Waterproof trousers that actually keep your arse dry?
CjKit
PostPosted: 13:53 - 04 Oct 2010    Post subject: Waterproof trousers that actually keep your arse dry? Reply with quote
Hi all,
I'm a year-round rider and commute to work everyday.
Problem is that I can't find a pair of bike pants that'll keep my butt dry when I sit on a wet seat.
I've had four pairs of Goretex pants from 2 different manufacturers (Dainese and Hein Gericke) and all of them do the same thing.
Within 10 minutes of sitting on a wet bike seat I can feel that my arse is damp.
I sent the Dainese pair back to Gore (via Infinity) who tested them but could find no leaks.
They said that they don't guarantee against this sort of thing as the plastic seat prevents the water escaping and body heat turns the water into vapour which can get through the Goretex layer - seems ridiculous as they supposedly "guarantee to keep you dry"
I dry the seat as much as I can before I get on but when it's raining the water will find it's way underneath you anyway.
I would've bought a cheaper pair if I'd known that I'd have the same problem even with Goretex.
I'm wondering if anyone else has this problem and if not what pants you wear.
The Artist
PostPosted: 13:56 - 04 Oct 2010    Post subject: Reply with quote
I have never had this problem. Maybe because all my seats have not absorbed water.
Solution
Make your seat waterproof.
PostPosted: 13:58 - 04 Oct 2010    Post subject: Reply with quote
Dutch army issue gore-tex overtrousers. I've used them for years and they keep me dry, even with a set of combats under them.
I long ago gave up on he search for the perfect "do everything" piece of motorcycle clothing. I wear thermals to keep warm, leathers/kevlar for protection and waterproofs to stay dry.
CjKit
PostPosted: 14:00 - 04 Oct 2010    Post subject: Reply with quote
The seat itself doesn't absorb water as it is waterproof.
I've had the same problem on both my '03 Bandit and my current '86 CB750
CjKit
PostPosted: 14:03 - 04 Oct 2010    Post subject: Reply with quote
Yeah I too have given up on that dream. I just want some trousers that will actually keep me dry.
I have no problem with waterproofness anywhere else, just where I'm in contact with the seat.
I've actually also got a pair of Berghaus Paclite Goretex overtrousers and even they do the same thing.
PostPosted: 14:09 - 04 Oct 2010    Post subject: Re: Waterproof trousers that actually keep your arse dry? Reply with quote
CjKit wrote:
Hi all,
I have some 'OUTDOOR-MC' waterproof overtrousers that I got from www.getgeared.co.uk . They only have zips in the sides and so there is nowhere for water to get in on the backside area. They cost £60 IIRC and can easily be put on over jeans etc because of the leg zips.
The Artist
PostPosted: 14:09 - 04 Oct 2010    Post subject: Reply with quote
Always carry a pouch/fanny pack of tissue paper?
yen_powell
PostPosted: 14:24 - 04 Oct 2010    Post subject: Reply with quote
I've had a few pairs of these too, British version as well. Cheap and do the job.
XT1200Z and a DR350 in bits
pa_broon74
PostPosted: 14:52 - 04 Oct 2010    Post subject: Reply with quote
I use normal berghaus overtrousers, zip and popper up the sides, so far so good. Only thing is the bottoms ride up a bit so you get wet trouser cuffs.
One thing I do get is, a cold feeling round the crotch area, it feels like water is getting through but its not, I think its just cold rain pooling in that area then chilling the material, eventually that chill gets to your skin and it feels like cold water.
Each time though, when I get to where I'm going, I'm as dry as a bone.
Didn't catch anything.
iooi
PostPosted: 15:24 - 04 Oct 2010    Post subject: Reply with quote
I have a pair of Spada over trousers, they are fine as were the cheap ones I had before these.
Never had this issue of pants leaking from soaking up water from the seat.
You sure its not leaking down, if you have a short jacket ?
A good test would be to wear the ones that you think leak. But put a plastic bag on the seat so you are sitting on something dry. Thumbs Up
Gortex works by only allowing moisture to move in one direction ie away from you body. Now I can see what they are saying. From the point of view that because you are sat on a non breathable surface the sweat from your nether regions can't escape. But it should still get through the gortex and sit in the outside layers.
Might make you feel like its wet, but should not actually be wet.
CjKit
PostPosted: 15:25 - 04 Oct 2010    Post subject: Reply with quote
I know what you mean about the cold crotch Shocked
However, I often wear my jeans under the trousers in the winter and the seat area is noticeably damp by the time I get to work - which is only a 25 min ride.
