| Big Pete |
 Big Pete Spanner Monkey
 Posted: 13:11 - 27 Jul 2004 Post subject: |
I will pontificate on engine fundamentals at lunch, when I have time to write a long ( and probably slightly patronising) post on the subject. The short version - 2 stroke or 4 stroke there is no other way with pistons. Technically, 2 strokes are more efficient. More later folks.  ____________________ Trust me, I`m an engineer
GarageOfPower.co.uk |
| Bendy |
 Bendy Mrs Sensible
 Posted: 13:16 - 27 Jul 2004 Post subject: |
Triple word score for 'pontificate'.  |
| Big Pete |
 Posted: 14:02 - 27 Jul 2004 Post subject: |
Bendy - I thank you lol.
right, engine fundamentals part one
piston engines only
engine efficiency is all about compression ratios and upper and lower temperature limits. Trust me on this one as its a pain to explain without going into the gas laws and drawing graphs.
If you to inject a self oxidising fuel in a piston engine at tdc on exhaust (having closed the ex valve first obviously) you will not get a very powerful engine.
This is because the bang is NOT what drives the engine. Heat (and the resultant expansion of the air in the cylinder) is what drives the piston down. If you put a pixie with a box of matches in the cylinder (and insulated it so it wouldn`t lose heat), as the the pixie lit the matches (raising the air temperature in the cylinder) the increasing pressure would force the piston down. If you shove explosives (and very little air) into the cylinder, the only gas available to expand and do useful work is that generated by the decomposition of the explosive (which is not much compared to a cylinder full which is then compressed at tdc).
2-strokes have the potential to be more efficient because they can do this twice as fast as 4-strokes.
If you want a really powerful, high efficiency engine you use a forced induction 2 stroke diesel ( which is at least as complex as a 4 stroke engine). Most really big engines (bulldozers, ships, generators etc) are this type. these engines have an exhaust valve in the head and inlet ports at the bottom of the cylinder. At bdc, the high pressure clean air is blown in the ports, forcing the waste gasses out the open valve. after the valve closes the piston starts to rise, compressing the air. At tdc fuel is injected in the normal manner, whereupon it burns, raising the temperature and pressure and forcing the piston back down. Repeat add infinitum.
As an aside, the blowers originally used on drag cars ("jimmy" blowers) were the scavenge pumps used on GMC 6-series bulldozer engines, which are of the type just described.
Here endeth the lesson, more another time if anybody is interested. ____________________ Trust me, I`m an engineer
| dibbster |
 dibbster Nearly there...
 Posted: 14:28 - 27 Jul 2004 Post subject: |
What are the advantages of the rotary engine as used by Norton?
Are their any bike companies that still use it? ____________________ Suzuki RF 600 - The two wheeled Testarossa (Deceased)
Suzuki GSXR - Now stops on a sixpence; SBK3's
www.bikepics.com/members/dibbster |
| Superabusa |
 Superabusa Two Stroke Sniffer
 Posted: 14:30 - 27 Jul 2004 Post subject: |
Piston engine's are measured by displacement & rotary's are measured by swept area, which is why the Norton's were binned in the end cos basically they were a fair bit bigger area than the bikes that they were racing against.
Also if the engine design was any good as a bike engine do you think Suzuki wouldn't have junked so much R & D? It's only when it's a bigger rotor with larger rotor tips that it becomes more efficient (RX7 & RX8). The Norton Aero engine is a different design again as it spends most of it's time at a constant RPM.
On the subject of the Norton BSB bikes though, didn't they have a different engine from the road bikes too. I'm sure they did. In fact if I remember correctly they even rotated in the opposite direction! As for the road bikes Overweight fuckin jellymolds that even the police found hard to ride.
I know you ain't going to agree with me on this Rot@ry but I couldn't give a flying fuck. I'm an aircraft engineer & I have covered Wankel engines in my training many moons ago, Norton's in fact! Also I'm older than you so screw the patronising bit mate. As for the 3 stroke idea, feck right off, it's still the same s.s.b.b. routine. Even jet engines s.s.b.b. In there own way 2 strokes do too, only from different sides of the piston.
I guess DaFrosty was probably thinking of the fact that the rotor is a 3 sided piece of kit it's a 3 stroke motor. Nice thought, but wrong. ____________________ Karma!! Fuck Karma, I am Satan's little helper.
& I'm considerably faster than yow! |
| TheGreatMilen... |
 TheGreatMilen... Derestricted Danger
| Big Pete |
| Shade_BW |
 Shade_BW I'm better than you
| Sadie |
 Sadie World Chat Champion
| Shade_BW |
| Mr Pants! |
 Mr Pants! I Karma
 Posted: 16:37 - 27 Jul 2004 Post subject: |
Mr W@nkle, I do recall those days, although I am only 34 years of old age. I know of all sorts of classic bikes as my uncle is one of the biggest dealers in them.
