| steppen22 |
 steppen22 World Chat Champion
 Posted: 11:02 - 10 Oct 2010 Post subject: skipping gears? |
In the interests of saving petrol, I tend nowadays to skip third gear altogther on my er5.
So, building to 30mph, I: 1, 2-4, 5 (if long straight).
Is this likely to a) actually save petrol? B) to cause any harm to the bike. The bike is not struggling at 30mph in 5th.
I do the same in my car, sometimes 1, 2 - 5. ____________________ no regrets, no retreat, no apology.
I've made mistakes in the past, and I apologise for FUCK ALL. |
| Gazz |
 Gazz World Chat Champion
| L4Isoside |
 L4Isoside World Chat Champion
 Posted: 11:27 - 10 Oct 2010 Post subject: |
Its actually what they suggested in the theory test, but I could never make sense of it, either way you still need to accelerate to the same speed.
Now the constant RPM once you are at that speed I believe can make a fair difference, a mate drives a Skoda fabia and was trying to save fuel on the way home from some where, it turns out on the roads he was driving it was more economical to actually drive in 4th (The dash has an MPG readout)
Now I think, and it would make sense, this was because it was just being kept at the most economical part of the rev range for the speed's he was doing (I think 60/50/40 limit areas), too lower revs the engine would struggle, too high and its just wasting fuel right?
As an example I usually use 3rd or 4th in 30's on my SV, and 4th in the 30's in my car (1.6)
Usually that's just below the point where it sounds like the engine wants more...if you get me, but still sounds comfterable.
I'm sure the all and powerful Keith will be along to blow me out of the water (or that essay junkie teflon-mike!! ) |
| ms51ves3 |
 ms51ves3 Super Spammer
 Posted: 11:29 - 10 Oct 2010 Post subject: |
It's more economical to get up to 40mph in 1st and then change into 5th  |
| The Tot |
 The Tot World Chat Champion
| blurredman |
 Posted: 11:46 - 10 Oct 2010 Post subject: |
Maybe Double clutching into 5th might help ____________________ CBT: 12/06/10, Theory: 22/09/10, Module 1: 09/11/10, Module 2: 19/01/11
Current: 1973 MZ ES250/2 - 18k, 1979 Suzuki TS185ER - 10k, 1981 Honda CX500B - 91k, 1987 MZ ETZ250 (295cc) - 40k, 1989 MZ ETZ251 - 51k. |
| dragstaar |
 dragstaar World Chat Champion
| pinkyfloyd |
 pinkyfloyd Super Spammer
| johnsmith222 |
 johnsmith222 World Chat Champion
| Ariel Badger |
 Ariel Badger Super Spammer
| dragstaar |
| pinkyfloyd |
| dodsi |
 dodsi Dirty Carny
| Teflon-Mike |
 Posted: 01:26 - 12 Oct 2010 Post subject: |
Power = Work Done Per Unit Time
Work Done = Force x Dstance Moved (and is 'energy)
Bit of algebra you get:
Power = Force x Speed
Power = Torque x Revs
And by common sense, if Work-done = 'energy' and that comes from burning fuel, then you get MPG is inversely proportional to Power Used.
From a strictly scientific possition, it makes no odds at all, whether, for a certain speed, you use a log gear, with a lot of revs and a little throttle to go a certain speed, or whether you use a higher gear, less revs and more throttle..... takes the same power, so you use the fame fuel......
Using the higher gear, though will NORMALLY lessen your rate of acceleration, which means you dont go as fast to a certain speed, so for more time you are travelling slower, hence using less power, hence using less fuel.
Now, in the real world......
People will argue '"Ah! But what about 'efficiency'?!"
and start arguing that an engine works most efficiently at a certain rpm and and then all about the wasted energy of redundant cycles and stuff.......
Becouse they have read a book or soemthing, and have an 'idea' about the science, and try to apply it......
BUT, for the most part while theres truth behind a lot of it, there is an anomoly when talking abouyt 'efficiency'.
Peak 'Torque' on an engines power curve normally depicts the engine speed where greatest cylinder pressure is achieved.
That occurs when you have the 'best' COMBUSTION efficiency, and get most power out of teh fuel burned.... but that point doesn't often have much to do with overall SYSTEM efficiency.
As engine speed increases, so the energy losses from reciprocating components increase, and they increase exponentially.
Peak torque tells you where your getting the best bang out of your fuel, but iof its at higher revs, you might be using MORE of that released energy JUST to turn the engine that fast, than you are getting as extra useful work, shoving the bike along.
So, in the REAL real world, it means little.......
And applying the fundemental science, rather than getting lost in the jargon and half understanding of engine efficiencies.....
What works?
Power = Force x Speed.
Faster you go, more power you gonna use, more fuel you gonna use.
Force is the force made by the engine, used to overcome the drag, mainly of wind resistance, and THAT increases exponentially with speed.