I just can't understand why I've had it with 4 different pairs of trousers - plus my Berghaus overtrousers - when other people don't seem to have the same problem.
CjKit
PostPosted: 15:36 - 04 Oct 2010    Post subject: Reply with quote
iooi wrote:
.... put a plastic bag on the seat so you are sitting on something dry.
Thing is I find that even if I get on a completely dry seat, by the time I get where I'm going the rain has got underneath me and the seat is wet when I get off - strange...
iooi wrote:
From the point of view that because you are sat on a non breathable surface the sweat from your nether regions can't escape. But it should still get through the gortex and sit in the outside layers. Might make you feel like its wet, but should not actually be wet.
I know it's not sweat as it's not that sort of dampness and it happens even in really cold temperatures.
It's also not that it just feels wet as whatever I'm wearing underneath is noticeably damp when I take the trousers off.
CjKit
PostPosted: 15:56 - 04 Oct 2010    Post subject: Reply with quote
Thanks for the input guys.
Just wanted to know if it's a common problem that people learn to put up with.
Apparently it's not Confused
Welshd1k
PostPosted: 16:47 - 04 Oct 2010    Post subject: Reply with quote
alot of my trousers did this had a pair fo rukka that NEVER ever got evan damp in for 3-4 years then they gradually started to leak
lucky rsm
PostPosted: 17:18 - 04 Oct 2010    Post subject: Reply with quote
https://www.getgeared.co.uk/WEISE_WT_Motorcycle_Rain_Trousers?sc=19&category=165
Never had any problems with these and i commute over an hour in any weather everyday. Butt and Balls dry everytime! Laughing
cb500s, er6f, er6f, Gsx650fK9
DMan
PostPosted: 17:35 - 04 Oct 2010    Post subject: Reply with quote
cheap shit nylon waterproof over trousers work perfect! Like those Weise ones or even cheaper. Just wear biking over-trousers for warmth and protection then these over the top. Means you have to stop if starts raining on journey but 2 mins to put on.
Trouble is the weakest point of goretex etc is the stitching as the holes for the needle can be the fail point unless made correctly, guess the crotch probably has the most in one area to fail.
2001 Hornet 600 - "Faster than yellow" Blue; Current: 1998 Yammy FZS 600 "Fazer" Black
You show me how to control a wild fucking gypsy and I'll show you how to control an unhinged, pig-feeding gangster.
andyscooter
PostPosted: 18:29 - 04 Oct 2010    Post subject: Reply with quote
dickies wet/work trousers work brilliant im on my third pair as i tend to lose or break the seals on them but at 9 quid a pop ive had ten years out of them
so 27 quid for ten years of dry
HD
PostPosted: 19:44 - 04 Oct 2010    Post subject: Reply with quote
Another one for the Weise's: https://www.getgeared.co.uk/WEISE_WT_Motorcycle_Rain_Trousers?sc=19&category=165
They are so cheap and came high in RiDE's tests Thumbs Up
olionel
PostPosted: 20:10 - 04 Oct 2010    Post subject: Reply with quote
ive got some regatta walking overtrousers, bought em a bit long in the leg.. £5 off ebay... kept me dry during badass rains in south of france this september
1989 CG125 - Childhood Sweetheart (she got kidnapped by baddies)
1998 ZXR400 - Teenage Love (lasted three years, then she turned lesbian and left me)
2001 XRV750 - Wife Material (still getting to know her but head over heels in love)
iooi
PostPosted: 20:14 - 04 Oct 2010    Post subject: Reply with quote
[quote="CjKitThing is I find that even if I get on a completely dry seat, by the time I get where I'm going the rain has got underneath me and the seat is wet when I get off - strange...
It's also not that it just feels wet as whatever I'm wearing underneath is noticeably damp when I take the trousers off.[/quote]
I hate to say, this and please don't take offense at it. But it could be possible that you have a issue with water leakage while on the move. Not uncommom if you are bounced around. Either that or because of the extra layers in the crotch area's you are sweating a lot. Certain area's of the body will sweat no matter how cold it is.
Could be related to the material your underwear is made from.....
You may not feel either of the above till you get off the bike.
Could be water is funneled to that area while on the move. You don't say what type of bike you have.
Daz324
PostPosted: 20:21 - 04 Oct 2010    Post subject: Reply with quote
I've just bought some Frank Thomas pathfinder textile trousers for commuting, will let you know how it goes!
The last post was made 16 years, 16 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.10 Sec - Server Load: 0.84 - MySQL Queries: 13 - Page Size: 113.3 Kb
