| frenchy |
 frenchy Derestricted Danger
 Posted: 12:47 - 25 Sep 2010 Post subject: Aprilia rs 125-trouble starting arghhh |
hi guys, my second post on here.
basically, my rs 125 wont start.
-if you try off the ignition, it makes a horrible sound and wont fire, so i bought a new spark plug although the old one seemed to be sparking fine, also replaced battery and ensured it was FULLY charged. still no joy. After many many bump starts, finally she fired up, bt then cut out, however this could be due to a lack of petrol etc...as i had removed the tank and used a squeezy bottle just to make sure petrol was getting through. All of the other electrics seem fine, horn, lights etc work.
Now even though it started after countless bump starts it doesnt seem to want to start again and definately not from electric start.
i removed the spark plug to compression test it, the meter didnt pick up a reading. i was turning the engine over by hand (would this have effected it) ? i wouldve thought i should get a reading, may be not all the high even if there was an issue.
When i got the bike it had been partially stripped and the previous owner had bought a car and lost the will to put it back together so the carb etc was all disconnected. (i reconnected this np). He claims he had redone the top end recently...
Soo, any help would be greatly appreciated it, dying to get it started, up and running to use for commuting to uni.
Any tips on how to clean out the carb etc too?
by the way, anyone have any info on getting insured on 'big bikes'....i was thinking of getting a gsxr 600 and having it restricted to 33bhp to be legal, bt previous insurer said they couldnt insure me as most young lads remove the restrictions straight after etc.
however, they would insure me on a gsx-750 for £650. (dnt really want a gsx though, much prefer looks and performance of gsx-R..all be it restricted)
and insurance for my rs125 is £250 a year. |
| paulcdb |
 paulcdb Scooby Slapper
| frenchy |
| stirlinggaz |
 stirlinggaz World Chat Champion
| frenchy |
 Posted: 16:49 - 26 Sep 2010 Post subject: |
recharged battery with trickle charge just to make sure its definately full. ill follow your advice and clean carb, filter etc etc. also, the compression meter i used wasnt a screw in, just had to push it in, rubber bung on the end type thing, so couldve been losing compression through that too. im thinkng the top end was not rebuilt correctly.
My bike does not have a kickstart (annoyingly).
Just got the paperwork back from the DVLA and year of manufacture is 2000, not 2001 like i originally thought.
funny you should mention bendix, thats what i suspected. i think the little carbon bush or w.e it is has gone, or needs replacing at least. the start motor/bendix is where the horibble sound comes from, its hard to describe, its not a grinding sound, its like a clunking/clicking/wierd rattle type sound. im nt 100% sure that the starter motor is engaging properly to turn the engine over sufficiently.
The spark plug im using is a Br10. ( although ive looked about and different places stay different things, some say br10, some say br9.) Is it br10 as my bike is fully derestricted?
I think the carb is 34mm btw, should the bike be rejetted after this? if so, how do i know it has been. (sorry if this is a daft question) |
| stirlinggaz |
 Posted: 18:12 - 27 Sep 2010 Post subject: |
Hi,
if it has the standard carb, then its the 28mm., unless someone has upgraded it.
(the 34mm carb was only standard on the older rs)
spark plugs (as recommended by rotax) :
BR8 for restricted version
BR10 for full power version OR
BR9 for full power version if you dont intend red-lining it continously.
i have always found the BR9 to be more suitable, as it wont foul as easily & the bike will usually be easier to start..
definitely test compression, as hard starting can be a sign of low compression & sometimes just new rings will cure this.
(get a good tester on it, test it 2 or 3 times & post results)
the clunking noise you hear will likely be the bendix gear rather than starter motor.
the starter motor does take a bit of punishment due to where its situated & can be re-furbished, though might be easier just to replace.
still tempted to think its just the usual clunky starting issue, caused by a low battery or/+ the bike being sitting around for a while.
