Stainless bolts in aluminium swingarm
MarkJ
PostPosted: 10:29 - 14 Oct 2010    Post subject: Stainless bolts in aluminium swingarm Reply with quote
The RSV has an aluminium swingarm, and the hugger is bolted to it with four small stainless steel allen key bolts (needs a 3mm key). Now being where it is the threads get soaked in water (and salt water in winter) which makes the bolts and swingarm corrode together. Then when you try to get them out you just end up rounding out the small allen key hole.
I managed to get these bolts out last night - but it took me over two hours, and they're all ruined now because I had to either saw a groove in them or hammer a torx head into them.
If i buy some direct replacements the same will happen eventually. I see myself as having two options:
1) Buy some more SS bolts and lube them up with some sort of grease. Apparently copper grease will eventually let the corrosion happen so that's out. I've been told maybe a type of molykote. Any others?
2) Buy some bolts of a different material. I was thinking titanium, would these corrode with the aluminium at all?
Raffles
PostPosted: 12:43 - 14 Oct 2010    Post subject: Reply with quote
Stainless steel bolts aren't terribly expensive to buy. Rather than trying to find a permanent solution to your problem (which might not be possible) you could always purchase a quantity of extra bolts and discipline yourself to change them every few months before the corrosion gets too severe. Just a thought.
SillyMe1 This post is not being displayed because the poster has bad karma. Unhide this post / all posts.
Bru
PostPosted: 13:20 - 14 Oct 2010    Post subject: Reply with quote
Avoid copper grease, as it is intended for high-heat applications where the grease may be cooked out, leaving the copper as an anti-seize lubricant. You do not want to lubricate your threads in your application.
Use medium-strength thread lock compound. Loctite 243 or similar. The compound will prevent corrosion. In all the cases I've seen, the corrosion is usually found along the shank of the bolt and at the 'top' of the thread (near the bolt head, closer to 'outside'), if the hole is blind. So, that is the key when applying the threadlock.
Bezzer
PostPosted: 13:34 - 14 Oct 2010    Post subject: Re: Stainless bolts in aluminium swingarm Reply with quote
Near enough all metals react with each other when water is present giving you galvanic/electrolytic reaction that can "weld" them together. Just depends where they are in the table as to how bad it is. Anything that creates a barrier between the metals stops/reduces it so they don't bind. Ti might be a touch better than Stainless but as long as you use at least copper grease or one of the more expensive anti seize compounds you should have no problem .
Where you're using it it doesn't really matter that copper grease would be lubricating the threads, as said it was developed for high heat applications but countless people have used it for donkeys years as a normal anti seize.
Teflon-Mike
tl;dr
PostPosted: 16:25 - 14 Oct 2010    Post subject: Reply with quote
Depending on how secure it is, & how heavy, and whether the bolts are M6 or not...... I'd be inclined to look at Plastic M6 Number-Plate screws.
Used to use them on my dirt bike quite a lot of low stress fastenings, as they dont rust up & if they dont want to come out you can cut them easily enough with a pair of wire snips.
MarkJ
PostPosted: 20:12 - 14 Oct 2010    Post subject: Reply with quote
Plastic bolts sounds like a good idea actually, hadn't thought of that! There's four M5x16 bolts which should hold fine:
https://aprilia.vladiks.com/forsale/Hugger.jpg
(not my bike)
For reference, you can get a gel called Tefgel which (believe it or not) has teflon in it and is used with steel & aluminium in boat applications which sounds as though it would work well.
Also, apparently titanium is worse for corrosion with aluminium as it's further away on that scale.
PostPosted: 20:24 - 14 Oct 2010    Post subject: Reply with quote
Afraid I would use copper grease. Might eventually allow corrosion, but will take so long as to likely be irrelevant.
neil.
PostPosted: 20:58 - 14 Oct 2010    Post subject: Reply with quote
+1 Copper grease. I have used it all over the bike on various fasteners where Locktite is not specified and never had anything rattle loose with it, ever. In fact, I found it isn't really a good lubricant anyway - tried it on my rear drum brake cam and it went stiff again after a month or so.
kestrel
PostPosted: 21:44 - 14 Oct 2010    Post subject: Reply with quote
There are specialist gels and greases available to combat this problem. One i have used before with excellent results is called Tef Gel, made from finely powdered PTFE.
https://www.sailboats.co.uk/ProductInfo.aspx?productid=TG-01
SoND
PostPosted: 01:00 - 15 Oct 2010    Post subject: Reply with quote
If you are torquing the bolts up be careful because the numbers are maybe given for a dry thread. A greased bolt will turn a little more than a dry bolt under the same force with a greater chance of stripping the thread in the aluminium.
Im-a-Ridah
PostPosted: 01:11 - 15 Oct 2010    Post subject: Reply with quote
Also in favour of copper grease, I've got a tub of that and normal grease out back. If you are that worried, just check the greased bolts every year or so Smile
SoND
PostPosted: 02:21 - 15 Oct 2010    Post subject: Reply with quote
The aluminium corrodes before the stainless, sticks to the bolt and locks it in place. Replacing the bolts will serve no purpose other than clearing the threads on removal, taking the bolts out once in a while and maybe giving them a quick wire brush if they need it will do the same job.
Walloper
PostPosted: 07:39 - 15 Oct 2010    Post subject: Reply with quote
Don't use copper grease (hee-haw to do with high temperature applications BTW. It is not designed for Hi Temp use AFAIK.)
Copper will react with the stainless for certain so not worth using it.
Dissimilar metals will react galvanically so as suggested preventing water ingress will reduce or eliminate this effect.
Silicone sealant, permatext, hylomar molibdenum grease will work fine.
I had a swing arm chain adjustment eccentric thing on a Triumph bike. Piece of shit was for ever seizing in the swing arm clamp due to galvanic-ism. Was advised by dealer to use copper-slip anti-seize too.
I changed to molycote and solved it.
Bezzer
PostPosted: 13:34 - 15 Oct 2010    Post subject: Reply with quote
High temperature anti seize applications is exactly what it's main purpose is.
No it wont. No one I know has ever had a problem with using it. Personally used nothing but for 40 years or so.
You only have to protect the threads so avoiding metal to metal contact which copper grease or other anti seize compounds will do. Who wants gobs of silicone sealant everywhere.
dodgydog
PostPosted: 15:59 - 15 Oct 2010    Post subject: Reply with quote
Copper grease, without question, I have used it for years, cars, bikes, everything.
Dog
I know that you believe that you understood what you think I said, but I am not sure you realise that what you heard is not exactly what I meant
dodgydog
PostPosted: 16:01 - 15 Oct 2010    Post subject: Reply with quote
CHR15 wrote:
wipe some Vaseline round the hole, and over the head once its in place.
Are we still talking about his bolts??
fnarr....fnar.
Dog
Bru
PostPosted: 15:52 - 16 Oct 2010    Post subject: Reply with quote
All I can add, is that in my experience, I have had two sets of bolts come loose which were lubed with copper grease; I had torqued them to the values set in my service manual. Never happens with thread-lock.
The last post was made 15 years, 323 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.10 Sec - Server Load: 0.31 - MySQL Queries: 13 - Page Size: 100.73 Kb