I will have to ask him about the Norton Rotary days......
He still chuckles at my plastic rocket, I my bike will never end up a classic as it would have probably disintegrated by then..... ____________________ Mr Pants! (Alex or Al)
Its better to burn out, than to fade away.... |
 Posted: 21:38 - 27 Jul 2004 Post subject: |
I do remember the Norton Rotaries, and remember seeing them race at the GP at Donington as a special one off (certainly raised a few cheers).
An engines capacity is measured as its swept volume, and it is just as easy to measure that for a rotary as for a normal piston engine. The problem is that a rotary engine has, effectively, 3 chambers sweeping the same volume at the same time so you can argue away about the effective volume when compared to a piston engine. For example if you say that a 2 stroke can have half the capacity of a 4 stroke as double the number of strokes are useful, then you could treat the rotary as having a capacity of a 4 stroke engine of 6 times the capacity.
From memory by the international rules the 588cc Norton was actually an 1176 (double the swept voume), but the UK rules were fudged to allow them to race.
| Demonic69 |
 Demonic69 The Pink Rhino
| W@nkel |
 W@nkel Derestricted Danger
 Posted: 23:48 - 27 Jul 2004 Post subject: Phew, you lot have been busy! |
| dibbster wrote: | What are the advantages of the rotary engine as used by Norton? Are their any bike companies that still use it? |
When BSA/Norton/Triumph evaluated the Wankel in 1969 it was considered to be the engine of the future having good power to size/weight ratio and very low vibration compared to a piston engine. Since then the Japanese have developed bike piston engines so much that these advantages have been cancelled out. Only Mazda use a Wankel now (RX8 car). The Wankel performs very well as a hydrogen fuelled engine and this may be its future.
| Superabusa wrote: | On the subject of the Norton BSB bikes, didn't they have a different engine from the road bikes? If I remember correctly they even rotated in the opposite direction! |
Hello Grandpa, no the road bike engines and race engines were the same. There was an air cooled (Interpol & Classic), watercooled (Commander) and 'reverse spin' watercooled (F1 & F1 'Sport' road bike race replicas). They were all twin rotor 588cc.
The Norton aero engine is still made in Germany.
| Kickstart wrote: | but the UK rules were fudged to allow them to race. |
Yes, the ACU said 588cc x1.7 makes it a 1000cc 'Twin', yep, that will do. Dunno where they got x1.7 from!
| Demonic69 wrote: | are you really the Wankel who created the Rotary engine? |
I bleedin hope not!!! Dr Felix Wankel is dead!! LOL ____________________
Click here for my Norton Wankel motorcycles web page |
| Dr Nick |
 Dr Nick World Chat Champion
| jayluvmito |
 jayluvmito Crazy Courier
 Posted: 23:59 - 27 Jul 2004 Post subject: |
damn, i never seen them norton f1's before....
detect the sarcasim ther.....  ____________________ one day... |
| W@nkel |
| Ava_Banana |
 Ava_Banana Renault 5 Driver
 Posted: 00:21 - 28 Jul 2004 Post subject: |
At 37 I must confess I had no real interest in bikes until a few years ago, but now am very interested.
From a technical point of view I have always been interested in the Wankel engine (well, rotary engines). It constantly amazes me how "theoretically" inefficient the process of "converting reciprocal to rotary energy/force" is.
Mazda certainly do well with them.  |
| MarJay |
 MarJay But it's British!
 Posted: 00:27 - 28 Jul 2004 Post subject: |
I haven't clicked on the link or looked at the rest of the thread but I can tell you that it was Norton, with a 1355 (or 599 depending on who you are) cc Wankel engined bike.
They make a heck of a noise!
Right, now I can read the rest of the thread!  ____________________ British beauty: Triumph Street Triple R; Loony stroker: KR1S; Track fun: GSXR750 L1; Commuter Missile: GSX-S1000F; Cheap project: CBR900RR FireBlade
| W@nkel |
| MarJay |
 Posted: 00:55 - 28 Jul 2004 Post subject: |
| W@nkel |
| W@nkel |
 Posted: 01:30 - 28 Jul 2004 Post subject: |
Lets see if i can put a photo on here... Norton F1 'Sport'
Note the 'Overweight fuckin jellymold that even the police found hard to ride' in the background. ____________________
The last post was made 22 years, 10 days ago. Instead of replying here, would creating a new thread be more useful? |
