cg dipped beam dash light always on
iooi
PostPosted: 17:00 - 04 Oct 2010    Post subject: Reply with quote
Dipped bean warning light ???
Is it blue, if so thats main beam and I would take a guess that its wired wrong. Could be the dip/main wires are crossed over somewhere,
stonesie
PostPosted: 20:56 - 04 Oct 2010    Post subject: Reply with quote
It's a right rat's nest of wires in there, what I ended up doing on mine was pulling every connector apart then cleaning the wires and starting from scratch, just match the colours.
It gets fun when you get down to the last few, long nose pliers are a big help too. Thumbs Up
Note
Your indicator tell-tale must work for your MOT!
https://www.ukmot.com/bike_1-5.asp#Text_top
lonie
PostPosted: 21:58 - 04 Oct 2010    Post subject: Reply with quote
indicator tell-tale does not have to work if you can see the indicators when sat on the bike (ohh btw easy bodge connect a bulb holder to one off the indi cables and use that as a tell tale if nessisary)
lonie
PostPosted: 23:51 - 04 Oct 2010    Post subject: Reply with quote
U dient swap the wires round with the ignition ON did u u may have blown the bulb id check that first stupid i know but its always the simple things (like the killswitch Smile )
stonesie
PostPosted: 16:56 - 05 Oct 2010    Post subject: Reply with quote
Nicely done, CG's like ours are easy to test. Being so basic helps Thumbs Up
I must have mis-read the link I put above (bottom right of the first table) Embarassed I know mine raised an eyebrow for flashing orange rather than the more usual green Laughing
The last post was made 15 years, 104 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.05 Sec - Server Load: 0.89 - MySQL Queries: 13 - Page Size: 81.72 Kb
