Gearbox woes - Diversion 600
Swim41
PostPosted: 11:09 - 16 Oct 2010    Post subject: Gearbox woes - Diversion 600 Reply with quote
Having problems with the gearbox on my 34'000 mile 600N. I've not ridden it much recently having been using my YBR for most things.
Anyway the gearbox seems to bang and clunk more than it used to. I say 'seems', because being used to the silky change on the YBR box the thunks from the Divvy seem savagely brutal.
I have done the following to try and sort it: new sprocket carrier bearings and rear wheel bearings, cleaned and tensioned chain (have tried varying tightnesses, doesn't seem to make much difference). The oil is of good quality (Silkolene Super4) and changed 1800 miles ago. The clutch is adjusted and appears to work correctly (when on stand, rear wheel does not turn with engine running and clutch pulled in).
Worst changes are 1st to 2nd, and especiallty 2nd into 1st although any changes involving gears 1 to 4 can be pretty violent (I actually find myself wincing and bracing myself when changing between 1st and 2nd and down again). The symptoms are not constant however, sometimes the gears snick in, other times there is a severe bang when engaging I'd estimate this was about 50/50.
Another symptom is when changing down into 2nd or 1st it won't actually make the change immediately, giving a the impression of the gears refusing to engage.
In all doesn't make for an enjoyable ride and I'm thinking of getting rid, which is a shame as these engines do have a reputation for toughness and it's not a bad medium tourer/rally bike. At the moment though, the YBR is much more fun to ride.
Any suggestions? Is this likely to be terminal?
thanks Smile
Yamaha XJ600N
el_oso
PostPosted: 14:15 - 16 Oct 2010    Post subject: Reply with quote
i always found that my divvy was quite clunky from 1st to 2nd and vice versa, but smooth in other gears.
this problem may be time to have a look at the gear box unfortunately. selector forks damaged or damaged/worn dogs would be my guess, but i certainly am no expert
Duke 390
Car: Jeep Wrangler 4.0L
iooi
PostPosted: 09:12 - 17 Oct 2010    Post subject: Reply with quote
Crush rubbers ?
You have not mentioned these.
Any free play in the front sprocket to indicate a knackered bearing due to chain being too tight.
Is it a new chain, or a old one with a tight spot ?
Swim41
PostPosted: 14:17 - 17 Oct 2010    Post subject: Reply with quote
The crush rubbers appeared in good order when I replaced the rear wheel recently. The chain is in pretty good condition, replaced approx 8k ago and seems OK.
Re: front sprocket - am I looking for sideways play in the shaft?
Yamaha XJ600N
PostPosted: 19:09 - 17 Oct 2010    Post subject: Reply with quote
Can you try something? Put the bike on the centre stand, engine running and in gear. With the back wheel spinning pull the clutch. See if the wheel spins for any length of time (if it stops almost immediately then I would suggest the clutch thrust bearing has failed).
iooi
PostPosted: 19:24 - 17 Oct 2010    Post subject: Reply with quote
Front to back, up or down.
I would also go with keiths idea. As it will also show and issues with the chain as you will see it bouncing around.
Swim41
PostPosted: 21:10 - 17 Oct 2010    Post subject: Reply with quote
Have duly tried your suggestion Kickstart, in 1st at idle, the wheel manages six to seven revolutions once the clutch is pulled in.
iooi: have had the sprocket cover off - the shaft does not seem to have any play.
Thanks for your suggestions, much appreciated.
Yamaha XJ600N
PostPosted: 21:18 - 17 Oct 2010    Post subject: Reply with quote
That probably counts out the thrust bearing.
You have covered most other normal things (assuming the chain is fine)
Is the clutch cable smooth? Same for the throttle cable?
Swim41
PostPosted: 21:51 - 17 Oct 2010    Post subject: Reply with quote
Control cables are regularly oiled and the clutch cable is newish, seems to operate smoothly. I've also checked for play in the actuator (sorry, not sure of correct term) on the clutch cover, seems OK.
I've just had a look in my notebook and was surprised to see that the chain is 12'000 miles old, which I suppose it quite a lot without a Scottoiler fitted. However seems in reasonable condition, with plenty of adjustment left and is not loose on the rear sprocket. I'll have a closer look at the chain tomorrow.
thanks for your help
Yamaha XJ600N
Noxious89123
PostPosted: 22:47 - 17 Oct 2010    Post subject: Reply with quote
Plenty of adjustment left might just mean that it has alot of tight spots. If the tension varies alot between different sections of the chain, then it's probably ready for the bin.
Also, it's called a cush drive, which contains cush drive rubbers, not crush. Wink
https://en.wikipedia.org/wiki/Cush_drive
iooi
PostPosted: 07:58 - 18 Oct 2010    Post subject: Reply with quote
Did seem wrong when I typed it.....
Got away with it for long enough
The last post was made 15 years, 349 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.09 Sec - Server Load: 1.15 - MySQL Queries: 13 - Page Size: 72.15 Kb
