well than some 125s!
HD
PostPosted: 18:58 - 03 Oct 2010    Post subject: Reply with quote
Cos then I have a bike to de-restrict that is better. Dont really like the ninja 250. Its more expensive than some others mentioned. I think thats about it really.
Cheeseybeaner
PostPosted: 19:16 - 03 Oct 2010    Post subject: Reply with quote
Sure but you've got to ride a very heavy 33hp bike that doesn't go very well and is completely flat for 2 years!
Personally I'd go for something that meets the 33hp criteria and performs as well as it can, possibly a single cylinder trail bike or something like an SRX maybe. Cheaper to run and insure as well. You can always sell after two years anyway.
I can't see how a 600 four restricted to 33hp can be much fun at all to ride, would feel completely castrated.
Frost
PostPosted: 19:22 - 03 Oct 2010    Post subject: Reply with quote
G wrote:
That's taking a rather simpistic view...
Yeah it was an over simplification, but when the OP was asking if restriction was bad because it hurt the engine, or it made it ride crappy i thought it was a justified one. As my explanation hints at, and you go on to point out, down gearing might be a good idea if restricting something that usually does 70mph in 1st, otherwise everything above 4th gear is going to be like an over drive.
HD
PostPosted: 19:30 - 03 Oct 2010    Post subject: Reply with quote
Im fine to make the choice of bike from all of the information I have now but will restriction actually harm the bike? Thats the question.
The last post was made 15 years, 337 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.10 Sec - Server Load: 0.56 - MySQL Queries: 13 - Page Size: 132 Kb
