Coolant Top Up
flamegrape
PostPosted: 12:32 - 12 Oct 2010    Post subject: Coolant Top Up Reply with quote
I noticed my coolant level is sitting on the minimum mark so I figured it would be time to top it up.
Is it a case of purchasing coolant, mixing it with water and adding it? Or adding the coolant neat?
I want to being it back between the Max/Min marks.
Thank you. Smile
Jonny (Riding his Kawasaki ZX6R J1)
Confused It's one big learning curve right now Sad
Paxovasa
PostPosted: 12:34 - 12 Oct 2010    Post subject: Reply with quote
I would put some antifreeze in.
Edit: You can check to make sure there is enough in before topping it up Thumbs Up
DrDonnyBrago
PostPosted: 12:56 - 12 Oct 2010    Post subject: Re: Coolant Top Up Reply with quote
Thank you. Smile
Winter is approaching, I'd just stick neat coolant in.
Normally you'd buy a coolant that is compatible, dilute it down if it isn't a ready mix and add that to the bottle.
flamegrape
PostPosted: 13:25 - 12 Oct 2010    Post subject: Reply with quote
Thanks guys!! Smile
Frost
PostPosted: 13:35 - 12 Oct 2010    Post subject: Reply with quote
For replacing the whole lot: Buy coolant and mix it with water etc.
For topping it up: In summer just add water, in winter just add coolant.
PostPosted: 13:45 - 12 Oct 2010    Post subject: Reply with quote
If you are just topping up and haven't got any rather than buy I would drop a cup of water into it.
The last post was made 15 years, 334 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.06 Sec - Server Load: 0.67 - MySQL Queries: 13 - Page Size: 47.06 Kb
