Fudging indicator relay
snowdude2004
PostPosted: 21:29 - 13 Oct 2010    Post subject: Fudging indicator relay Reply with quote
Well I got some new rear indicators for my cbr 400 because the OEM ones looked horrible and the rear left one had stopped working and the bolts were rounded on it etc etc so thought sod it and bought led ones.
Thought that because i only have leds at the back I might be able to get away without buying an led relay however they flash like mad.
So I've been trying to hunt down a three pin led relay for the cbr and can't find anything.
Was wondering if you guys might know where I can get one or a trick to doing it another method?
Here's a couple of dodgy blurry pics and a video of the bastard.
https://i31.photobucket.com/albums/c376/snowdude2004/CIMG1449.jpg
https://i31.photobucket.com/albums/c376/snowdude2004/CIMG1448.jpg
https://i31.photobucket.com/albums/c376/snowdude2004/th_CIMG1450.jpg
CBT passed: 26/09/09, Theory Passed: 18/08/10, Mod 1 passed: 20/10/10, Mod 2 passed: 26/10/10.
Current Bike: Honda CBR 400 Nc23
SillyMe
PostPosted: 21:49 - 13 Oct 2010    Post subject: Reply with quote
Hope this helps.
Scroll down look in the middle for cbr led flasher relay's
https://www.biker-discount.co.uk/bulbs-nightracer--nightbreaker---relays--electrics-57-c.asp
https://www.biker-discount.co.uk/honda-3-pin-led-flasher-relay-led-flash-rate-fix-1482-p.asp
Once made equal to man, woman becomes his superior.
The man who says "I may be wrong, but -" does not believe there can be any such possibility
Owned and rode: Honda 100H, Honda MBX 125, Kawasaki AR 125, Suzuki RG 125 Pepsi, Honda NSR125 RK, Honda NRS 125 race bike, Suzuki GSXR 400 Bandit, Aprilia RS 125 O2, Honda CG125, Kawasaki KMX 125, Aprilia RS 125 O6, Suzuki XT225 and now Honda XR 400. ( A few scooters and other dead beats in between)
snowdude2004
I was thinking about trying to fit some sort of a resistor onto each indicators but not sure what size I would get and that just involves too much mucking about and trail and error.
SillyMe
PostPosted: 21:51 - 13 Oct 2010    Post subject: Reply with quote
rob yarrr wrote:
i think some people put resistors on them to slow um down,but not exactly sure where or how
Correct, you are knowledge and I is wisdom.
Slow down those LED's
https://www.customfighters.com/forums/showthread.php?t=18684
snowdude2004
PostPosted: 22:04 - 13 Oct 2010    Post subject: Reply with quote
Esoteric1 has too much knowledge :L
Looked at those relays which are like 20 quid, May have to buy one of those since I plan on keeping the bike as standard as possible with minimal modifications because I hate wiring!
SillyMe
PostPosted: 22:11 - 13 Oct 2010    Post subject: Reply with quote
Sounds like a good idea unless you want go down the resistor route.
V over
___________
AMPS times R and all that!
Instructions should be on the site though to set it up.
herulach
PostPosted: 22:26 - 13 Oct 2010    Post subject: Reply with quote
WHat wattage are your new ones? Busters do an 8w one for 2.99. It probably won't be too bad if you have an incan at the front.
If you want to go with resistors, you're using R=V^2/P. Find out what the stock bulbs are, stick it in for P, V=13.5 ish. fanny's your aunt. Just make sure you get a decent wirewound resistor.
Maplin do 10W ones (thats maximum continuous dissipation). I'd be tempted to use 2 in series to give yourself some headroom (just halve the resistance). Wiring is easy, just split one of the wires & put the resistors in series (edit, with each other, parallel to the indicator).
Hopefully that makes sense (I've seen this done litterally hundreds of times, used to work in maplins next door to a HG.)
YBR 125>FZS600
Itchy
PostPosted: 22:29 - 13 Oct 2010    Post subject: Reply with quote
Go to a car motor factors and ask for one. A bike place wanted £10 for one the car place next door wanted £1.50 Very Happy
cb1rocket
PostPosted: 22:30 - 13 Oct 2010    Post subject: Reply with quote
Maplin do 10W ones (thats maximum continuous dissipation). I'd be tempted to use 2 in series to give yourself some headroom (just halve the resistance). Wiring is easy, just split one of the wires & put the resistors in series.
you mean wire them in parallel? that how mine has been done once before
herulach
PostPosted: 22:36 - 13 Oct 2010    Post subject: Reply with quote
Doh, yep.
YBR 125>FZS600
SillyMe
PostPosted: 22:55 - 13 Oct 2010    Post subject: Reply with quote
Online resistance in parallel calculator if needed but previous posts sound as though they have solved the problem.
https://www.1728.com/resistrs.htm
SillyMe
PostPosted: 23:18 - 13 Oct 2010    Post subject: Reply with quote
LOL.
AKA, Bodge it and leggit.
Why not?
If it works why take the batteries out?
The last post was made 15 years, 325 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.10 Sec - Server Load: 0.77 - MySQL Queries: 13 - Page Size: 83.6 Kb
