Pattern Fork seals and bushes
Nixon
PostPosted: 15:10 - 06 Oct 2010    Post subject: Pattern Fork seals and bushes Reply with quote
Has anyone got any horror stories with pattern fork seals? Is it worth spending more to get genuine? Its about half the price, £30 for pattern £60 for genuine Confused
Ta Thumbs Up
Deckx
PostPosted: 15:16 - 06 Oct 2010    Post subject: Reply with quote
They're just bits of rubber at the end of the day.. last time i got a seal changed here in Thailand the owner said he got it locally from a place that made piston type rams/actuators..
BTW , check first, the leak isn't from a corroded fork leg as it will fuck up the new seal.... all it takes is a few tiny spots Confused
tatters
Exxon Valdez
PostPosted: 15:33 - 06 Oct 2010    Post subject: Reply with quote
Always buy original oil seals if you can get them, pattern ones are normaly of a poor quailty and inferrera rubber.
pattern dust seals and bushes are fine.
Robby
Dirty Old Man
PostPosted: 15:58 - 06 Oct 2010    Post subject: Reply with quote
60 quid for genuine fork seals, or for the whole oil seals, dust seals and bushes kit?
I always get genuine fork seals. Used to use pattern ones, and I have never had a set of pattern seals last more than 500 miles without leaking.
When you have them stripped, make sure any surface corrosion on the fork legs is rubbed back with a finishing pad. Fork seals rarely go just due to age, usually some corrosion on the fork leg has caused them to go - likely from the bike standing for 6 months or more and a very small amount of corrosion developing.
Pattern bushes and dust seals, although to be honest I have never had a set of bushes so worn that they needed replacing. They're only likely to wear that badly if the bike has done over 100,000 miles or has been run for a while with no oil in the forks.
The last post was made 15 years, 351 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 0.58 - MySQL Queries: 13 - Page Size: 40.08 Kb
