| lee24yorkshir... |
 lee24yorkshir... Two Stroke Sniffer
| N cee thirty |
 N cee thirty Banned
| lonie |
 lonie Banned
 Posted: 14:26 - 28 Sep 2010 Post subject: |
tried checking teh imobiliser?
speedfights are a bitch for the immobilisers failing and not letting you start it (first hand experiance)
look at the imobiliser light when you turn the key it should flash twice then go out and not re light till you turn the ignition off if it carys on flashing or stays solid then you need a new CDI about 180 squids for the OEM one iirc
check the carb take it off clean it also get some off this
https://www.gmengineers.co.uk/easy_start.jpg
and try it with that
if you still cant start it
then i am in york if you're nearby ill happily lend a hand
also try throwing soame fresh petrol in there speedfights can be fussy little bastards when they want to be |
| lee24yorkshir... |
| N cee thirty |
 N cee thirty Banned
| lee24yorkshir... |
| N cee thirty |
 N cee thirty Banned
| lee24yorkshir... |
| lonie |
 lonie Banned
| N cee thirty |
 N cee thirty Banned
| lee24yorkshir... |
| N cee thirty |
 N cee thirty Banned
| lee24yorkshir... |
| N cee thirty |
 N cee thirty Banned
| lee24yorkshir... |
| N cee thirty |
 N cee thirty Banned
| lee24yorkshir... |
| lee24yorkshir... |
| Paxovasa |
 Paxovasa World Chat Champion
| Glenben92 |
 Glenben92 Nearly there...
 Posted: 12:22 - 02 Oct 2010 Post subject: |
not flooding is it? "spark plug is WET" rings alarm bells to me like ____________________ 57 Huoniao HN125-8 - , 97 Kawasaki GPZ500S -
99 Yamaha FZS 600 -
Mod 2 Passed - 01/10/2010 |
| lee24yorkshir... |
| Paxovasa |
| lee24yorkshir... |
| Glenben92 |
 Posted: 11:52 - 03 Oct 2010 Post subject: |
Bare in mind that with a 2t, if the plug gets oiled up its NOT gonna start. Mixture could be too rich, which fouls the plug with oil before it can get a chance to fire. I've had this before with a 2t ped. ____________________ 57 Huoniao HN125-8 - , 97 Kawasaki GPZ500S -
99 Yamaha FZS 600 -
| andys675 |
 andys675 World Chat Champion
 Posted: 12:30 - 03 Oct 2010 Post subject: |
if you have a speedfight with an immobiliser you should always use a Resistor type spark plug as in BR8ES as the radio waves transmitted by an non resistor plug can damage the CDi, frying the programming so it fires at the wrong point, also getting the cdi connector plug wet can affect the spark timing, as does putting the battery on the wrong way or shorting it out  |
The last post was made 15 years, 338 days ago. Instead of replying here, would creating a new thread be more useful? |
