Motorbike working drawings
saikouslx
PostPosted: 19:56 - 15 Oct 2010    Post subject: Motorbike working drawings Reply with quote
Hi, i just started my firstyear at university studying automotive engineering, basically we've started using solidworks which is a cad program. Ive been looking for working drawings for a rs125 (because i have one Smile ) but any bike will do, as id like to get practice but it wud just be better if i rendered a bike,as the plan is to draw the bike in 3d on the program from working drawings. good fun and that and it will give me alot of practice which hopefully will come in useful later on.
Tristan.
PostPosted: 20:08 - 15 Oct 2010    Post subject: Reply with quote
Have you only recently started using solidworks? The amount of surface modelling and very complex shapes and the steep learning curve means I would advise you to start a bit less ambitious, go through tutorials and some easier subjects (engines are fairly easy) before you try to recreate frames and fairings
I will do a bit of solidworks whoring though Razz It's really addictive when you get started
https://i35.photobucket.com/albums/d170/tristanthe/Renders/shock1.jpg
https://i35.photobucket.com/albums/d170/tristanthe/Renders/shock.jpg
And to give some indication of time spent, the shock (30 components) took maybe two hours, the frame took easily double that, the only bit thats finished is the main spars, but it's pretty much 100% accurate to an FZR400 frame spar. The other parts of the frame model (steering head, subframe support, engine mounts etc) took barely 10 minutes - to give a rough indication of how it will look. Theres a huge difference in modelling smooth surface heavy objects.
neatbik
PostPosted: 21:21 - 15 Oct 2010    Post subject: Reply with quote
I would love to have a crack at this stuff, but im put off because im guessing it takes a hell of a lot of effort to learn. Embarassed Laughing
saikouslx
PostPosted: 17:19 - 17 Oct 2010    Post subject: Reply with quote
I know its hard but although i havent been using solidworks for long but i have been using similar software. Its a challenge, i know i wont be able to draw it straight away but thats part of the challenge!
Tristan.
PostPosted: 12:25 - 18 Oct 2010    Post subject: Reply with quote
Oh I wasn't trying to dissaude you, I'm just advising, a lot of things that look very impressive (working mechanisms particularly) are very easy when you get your head around it, but stuff which involves freeform curves such as fairings and frames really take a lot of knowledge, the way I did the frame up there involved curved shapes lofted between about a dozen different planes all at slightly different angles, and that was the easiest way of doing it!
In a couple hours I'll hopefully be able to post up a fully working gearbox designed from scratch (started about 20 minutes ago) You'll see how much easier complex assemblies made from simple parts are.
I'd advise you to start by making a replica of your aprillias engine, that should give you a basis of the skills you'll need to start the rest, plus then when people look at it you can go into wireframe mode and show off it's working innards.
FLV
PostPosted: 14:33 - 18 Oct 2010    Post subject: Reply with quote
2 hours is quite fast for that shock, I use catia V5 for a living and I suspect that shock would take longet than that even if copied from an exisitng drawing
parp...brap....parp
neatbik
PostPosted: 20:04 - 18 Oct 2010    Post subject: Reply with quote
Actually i want to have a crack at this.
Can you reccomend any decent tutorials?
And would solidworks 2006 be ok or is the 2010 version significantly better?
Karma Thumbs Up
Tristan.
PostPosted: 20:15 - 18 Oct 2010    Post subject: Reply with quote
2010 is a lot prettier and slightly more intuative, but I've never had a problem using older versions. Also worth bearing in mind that you can generally open older version saved files on a newer version, but rarely the other way round (you can save files as STEP or IGS to get round this but you lose everything bar the basic shape (feature history etc))
I just used the contained tutorials and went from there, but I found it a big learning curve, theres also youtube and forums, but I've never bothered.
If you have trouble finding a free version theres also
https://www.caligari.com/
which is completely free apparently with downloadable tutorials and manuels
(if you find a free download of SW2010 I wouldn't mind if you shared it Razz )
kevinjones This post is not being displayed because the poster is banned. Unhide this post / all posts.
saikouslx
PostPosted: 14:31 - 21 Oct 2010    Post subject: Reply with quote
yeh i probs will give it a crack, i know my engine inside out, i would however prefer to make my drawings accurate and unfortunately my bike is back home also i dont fancy taking it apart if i dont need to, but i shud be able to find some dimensions around. Cheers for the advice, and on the 2010 version the built in tutorials are really good.
The last post was made 15 years, 319 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.08 Sec - Server Load: 0.37 - MySQL Queries: 13 - Page Size: 64.83 Kb
