| map |
 map Mr Calendar
 Posted: 20:58 - 09 Oct 2010 Post subject: Advice needed - Bike will idle but not rev! - update sorted |
Had a little bit of drama with one of the bikes.
Old, 1985 CG125, in need of TLC eventually got running and through MOT. It's a little project bike, like to get it restored a little more rather than rat it.
However, on a little test ride the fuel filter snapped. Subsequent replacement emergency replacement hose and bike didn't pick up revs. So suspect some debris in the carb. (That's the clean version, was thinking more horse manure!).
Daughter's boyfriend dismantled and cleaned carb. Bike will now idle ok. However, does not rev correctly and will not pick up to be ridden (ok, will do about 5mph but that's all).
It's almost like the throttle doesn't wind round far enough. Have checked what I can of the points (yes, it has points, it's that old). These seem ok but I know this was one bit replaced as part of the tlc.
So, in summary, any help/advice/pointers appreciated for a non-reving old CG125. Thanks in anticipation.
 ____________________ ...and the whirlwind is in the thorn trees, it's hard for thee to kick against the pricks...
Gibbs, what did Duckie look like when he was younger?
| N cee thirty |
 N cee thirty Banned
| map |
 map Mr Calendar
| N cee thirty |
 N cee thirty Banned
| map |
 map Mr Calendar
| N cee thirty |
 N cee thirty Banned
| map |
 map Mr Calendar
| N cee thirty |
 N cee thirty Banned
| map |
 map Mr Calendar
| N cee thirty |
 N cee thirty Banned
| map |
 map Mr Calendar
| Noxious89123 |
 Noxious89123 World Chat Champion
| Blue_SV650S |
 Blue_SV650S World Chat Champion
| map |
 map Mr Calendar
 Posted: 00:02 - 18 Oct 2010 Post subject: |
Quick update.
Problem appears to be sorted.
Issue 1 was the carb needed another strip down and clear.
Daughter's boyfriend's father came over and sorted.
Guy is used to sorting this kind of thing.
Issue 2 that he spotted and sorted was magneto cover not fully on.
Removal showed some damage to woodruff key.
This has caused slipping and so altered the timing.
No wonder didn't rev correctly.
Temporary woodruff key fabricated (guy is a fabricator by trade!).
Slotted all together and all appeared to work ok.
Getting a genuine woodruff key as this will be of hardened metal and when fitted this will complete the job.
Will give the CG some more TLC over the coming months.
Thanks to everyone for their advice.
If anyone has similar issues I hope this thread will be of some help.
| stinkwheel |
 Posted: 02:50 - 18 Oct 2010 Post subject: |
| map wrote: |
Getting a genuine woodruff key as this will be of hardened metal and when fitted this will complete the job. |
Although if it's on in the right place now, the key is pretty superfluous. All the key does is make sure you locate the rotor in the correct place on the shaft when you fit it. It's the taper on the shaft that actually holds it in place. If it's on properly, what the key is made of is irrelevant (in fact, you could fit it without the key, it's just a bastard to get in exactly the right place).
If it's not on properly, it'll spin up and mangle the key even if it's a genuine one.
So, if it's fitted correctly with the tapers thoroughly degreased, the bolt torqued down on top of the rotor and is running properly, I'd leave it well enough alone. By all means get a new key and keep it somewhere safe to replace if you take the rotor off again but I see no good reason to strip it all down again now. ____________________ “Rule one: Always stick around for one more drink. That's when things happen. That's when you find out everything you want to know.”
| Blue_SV650S |
 Posted: 19:21 - 18 Oct 2010 Post subject: |
Yep, as stinky said, not worth replacing the key as it has already done its job*!!
*orientating the flywheel ____________________ The purpose of life is to fight maturity. |
The last post was made 15 years, 362 days ago. Instead of replying here, would creating a new thread be more useful? |
