Gear lever flaps about sometimes and won't go into first?
PizzImperfect
PostPosted: 15:43 - 08 Oct 2010    Post subject: Gear lever flaps about sometimes and won't go into first? Reply with quote
Hi,
An issue i've had with my CBF125 since week 1 really.. and my friend who has a Kawasaki Eliminator has exactly the same issue...
If i'm slowing and come to a stop in say, 2nd gear with my clutch in... And try to shift down into 1st to set off again... It seems to just flap about and bounce back into neutral.
Is it advised to only shift down while actually in motion?
Its frustrating when im sat at lights in neutral and it refuses to shift into 1st.
The way around it seems to be to rev and let the clutch out slightly, and something clicks and from then it will shift into 1st.
This may be something all bikes do.. i don't know, can you help?
Thank you and sorry if its a stupid question!
MaybeGuy
PostPosted: 16:21 - 08 Oct 2010    Post subject: Reply with quote
its normal.
Sequential gearboxes only work properly when they're moving
PizzImperfect
PostPosted: 16:31 - 08 Oct 2010    Post subject: Reply with quote
Spot On. Well that's one thing to keep in mind.
Sorry for the stupid question, and thanks for the answer!
tahrey
PostPosted: 19:56 - 11 Oct 2010    Post subject: Reply with quote
Just like some balky car gearboxes, best if you can get it into 1st as the very last thing before coming to a stop. Like 1mph or less and it should snick in nicely.
Alternatively let clutch out in neutral, pull it in again and hit the lever, the residual spinning of the input shaft should allow enough movement for it to engage. If not, final thing is to rock it forward/back slightly til the output shaft turns and it clicks in. (With the balky car, this comes down to moving it eeeeever so slightly in 2nd or reverse... trickier when it's R that won't engage and you haven't got much leeway for forward motion!)
The dog teeth on the engagement mechanism aren't lining up quite right, and without the ability to move past each other they probably won't. It's possible in all gears, but worst in 1st for... well... some reason. I was going to give an explanation but sounding it out mentally, it sounds like BS.
The last post was made 15 years, 338 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.06 Sec - Server Load: 0.34 - MySQL Queries: 13 - Page Size: 40.71 Kb