AND the carb needing cleaned & set up properly,
(theres a good guide on here by Kickstart about dellorto carbs)
cheers,
GAZ |
| skills |
 skills Derestricted Danger
 Posted: 09:55 - 14 Oct 2010 Post subject: |
I had the same sort of problem with my RS 125, I do not know alot about bikes but I do know that the problemm was something pretty simple. I'll find out exactly what this problem was and get back to you. Hopefully it may be able to help you too.  ____________________ Billy. Loved my aprilia rs 125, also love to find the kids who nicked it. Soon as the insurance pay out i'll be buying another. https://www.apriliars125.co.uk  |
| SillyMe |
 SillyMe Trackday Trickster
 Posted: 17:29 - 14 Oct 2010 Post subject: |
Yeah check the float chamber, had loads of trouble with mine, the floats them selves were filled with petrol so couldn't maintain hight to shut off the needle valve. This alone will make these bike run horrible, Full of gunk too. Give it a good sorting pal and try again.
Well I can speak from experience here as I too was ripped with an Aprilia RS125. I got it really cheap off ebay and realised there would be something wrong, but it still stood me in credit after I fixed it.
It's a very common thing i'm afraid.
When you said the engine sounded really bad after the initial fire up, this indicated to me the top end needs a rebuild.
It's difficult to tell without a proper compression test becasue my barrel was OK(No scratches), I had it rehoned anyway and fitted a 10th of a milli oversized Vertex teflon coated piston kit. Trickly little job.
If you need to go down this route you will need top end gasket kit, you may need jubilee clips for the hoses as a result of not having the correct Aprilia tools to remove the hose clips fitted as standard, and a few cable ties for the wiring loom. You even need a special tool for the reed block, this keep Aprilia mechanics in work, but you won't need to remove this.
When the carb isn't set correctly on these they don't run I'm afraid, I believe they are designed to fail. Horrendous but true. Keeps people in jobs and scampsters in pocket.
These helped all the way, they specialise in Aprilia's
https://www.pjme.co.uk/
https://www.swiftcover.com/motorbikeinsurance/faq/
Follow the instruction and fill in the fields, you will be issued with a load of qoutes starting with the cheapest.
Just call the brokers who give you the best qoutes direct from the number given.
Sorry guy's gunna hog this thread with a few pics too.
https://img193.imageshack.us/img193/5821/dsc00075xs.jpg
Make sure the two stroke feed is set up correctly!
https://img135.imageshack.us/img135/1194/dsc00072z.jpg
Rehoned for 10th of a milli oversized piston kit to be installed.
https://img718.imageshack.us/img718/3623/dsc00074ee.jpg
Notice the white cable ties.
https://img412.imageshack.us/img412/1606/dsc00067rz.jpg
And finaly the beast here self running like a dream.
https://img176.imageshack.us/img176/1914/dsc00077by.jpg ____________________ Once made equal to man, woman becomes his superior.
The man who says "I may be wrong, but -" does not believe there can be any such possibility
Owned and rode: Honda 100H, Honda MBX 125, Kawasaki AR 125, Suzuki RG 125 Pepsi, Honda NSR125 RK, Honda NRS 125 race bike, Suzuki GSXR 400 Bandit, Aprilia RS 125 O2, Honda CG125, Kawasaki KMX 125, Aprilia RS 125 O6, Suzuki XT225 and now Honda XR 400. ( A few scooters and other dead beats in between) |
| SillyMe |
 Posted: 22:26 - 14 Oct 2010 Post subject: |
Just one more thing, if it is a top end job it cost me no more than £150 plus the train fare to Wolverhamton and back. ____________________ Once made equal to man, woman becomes his superior.
| 121game121 |
 121game121 Two Stroke Sniffer
| N cee thirty |
 N cee thirty Banned
The last post was made 15 years, 207 days ago. Instead of replying here, would creating a new thread be more useful? |
