| syler |
 syler Two Stroke Sniffer
| N cee thirty |
 N cee thirty Banned
| Wafer_Thin_Ham |
 Wafer_Thin_Ham Super Spammer
 Posted: 19:19 - 29 Sep 2010 Post subject: |
Could just be a knackered battery. ____________________ My Flickr |
| doggone |
 doggone World Chat Champion
| Walloper |
 Walloper Super Spammer
 Posted: 21:07 - 29 Sep 2010 Post subject: |
I'm betting on the flat battery being goosed too.
Lead acid type batteries get a coating on the plates inside which cannot be removed if left to go flat and kept flat. Recharging regularly stops this irreversible damage.
https://en.wikipedia.org/wiki/Lead%E2%80%93acid_battery
New battery 20 40 quid
Halfrauds et al ____________________ W-ireless A-rtificial L-ifeform L-imited to O-bservation P-eacekeeping and E-fficient R-epair |
| syler |
| syler |
| N cee thirty |
 N cee thirty Banned
| syler |
| N cee thirty |
 N cee thirty Banned
| syler |
 Posted: 14:25 - 04 Oct 2010 Post subject: |
Most of the time you can only really check the regulator / rectifier by seeing if the battery is charging and by substitution with a known good one.
However you can test the other things in the circuit to exclude them. Main thing is the actual stator. There will be a few wires from the stator to the regulator / rectifier, probably 3 and they will probably be the same colour. With the ignition off disconnect these from the regulator / rectifier, set the multimeter to measure resistance and check that on each pair of the 3 wires the resistance over them is the same.
| syler |
| syler |
 Posted: 15:32 - 04 Oct 2010 Post subject: |
| stirlinggaz |
 Posted: 16:37 - 04 Oct 2010 Post subject: |
check the current coming out out the yellow wires?
set multi-meter to 100v or nearest setting, your looking for 30-60v, or whatever it says in wsm.
if your gettting the required voltage (eg. the bike i just rebuilt, the wsm stated 40-60v & multi-meter showed 53v, so this indicated the charging circuit was ok)
the reg/rec just controls the voltage, ie. brings it down to a steady 12v or whatever, afaik.
i was having the same sort of problem, battery charged up overnight off bike but would slowly lose its charge.
i found the connector block with the 3 yellow wires & was getting 53v out, but when i put multi-meter probes on battery & revved the bike, the voltage wasnt increasing, like it should.
anyway, the 53v reading indicated the charging circuit was ok, the fact that the battery wasnt reading 53v or something silly, indicated the reg/rec was doing its job,so i reckoned it was a dud battery.
so i splashed out 40 quid on a new battery... & it was still the same, this baffled me somewhat(waste of 40 f*cking quid too!).
tried another reg/rec & it was still the same. (i didnt know if the spare reg/rec was any good, as it was in an old box of spares.)
the problem?
turns out i was getting the 53v at the male end of the plug but not at the female end!
once i cut off the offending plug & joined wires with spade connectors, problem solved!
took me a few days to figure that one out,lol
was just a dodgy plug!
cheers,
GAZ |
| syler |
| dotti2009 |
 dotti2009 Derestricted Danger
The last post was made 15 years, 332 days ago. Instead of replying here, would creating a new thread be more useful? |