SO, if you WANT to get better mpg, go slowly, accelerate gently, DONT waste energy braking hard!
Ride 'predictively', so you dont have to do anything in a hurry, ride smoothly, so you dont accelerate hard, or brake hard, or corner hard, you do everything nice and gently with as LITTLE force as possible, and you'll save fuel......
What GEAR you actually use at any particular moment in time.... and certainly for the few moments of getting to 30mph..... I dount it would make FUCK ALL difference!
Make the motor labour starting in 2nd and block shifting straight to 4th...... you are just making life harder for yourself. Accelerating all the way in 1st, letting the motor rev out, would PROBABLY not use ANY more fuel, or such a miniscule difference as to be negligible, PROVIDED you apply some throttle control and accelerate at the same rate.... ie gently.
Have this debate quite a lot, and EVERY-ONE wants something for nothing, or the magic fix, that will let them go faster AND get better MPG, but the fundementals of teh science essentially forbid it.... you want mpg, go slow, you want speed, you pay for it in extra fuel.
BUT, do take heed of that 'ride smooth' motto.
If you DO adopt a predictive riding style, OFTEN you'll not only get better mpg, but you CAN go faster... at least point to point. Riding like that you can maintain a higher average speed, than riding more reactivelt, and dramatically, using a lot of hard acceleration, braking and cornering.....
and again, in the REAL real world, THAT 'efficiency' gain from riding style is FAR more influential than whats going on inside the engine, to the MPG you get.
Something that used to be a mantra of a lot of advanced riding courses.... dont know if it still is, but maybe something you may like to look into. ____________________ My Webby'Tef's-tQ, loads of stuff about my bikes, my Land-Rovers, and the stuff I do with them!
| dragstaar |
| TUG |
 TUG World Chat Champion
| Paxovasa |
 Paxovasa World Chat Champion
| joncwl |
 joncwl Scooby Slapper
 Posted: 19:34 - 12 Oct 2010 Post subject: |
| Quote: | Power = Work Done Per Unit Time
What works?
Something that used to be a mantra of a lot of advanced riding courses.... dont know if it still is, but maybe something you may like to look into. |
i learnt all of this when i did motor engineering worst thing about the course all that algerbra crap ____________________ currently being a cager cause winter......the bike will be back out during the summer now
last bike, 1990 yamaha tzr125 (2rk model) - still after a fairing kit for it !!!!! |
| dragstaar |
| johnsmith222 |
| pinkyfloyd |
| Paxovasa |
 Posted: 22:09 - 12 Oct 2010 Post subject: |
| L-Jam |
 L-Jam World Chat Champion
 Posted: 22:43 - 12 Oct 2010 Post subject: |
Basically, Teflon-mike is saying that better MPG = less fun...
the side effect of riding as such is taught by the advanced motorcycle malarky groups though, is that you do indeed become a 'better' rider. ____________________ Journalist, student, egotist.
Skp 50 --> GS 500 --> CBR600F with custom HRC paint jobby --> GSX-R 750 K7, beautiful! |
| Teflon-Mike |
 Posted: 02:28 - 13 Oct 2010 Post subject: |
| L-Jam wrote: | Basically, Teflon-mike is saying that better MPG = less fun...
the side effect of riding as such is taught by the advanced motorcycle malarky groups though, is that you do indeed become a 'better' rider. |
Depends what your idea of 'fun' is......
But 'fun' does tend to cost money..... like I told my eldest when he first started work..... "If it was non-stop fun' there'd be a turnstyle rather than a clock-in card, & you'd be paying THEM to attend, like at Alton Towers.... rather than being paid....
But what did Mary Poppins say? The trick was to find the ounce of fun in everything you do?!?
To be honest, I've never really bothered riding for ecconomy on a bike, only thing that really got me thinking about it was when I first bought a Range-Rover V8! ACTUALLY, no, it was when I let the ex have the Rangie to use to get to & from work...... had rather a lot of time...... stood next to the pump filling it back up to ponder...... like why I got nearly 20mpg out the thing...... where she barely broke into double figures!
Though when I used the VF-Thou as every-day transport, it did rather high-light the matter. Bimbling about sight seeing, could be in the saddle almost all day, before it ran onto res... has a five and half gallon tank! Stop to fill up, and then realise that riding at legal speeds down long by-passes and bimbling about conutry roads taking in the sights, I'd covered over 400 miles since last fill up and returned around 70mpg...... but 'hooning it' on the way home from work a couple of times, the half gallon in reserve had, on occassion, BARELY got me five miles from the round-about it started stuttering on, to the nearest filling station! ____________________ My Webby'Tef's-tQ, loads of stuff about my bikes, my Land-Rovers, and the stuff I do with them!
| Black Knight |
 Black Knight World Chat Champion
The last post was made 15 years, 139 days ago. Instead of replying here, would creating a new thread be more useful? |
