Fairing fittings
Suntan Sid
PostPosted: 11:44 - 09 Oct 2010    Post subject: Fairing fittings Reply with quote
What are those rubber, doughnut type, things that fairings clip onto called and more impotantly where can I buy them?
PostPosted: 11:48 - 09 Oct 2010    Post subject: Reply with quote
If its what I think it is then its just fairing rubber washers. Ebay have them. I know this because I need one for my bike.
Its the rubber bung that attaches the fairing to the actual frame/engine block?
They are attached by a big screw or allen bolt. I bought crash bungs after one of mine went missing. Saddly the crash bung has now gone missing because the Thread has gone in the housing.
Oops
UKRedwing
PostPosted: 12:08 - 09 Oct 2010    Post subject: Re: Fairing fittings Reply with quote
Think you're talking about the rubber grommets
Suntan Sid
PostPosted: 12:33 - 09 Oct 2010    Post subject: Reply with quote
Thanks for the replies.
I'll have a look on Ebay!
salty21
PostPosted: 14:11 - 09 Oct 2010    Post subject: Reply with quote
or maybe he means well nuts?
PostPosted: 14:14 - 09 Oct 2010    Post subject: Reply with quote
Rawl nut Thumbs Up
https://www.bonaero.com/images/RaulNuts.GIF
yanto
PostPosted: 15:21 - 09 Oct 2010    Post subject: Reply with quote
my parts fish calls them RUBBER GROMMET Thumbs Up
Suntan Sid
PostPosted: 16:31 - 09 Oct 2010    Post subject: Reply with quote
Well I've spent a couple of hours googling and can't find anything suitable.
What I am looking for are grommets, they fit over studs attached to the frame the fairing panels then slot onto the grommets.
The nearest I can find are "open cable grommets", but none, that I can find, are the right dimensions.
Can you link this parts fiche please?
yanto
PostPosted: 16:44 - 09 Oct 2010    Post subject: Reply with quote
what bike is it as my parts fish are kawasaki
Suntan Sid
PostPosted: 08:32 - 10 Oct 2010    Post subject: Reply with quote
Well I need some for a Yamaha and some for a Honda.
I can't see there being that much difference between makes, the ones on my Yam have a 6mm hole in the middle and the slot, that the bodywork fits into, is 4mm.
If your Kwacka bits are the same I'm sure they'd fit!
The peoblem with the "open cable gromets" is that the slot for the body work is too small!
yanto
PostPosted: 09:54 - 10 Oct 2010    Post subject: Reply with quote
here is a site i use select your bike it will come up with all the parts the numbers are the same all over the world
https://www.cmsnl.com/ hope it helps
Suntan Sid
PostPosted: 17:19 - 10 Oct 2010    Post subject: Reply with quote
CHR15 wrote:
Yes I saw them, thanks but I need more than he's got!
After spending way too long Googling, I now know searching for:-
"Side panel rubbers"
or
"Side cover rubbers"
or
"Side panel damper"
or
"Side cover damper"
produces results, so for anyone else looking for these parts, use those search parameters!
Thanks for all the replies. Thumbs Up
The last post was made 16 years, 20 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.08 Sec - Server Load: 1.29 - MySQL Queries: 13 - Page Size: 75.18 Kb
